Question about GE CORDLESS PHONE FOR SKYPE AND LANDLINE
Ge skype phone model 31599 is not geting charged
The phone was not used for 20 days. the battery got discharged and not geting charged at all.
3 Suggested Answers
SOURCE: display says searching,wont stay charged for more than 20 min.
Unplug the power cord of the phone and plug it in another electric outlet.
Posted on May 24, 2008
SOURCE: walmart ge phonw
Very likely your voucher has expired check the dates on it...
Posted on Apr 19, 2009
Hi have a sanyo x1200 camera havent used it for a few months but fully charged the battery before went to swutch it on but will not switch on???
HERE'S THE ANSWER TO YOUR PROBLEM:
Naturally, for some battery brands and models, recharging happens quiet often since some batteries have shorter capacity to sore current. Some are also designed for a longer time of use. But, here are tips on hoe to prolong the life of your battery:
  • Do not use Super Heavy Duty and other low capacity batteries in high drain devices such as digital cameras.
  • Store batteries in a dry, cool place and avoid heat situations.
  • Fully discharge batteries before charging. This is particularly true for Nickel Cadmium batteries which have a memory effect.
  • Store Lithium batteries (such as the Lithium P7) between 20¡ãC and 25¡ãC (68¡ãF and 77¡ãF) with 30% to 50% charge.
  • Remove the battery if the device is not used for several days or if the device will be plugged into AC continuously.
  • Rechargeable batteries should be fully discharged and charged at least once every 3 months.
Thanks. I hope it helps...
Jul 04, 2011 | Cameras
Am using sony ericssion mobile model no. is w760a AT&T, from last two day am connecting charger, but its charging asusally, after i disconnect charger is showing battery empty..
Ifthe sell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 24, 2011 | AT&T Cell Phones
I have a new AS280 Duo which I charged-up and now it tells me to discharge it - run down the batteries. This is taking days and days ..... why can i not use this phone (urgently needed) now?
However, when the battery is discharged in a shorter time a derating factor has to be ... Failure to replace the whole bank could result in the new battery not being charged ... That means less down time and assured power supply. ... allied small scale industries, run by people with expertise in their own fields. ...
Jun 27, 2010 | AT&T Siemens S46 GSM Cellular Phone
Walmart ge phonw
Mar 17, 2009 | GE Lands Phones
I own aB&D 14.4 Driver drill modelCD140G. Do I have to discharge
Newer rechargable batteries aren't like the older ones back from 5-10 years ago. They do not have a "memory" like old cell phone batteries and cordless tools used to have. So charge it whenever.
Stick it in the charger and when it's charged, the light will stop flashing. Usually takes a few hours for a full charge.
It's not recommended to leave it in the charger for extended periods. Not only does it siphon off your power bill, but it's harder for the battery I believe.
I've had mine for a few years and they done excellent. Just as powerful as the day i bought them.
If they ever do give out, be sure to recycle them, don't throw them away. Lowes and Home Depot have rechargeable battery recycling at the front desks.
Jan 21, 2009 | Black & Decker CDC140ASB 14.4-Volt Compact...
3month old battery does not charge full even after ten /more hrs.
i could charge to full by usv port in 16 hrs. now i do not let discharge more than 20% or chage every 10hrs.
ravi shanker malviya
Jan 18, 2009 | Sony Ericsson P990i Cellular Phone
Battery died and or charging system failure
I think its probably your only choice, NIMH batteries are known to have a very short shelf life if not regular charged / discharged you can get GE cordless batteries here - GE Cordless battery
Jan 10, 2009 | Uniden Cordless Phone
Registering handset
If all else fails, read the instructions.
"4. Place the handset in the base cradle. The charge/in use indicator turns on, verifying the battery is charging. The unit will take 20 seconds to register and verify its security code. READY shows in the handset’s display."
Dec 12, 2008 | GE 25922 Cordless Phone
Battery
Before you change the battery:
  1. Charge the battery fully
  2. Discharge the battery fully
  3. Repeat steps 1 and 2
If the battery does not reset itself and start lasting longer then you do need to replace it.
Jun 26, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Question
yes you can leave it in the charger, how ever its better to let the battery discharge then recharge, on a side note does your phone seem to light up for no apparent reason? at random times? just wondering because mine does :)
Jun 25, 2008 | GE 28111 Cordless Phone
GE CORDLESS PHONE FOR SKYPE AND LANDLINE Logo
362 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
