Question about Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat
Heater wont start makes buzzing sound
I took cover off. turned fan manually really stiff moter then had to spin while turning unit on then fan started.do i just need to replace the brushes or do i have to replace the moter?
    Novelist:
  • 88 Answers
Thanks for your question,
Changing the brushes might help, but more often since you said its really stiff, something in the motor over heated and it would probably benefit you more to change out the motor, the windings could be burned up, at least you will have the peace of mind that you know your motor wont lock up again. if it were me, I would replace over repair, hope this helps, please rate this and let us know what happens, thanks again,
mr.grzz
Posted on Jan 26, 2009
Turn on AC but outside unit fan doesn't move
Either a very bad Capacitor, or the fan belt came loose and the motor is just spinning
May 26, 2014 | Empire DV-215 Direct Vent Natural Gas...
Gas package unit
the bushing or the bearing in the motor may have already worn out. or may need some lubrication. the rotor is trying to turn but it's stiff and won't continue to turn. dont continue to turn on if it wont spin otherwise you'll damage the motor further. it might also be the busted capacitor "if it has"
Jun 04, 2013 | Amana Heating & Cooling
No suction from my kirby sentria
I just took a stiff piece of coax cable, and took the bag off where it attaches to the main unit, and took the head off ( the part with the brush roll in it) AMD cleaned every thing really well, turning the spindle for the fan while " snaking" it and pulled out a baby sock! Ta-Da! Works like New.
Apr 29, 2012 | Kirby Ultimate G Bagged Upright Vacuum
I have a 110,000 btu reddy heater model r110. When i plug it in it just makes a buzzing noise? I am pretty good at fixing things so i took off the top, the fan on the motor turns freely when its not...
Steven, I thoroughly enjoyed your thorough explanation of what and how it e. Really, the best I have ever read, so far.
What may have happened it that the fan sensor may need readjusting or resetting. In case you have misplaced your Owners Manual, I have included a link to it that you can download and print for future reference. Pay particular attention to Pages 6 & 7, as well as the Troubleshoot Guide. If all else fails, get a bigger hammer! Just kidding. If you find you need any replacement parts, you can order them directly for www.masterdistributors.com
Owners Manual link below.
http://www.desatech.com/manuals/Construction%20Heaters/102439-01.pdf
Hope this helps you solve the problem.
Apr 09, 2011 | Reddy Heater-30-55,000 BTU Variable
Coleman RV Roof AC Fan Issues
It sounds like you have a bad fan capacitor.
You might try replacing it, they don't cost very much.
Sep 22, 2009 | Dometic Rooftop RV Air Conditioner
Air condtioning unit outside fan will not move
Sounds like the motor start capacitor is gone south on you. you can get them at a motor rebuilder.
Jul 12, 2009 | Coleman Propane Forced Air Heater...
Ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Jun 26, 2009 | Carrier Heating & Cooling
Tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint NWXR473EV Dryer
Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat Logo
244 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
