Question about HP Officejet 4315v All-In-One InkJet Printer
Printer Wont Turn On Officejet 4315 all in one
Printer won't turn on at all, i've unplugged it and plugged it back in and still nothing...Is it possible that the power cord may have been burnt out? If so how would I know?
    Scholar:
  • 97 Answers
Please follow the follwoing steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to
printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and
then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Posted on Jan 29, 2009
Hp officejet 6110 all-in-one printer -- Getting error message "Press Enter to align cartridge." We've had this error before and did as instructed and it's corrected itself. However,...
turn off the printer
remove the cartidges.
Take a damp paper towel and clean the contacts of the cartridges and also the contact inside the holder of the cartridges.
put back the cartridges.
Print a self test
Also clear the the printer memory
Jul 25, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I have a HP 4315 officejet all in one and it prints fine...but when i try to fax a page it fails every time...why?
Good Day Sir, I have a solution to your problem, hope this will help you.
"HP 4315 officejet fax failed"
solution:
  • Turn off the machine by using the ON button and then unplug the power cord from the back of the machine. After a few seconds, plug the power cord back in and turn the power on.
  • Try to send or receive a test fax.
  • If you are running the test from the Fax Setup Wizard (windows) or Fax Setup Utility(Mac), Make sure the Machine is not busy completing another task, such as receiving a fax or making a copy. Check the display for a message indicating that the machine is busy.If it is busy, wait until it is finished and in the idle state.
  • Make sure you use the phone cord that came with the machine. If you do not use the supplied phone cord to connect from the telephone wall jack to the HP All-in-One, YOU MIGHT NOT BE ABLE TO SEND OR RECEIVE faxes. then after you plug run the test again.
  • If you are using a PHONE SPLITTER, this can cause faxing problems. connect the machine directly to the telephone wall jack.
run the test again to make sure it passes and the machine is ready for faxing.
Goodluck and God bless.
May 22, 2010 | HP Officejet 4315 All-in-One Printer
My hp officejet printer 4315 wont print
Good day Sir, the onscreen help provides troubleshooting topics to assist you in resolving any issues you might encounter with the HP All-in-One. In the HP Solution Center, click tab for Hp all in one. In the device support area, click onscreen guide or troubleshooting.
have a nice day. hope this will help you.
May 19, 2010 | HP Officejet 4315 All-in-One Printer
I have a new computer w/ Windows 7 -- and my OJ 4315 won't connect. Except it did! Long enough to print one page. now it says can't find the driver. What should I do? I have rebooted, unplugged,...
Unplug the printer.
You should Open Devices and Printers. Then remove the printer. Then open Device Manager and remove the USB connection for the device. Use the "Show Hidden devices"option from the menu. Remove any USB connections that show up there with an exclamation point.
Reboot.
Plug in the printer.
Check to see if you can see a valid connection to this printer.
Mar 17, 2010 | HP OfficeJet 4315 All-In-One InkJet...
My hp 4315 all in one printer wont turn on
hold the ink for a while, then buy a new printer, maybe the ink wont be all dried up
Dec 07, 2009 | HP Officejet 4315v All-In-One InkJet...
How do i download the hp officejet 4315 all in one in my new computer when i lost the installation cd?
HP Officejet 4315 printer unplugged from your computer. (Via the USB cable)
Printer off, and unplugged from the surge protector.
Go to HP Support. On this page,
1.Type - Officejet 4315 in the search box, (for product:___________)
2.Click on the double Side Arrow to the right of the search box.
3.On the main page for the HP Officejet 4315 All-In-One Printer, click on Software and Driver Downloads. (Middle column)
4.Now choose your Operating System on the next page. I'm going to choose Windows XP as an example.
5.On the Select software and drivers page, go down to the first heading - Driver
Click on - HP Photosmart Full Feature Software and Drivers
After you click on the above, you will be taken to another page. It may look like it's starting to get complicated, but it's not.
Click on the blue rectangle with Download Only>>
in it.
A small window will pop-up to the top right. Click on - Save File.
The file will now start downloading to your computer. Let it download all the way. (I have a medium speed DSL connection, and the download box indicates 30 minutes! Just have to be patient I guess!)
Where will this file go?
Unless you have your downloads set to save to your My Documents folder, (Documents for Vista), this file will go to your desktop screen.
In either place when you see it, Double-Click on it.
The Installation Wizard will now come up, and guide you with simple instructions.
It will put the file in the proper place, so there is no reason to guess. Just click on I Agree, (If stated), Next, Next again, and Finish.
After you click on Finish you are done installing. If you are asked to Restart your computer, do so.
If not, do so anyway.
After your computer has FULLY restarted, and Windows is running, (Assuming we are referring to Windows here), plug the USB cable from the printer into the computer.
Plug the printer into the surge protector. Turn the printer on.
You should get a pop-up out of your system tray, (Bottom of monitor screen)
"Found New Hardware", and perhaps another pop-up,
"Found Officejet 4315"
Now just go to Start>All Programs>HP>HP Officejet
Sep 24, 2009 | HP Officejet 4315v All-In-One InkJet...
Officejet 6310 won't turn on.
Ok try unplugging the printer for about 15 minutes and plug it back in that will reset the printer and it should work fine.
Let me know how it works out
Dec 24, 2008 | HP Officejet 6310 All-In-One InkJet...
Cartridge error
try to put off the cartridge and then turn off the printer. Rest it for 15 minutes, then turn it on put the cartridge back again. If still didn't work out if you have spare cartridges try replacing it. Okay...
Dec 14, 2008 | HP Officejet 4315 All-in-One Printer
HP Officejet 4315v All-In-One InkJet Printer Logo
Ben Johnson
