My washer WA7584c1 is realising water when its on a processes of wahing?
  • Washing Mach... Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Posted on Jan 19, 2013
Have just purchased eco bubble wahing machine from good guys at gepps cross and would like to read user manual online?
I'm surprised one wasn't supplied with the washer!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 15, 2011 | Washing Machines
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
All of my washing machine's "FUnction" buttons do
Change the program controler unit /the board if you need to get access to all the programs.
Remove the controller unit and make sure that the connectors are tight. Make sure the water level sensors , the door switch is working.
If there is no result the program controller is a suspect.
Jan 21, 2011 | Samsung SW62ASP Top Load Washer
I have a centenial wahing machine that will not fill with water.
check that there is good water flow to the washer, if yes , then it is the selonoid valve on the washer, located inside where the water hoses come in
Oct 20, 2010 | Maytag Washing Machines
HE5 Washer. Water in tub all the time.
your water solenoid is probably not closing completely and letting water by pass. Not sure what your model number is but you can find this part and others at www.Repairclinic.com Good luck.
Apr 20, 2009 | Kenmore HE5
F-01
i went on to the hotpoint website which told me what was wrong
Sep 19, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Water supply
yes it is normal. It fills up during the washing proces
I had the same thought at first but it truns out ok.
Jun 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Wahing machine kitchenaid won't completely drain water
Check drain pump for any blockage.Pump accessible by removing lower panel,on bottom front of machine.Also try liquid instead of wash powder,and make sure that you are using automatic powder as other will foam in machine.
Apr 01, 2008 | Indesit W 123 Front Load Washer
Leaking water
Maybe it leaks from te heating element. Happends often on older Candy machines!
Jan 22, 2008 | Candy AQ130 Front Load Washer
Wahing mahine
Suspect water valve is faulty and possible a faulty lid switch.
Dec 13, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
