Question about Samsung MW1080STA Microwave Oven
SAMSUNG CM1929 E41
AFTER 5 SECONS TURNS OFF AND COMES UP WITH E41
Whirlpool GMH5205XVS0 stop after few secons no heat and show A F7 signal
See my help files here: http://www.microwavecontrol.com/safety.htm
http://www.microwavecontrol.com/disassembly.htm There is a service bulletin here for trained service personnel which addresses the diagnosis and cure for the F7 error code in these models.
There should be a technical sheet hidden behind the controls of your microwave. If not, it is here. It is helpful.
Feel free to contact me directly (see below) if you have other questions.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Dec 01, 2017 | Whirlpool Microwave Ovens
Filter showing on control panel
try unplugging it for 5 minutes
Aug 17, 2015 | Samsung Microwave Ovens
The microwave got the codeh97
What brand is it? Check with the manufacturer. There were recalls announced because of fire hazards from microwaves starting on their own later. Unplug the unit now.
Feb 14, 2013 | Panasonic NN-SN657SMicrowave Oven
I have samsung 1850w CM1929 Microwave it shows e41 and does not work.
if you have not plugged out the microwave...then do so now.the trick is that when you plug out the microwave it will reset the microchip.after you have plugged it out ....then you plug it back in after about an hour.if that does not work then it is time to look for a tech to repair your microwave.the problem is that the diode or the cap is bad.
Mar 04, 2011 | Samsung MW1080STA Microwave Oven
Cm 1929 error code e41
i there i have a samsung cm1929 microwave and it coming up with the code e41 please help thanks mike
Nov 08, 2010 | Samsung MW1080STA Microwave Oven
Just bought new Samsung SMH9151 OTR Microwave. Installed it and it turns on for 3 seconds and turns off. I took it back down and just plugged it in the wall plug (while sitting on the counter) and same...
I don't mean to be coy, but if you bought it from a local company (Best Buy, Lowes, Home Depot), take it back (within the 30 day window) for a refund. I bought three microwaves (all poor quality) and returned them all!
I may be returning this Samsung if your review turns out to be true for my microwave.
Jun 03, 2010 | Samsung SMH9151 Microwave Oven
Microwave will not heat. The light comes on the turntable turns
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/./,/,
May 16, 2010 | Maytag MMV4205 Microwave Oven
Not heating food
Sounds like the magnetron has failed. It will need replacing by a qualified microwave engineer to be sure it's safe.
Jul 18, 2008 | Samsung Microwave Ovens
Samsung MW1080STA Microwave Oven Logo
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
