Question about Intel Computers & Internet
I purchased a new Intel D865G5A motherboard and a refurbished CPU for it. also i have a NEW WD IDE hardrive. all i have in it otherwise is a network card, & SATA DVD-ROM. I am running WIN XP PRO t
I am rebuilding an old computer. i didnt have this error code before changing out the motherboard and CPU
  • Debbie Daniel Jan 20, 2013
    I was able to find fix. i went into the BIOS and changed a few settings. not sure which one did it but..i think it was the change i made to the (hardrive) drive configuration. switched from auto to IDE or legacy..one of... if i remember correctly. i need to go look. LOL
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intel Master
  • 2,226 Answers
Take out the cmos battery wait 1 min then put it back then restart
Posted on May 26, 2014
SOURCE: Dell Motherboard E210882 Rev 00
My Dell has a SATA hard drive and the E210882 motherboard. Hope this helps.
Posted on Mar 30, 2008
leecom72
  • 4806 Answers
SOURCE: Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Posted on Feb 09, 2009
  • 37 Answers
SOURCE: 945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Posted on Feb 26, 2009
  • 156 Answers
SOURCE: SATA DVD drive not found in BIOS
If the drive is not detected in the BIOS the problem is mostly with your drive. Try connecting to the other slot where the HDD is connected if problem persists replace your drive
Posted on Dec 04, 2009
SOURCE: Problem: Windows xp Sp2 or 3 installation
I HAVE THE SAME PROBLEM, AND I RESOLVE IT CHANGIN A BULGING CAPACITOR NEAR THE PROCESSOR
Posted on Feb 11, 2011
Can't get my system to boot up
The power mapping grid on the motherboard may be defective
Sep 15, 2012 | ASUS P8Z77 WS Z77 LGA 1155 ATX Intel...
Looking to get new mother board because it went on fire, old mother bd was asus P5VD1-X HAVE INTERL P-4 CHIP AND DDR 400 MEMORY THAT I WOULD LIKE TO KEEP USING WHAT MOTHER BOARD DO YOU SUGGEST
Better to purchase new mobo, cpu n memory. Bcoz the compatible Motherboard for your CPU/Memory is no longer available. If it is available, only from the dead stock or refurbished. Better to purchase new motherboard/cpu/memory
Sep 17, 2010 | VIA Asus P5VD1-X PT880 Ultra Chipset 1066...
Intel 865GSA
Looking at the vendors I buy parts from, all the cards I saw offer both SATA and IDE ports. Here's one as an example. You definitely want SATA capability as most newer drives are only being offered as SATA, so you'll have a wider selection to choose from.
Another possibility: start fresh with a new system board. If the onboard IDE controller isn't working properly, this may be a warning sign that other problems follow. You might be better off spending your money on a new mobo that already supports IDE and SATA.
Hope this helps you make up your mind. Thanks for using Fixya!
Feb 20, 2010 | Intel 865G Motherboard
Display not comming ,even I discconect hardrive , only for 2min. display come and then gone ...my board and ram is new just replace my cpu from old baord to new gigabayte g31 board..plz tell me i m very...
Disconnecting the hard drive will not influence the system's graphics. If the display turns on, then abrubtly turns off when you power on the machine, check to make sure the CPU is good, if it is a known working CPU, and the CPU is suppoted by your PC, you may need to reset the bios to default* Then boot the PC, and if it functions, enter bios, and set the settings as needed.
*there's usually a jumper, check your motherboard documentation
Nov 03, 2009 | Gigabyte Matx Intel G31 775 DDR2-800...
Hi guys, I'm new in this forum and I really need some help. I have a p4vmm2 motherboard with Intel Celeron 2.0 Ghz CPU and I want to upgrade it with Intel Pentium 2.4 CPU motherboard. I have already tried...
Whenever you try to upgrade motherboard and CPU's with Windows XP, you're probably going to have to format your drive and re-install XP. When you originally install XP it detects the motherboard and IDE controlers for your hard drives and installs the drivers needed but it doesn't install all drivers for motherborads and IDE controlers. When you swap out motherboards and the system tries to fire it doesn't have drivers available for the new motherboard and can't complete the boot into windows. Every once in a while you get luck and the new and old motherboard can use the same drivers but this is very rare. So when upgrading motherboards plan on backing up your hard drive of all files you need to keep and being prepared to format and re-install windows.
May 15, 2009 | EliteGroup P4VMM2 V8.1 Motherboard
Computer problems
it sounds more of some legal issue than a technical one.. ask someone in that field..don't waste my time.
Aug 22, 2008 | Intel Motherboard
Re:No POST.
http://www.intel.com/support/motherboards/desktop/d915pdt/sb/cs-026985.htm
This is Intel's website for this motherboard, which lists which CPUs are compatible.
Feb 02, 2008 | Intel Pentium 4 541, 3.2 GHz...
Motherboard is not seeing the HD
generally its not a good idea to run both ide and sata drive at the same time.
if you are lucky in your bios it will have a emulate sata as pata/ide drives.
turn this on and be sure to select the ide drive with the OS on it as the master drive so it boots first.
also if you are doing this you will also need to change the jumpers on the sata drive as well to make it a slave and not a master otherwise you will have two master drives and it won't boot.
good luck
smeags
Jan 09, 2008 | Intel D865GBF Motherboard
Installing an old hardrive to a new computer
depending on the BIOS type, there must be a method to disable IDE-0 from booting. If no method found, try booting from floppy disc and then run setup.exe from CD. Try to find this in the BIOS settings, then enable it again after you have fixed the Windows.
Nov 25, 2007 | PC Chips (M791G) Motherboard
No booting (Smthing I never seen)
is the power supply good enough? a P4 certified? You need at least a 400W, better anything higher for a decent machine today. Low quality PSUs do that, just will not turn on. (assuming all the rest is set and connected properly as u said, otherwise there is a trilion other possibilities, like wrong cpu type, an onboard VGA card as default, CPU power cable not connected, graphics card not seated properly, IDE cable in wrong position, etc...)
Jan 21, 2007 | Intel Motherboard
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
