Question about Refrigerators
How to defrost / deice matsui freezer
My matsui muf988s freezer is not frost free. I was wandering how to defrost it. Do i simply unplug it to defrost or there is a special way to do it.
KOakaKO
  • 135 Answers
SOURCE: Fridge Smell
Wash it out with bleach. Nearly always solves this problem.
Posted on Aug 02, 2007
SOURCE: Freezer alarm keeps going off..
Mate prehaps the defrost element could be burntout thus no auto defrost and the big freeze and the alarm, when you switch off the defrost starts and the alarm resets?
Posted on May 03, 2008
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
Maytag317
  • 1136 Answers
SOURCE: frost build-up freezer back wall
Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 24, 2009
SOURCE: hotpoint frost free ff200e flashing lights and
Make sure fridge OFF freezer OFF ... then turn mains on. ONLY turn freezer to max, after 30mins put fridge to 1care ... this should overcome the problem of the flashing lights. When both nice and cool turn settings down. it worked for me
Posted on Sep 27, 2009
Freezer ices up on back wall and dosen't stay cold .stops making ice and refrigerator starts to warm up. If I unplug deice unit it works fine for two or thee months befor it freezes back up and...
If your unit is frost free, then you have a defrost circuit failure, which is made up of the defrost heater, defrost thermostat and defrost timer. The defrost heater and defrost thermostat are located in the freezer compartment next to the evaporator coil and can be checked with an ohmmeter (anything except an open is good). The defrost timer is usually located in the free food side or in the compressor compartment.
Suggest you go to the www.searspartsdirect.com website and insert the model number off the equipment id tag on your unit and find the parts.
Aug 16, 2011 | Refrigerators
Excessive frost- maybe door won't close well Builds up on to shelves the worst--could it be the rubber seal
First you must fully defrost your freezer. Frost simply attracts more frost. A build up of frost large enough to prevent the door closing properly will grow very rapidly indeed and waste a lot of electricity; it will also overload the compressor and can cause it to fail prematurely.
If the seal is damaged then it will allow moist air in and cause frost. If the seal has simply become unseated, then refitting it will prevent a recurrence.
Unless you have a frost-free model, then all freezers eventually need defrosting. You can slow the process by never opening the freezer door unnecessarily and also by never leaving it open any longer than necessary. Frost free models rely on air circulation via a fan to prevent frost build up. If the fan fails, or if the freezer is overloaded and so preventing air circulation then it will still frost up.
Please take a brief moment to rate my answer.
Sep 12, 2010 | Canon PowerShot S1 IS Digital Camera
RFA52 upright fridge freezer keeps frosting up.what is the 'normal' setting for the freezer 0 or 1?
Setting should be midrange. If the freezer is frosting on the back panel you have a defrost problem. The coils will be iced over and the unit will slow down on it's cooling. If there is frost you will need to deice the coils by removing the frezzer back wall panel and use a hair dryer to melt all of the ice. The problem causer of all this will be either the defrost timer, defrost t-stat or defrost heater. Good luck.
Feb 28, 2010 | Freezers
My father has an Electrlux ER 78311 fridge/freezer. It started icing up inside fridge and top of freezer. After we deiced it, it stopped working altogether. Still makes a noise as though it's working....
Did you deice totally or just the ice you saw. To properly deice the freezer section you have to remove the panel on the back of the freezer section and using a hair dryer remove all frost build up on the evap. coils. The most common cause of this problem in these models is the defrost t-stat going bad. Install a new defrost t-stat located on the coils and you will be good to go again. Hope this helps.
Feb 03, 2010 | Electrolux Refrigerators
Coils inside freezer keep icing up.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model of fridge)
Aug 08, 2009 | Refrigerators
Is there a way to disable the frost-free feature on amana freezer
If you disable the frost free feature you will have to defrost every 10 days.
But, yes,it can be done.
Aug 05, 2009 | Kenmore 53542 / 53544 Side by Side...
Divider between fridge and freezer is heating up a lot.
Between the freezer and fresh food compartment is where the evaporator coils are. Frost free refrigerators aren't really frost free at all. Every 12 hours or 24 hours, a timer turns on a set of heating coils in the evaporator to melt the ice on them. If your refrigerator is otherwise functioning normally (normal cooling), it could be that you simply felt the divider it when the unit was self-defrosting.
Most refrigerators go through the defrost cycle unnoticed. When the cycle starts depends on when you plug in or turn on the refrigerator. If you'd prefer to change the time of your defrost cycle, simply unplug the refrigerator for an hour or two then plug it back in. Every hour it's unplugged will delay the defrost cycle one hour. To avoid having to remove food from the refrigerator, you might want to do this over several days, but it's cumulative so each time you unplug it for whatever length of time, it further delays the defrost cycle that length of time.
Your refrigerator has no idea what time it is (unless it's an electronic model with a built-in clock), so setting its timer to self-defrost in the middle of the night is an exercise in trial-and-error.
The other alternative... That the heater is turned on all the time... Would DEFINITELY affect the cooling capacity of the refrigerator and you'd notice that WAY before you'd notice the heat coming from the freezer/refrigerator compartment wall.
Jun 27, 2009 | Kenmore Refrigerators
Water leaking inside of the fridge from the top
It sounds like your frost-free freezer is cycling through its normal defrost mode, which allows the cooling assy. to be deiced and that melted ice (water) will run out and down to the drain in the bottom of your fridge.
Aduz
Mar 27, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Freezer has frost in back- frig not coolling
You have a defrost parts issue.
Unplug the fridge. Remove the back freezer panel and check the defrost heater and defrost thermostat.
Without a model number I can not tell you where the defrost timer is.
Mar 04, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
