Question about Hardware & Accessories
I have had a grasslin ecosave fitted about 3 months ago and not had any problems. However for the last 3 days the timer is stopping just before the off peak timer clicks on. It still makes a clicking noise but the timer doesn't rotate. I've tried changing the little push pins but it always gets stuck just before it would turn on. The boiler works fine and the boost works fine, it's just the rotating timer. Any ideas let me know
Buffalo12980
  • 625 Answers
SOURCE: Fan makes clicking noise when oscillating
inside the motor there is a nylon gear that is broken. the oscillation operates off a gear connected to the motor drive.
Posted on Aug 31, 2007
the dr
  • 447 Answers
SOURCE: Kenmore 106.53603202 stopped cooling making a clicking sound
The compressor may not have to be changed it could be the relay that is bad, not properly starting the compressor. The relay is attached to the compressor where the wires go to it. Remove it, Shake it, If it sounds like little rocks are inside (it rattles) than it is bad. Let me know what you find
Posted on Jan 05, 2008
SOURCE: Gilmour 9400 water timer won't turn on
Well, I have the same problem. In fact, I just took mine apart (look for 4 screws on the back gray plastic) and found that the gears are stripped. About 3 of the teeth are broke off. I've been looking for parts on the Internet, but no luck yet. I'm afraid the only solution is to purchase a new timer.
Posted on Jul 11, 2009
  • 112 Answers
SOURCE: Timer just stopped working on my ML121RT. When I
this could be a fix or just a way to find out if its bad or not. check to see if the wheel is in the neutral position, some of them u pull out to disengage from the motor and gears so u can turn it manually. if this is the case then just put it back in gear.
if thats not the problem then i would think that the motor is burned up that is turning it. if the motor works and the wheel doesn't turn then the gears r probly stripped.
Posted on Aug 10, 2009
smarthome2
  • 1114 Answers
SOURCE: Broken carouself? Can't properly open, close, rotate, etc.
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Posted on Nov 19, 2009
DO YOU HAVE A BATTERY BACK UP TIMER PLUG IN .iF SO HOW LONG DOES THE ATTERY LAST BEFORE RECHARGE
KM series timer is not battery operated
http://waterheatertimer.org/Programmable.html#KM
Other timers have a back up battery that lasts a few hours or days.
Other timer have super capacitor backup that lasts week or more.
Some timers are powered by the battery, and battery lasts 1-3 years.
The product manual should have some information.
Jul 04, 2014 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Grasslin Intermatic pool timer turns on and off randomly
did you change the base out or just the clock?? it could be shorting out threw the base
May 29, 2014 | Intermatic Grasslin Pool Time Clock 24hr...
Grasslin ecosave timer not working
Add a comment and say if the timer worked before and stopped working, or if this is new installation that does not work correctly.
Otherwise the timer expert is guess that the problem is incorrect wiring, defective timer, tripped circuit breaker, or if the clock motor has gotten weak over time, and stopped working.
Or, Contact Grasslin UK:
http://www.grasslin-controls.co.uk/ecosave.html
Aug 25, 2012 | Hardware & Accessories
For a church HVAC ysem, we need detailed instructions on programming a Grasslin 2 channel, 7 day, 24 hour digital clock. Ned Spencer Programming the Grasslin is a tough job. Together with an...
Open following link to identify timer module:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#GM40AVE
Link for FMD 2-channel Intermatic timer
http://waterheatertimer.org/pdf/fmd-50-setpoint-programming-guide.pdf
1-channel FMD Intermatic timer
http://waterheatertimer.org/pdf/GM40AVE-digital-timer-programming.pdf
FMD timers are complex to program, and if timer does not program correctly, then check voltage and polarity of circuit. These timers typically have 1 year limited warranty and can be affected by power surge.
If you have 2-channel timer, then each contact on relay will turn on-and-off at different schedules.
Make sure you don't wire both legs of a 240Volt circuit to to different relays, or the circuit will not turn on-off as expected. To control 240V, just turn off one leg using one of the relays.
If your exact timer does not show, add a comment and describe everything about the timer buttons and appearance, and I will search my files for possible manual.
Grasslin timers were made by GE for many years, and now Intermatic owns the product line.
Jul 11, 2011 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
My Grasslin Digi 20E-120 timer will not set time or timer. The 1-7 numbers blink. What does this mean?
Digi 20E-120 is 16Amp 120Volt flush mount digital timer with 20 or 140 programs per week.
Grasslin Digi (digi tal/ digital) can be reset using reset button.
Reset might restore functionality, but will delete all programming.
Check that circuit is delivering 120Volt and that circuit is clean without interference.
Also check electrical terminals fit tight on the timer.
Use needle nose pliers and pull terminals off and then push back.
The digi series has 5-day program back-up capacitor so programs should remain, but capacitors go bad.
Power surge can blow out timers. Use surge protection on all circuits.
There are a many Digi timers from years of manufacture by GE and now Intermatic, since Intermatic bought Grasslin from GE.
The digi can be replaced with simple-to--program FM1D digital timer.
Replacement crossover is FM1D20E-120
Open following link for FM1D manual and Digi manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#FM1D
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 18, 2011 | Water Heaters
I have pressed reset on my grasslin qe1 timer and now nothing will work on it
Grasslin qe1 and qe2 manual does not show troubleshoot section.
http://www.grasslin-controls.co.uk/assets/graphics/static/QE1-QE2_GB%20instructions.pdf
1) Remove power to unit and see if it will reset.
2) Press reset and hold button longer
3) Manual says: SLIDE SWITCH MUST ALWAYS BE LEFT IN "RUN PRESET PROGRAMME" OR, "RUN OWN PROGRAMME" POSITION, OTHERWISE THE CLOCK WILL NOT RUN, AND NO SWITCHING WILL OCCUR.
4) Timer has stopped working. I test timers, and they all stop working one day.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 04, 2011 | Hardware & Accessories
I have lost the instructions for my boiler and I have seen that the timer is a Grassling timer, i don't know when it is on or off, it might not even work as the radiators seem to stay hot whatevr I do.
Without knowing which Grasslin timer you have, I cannot offer specific instructions:
Find Grasslin timers and manuals at following link:
http://www.intermatic.com/products/grasslin.aspx
I am familiar with Grasslin timers, and you can add a comment with specific question and I will respond.
Mar 02, 2011 | Intermatic Hardware & Accessories
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
