Question about Clifford 7752X 2-way LC3 SST LCD Replacement Remote
How to replace the battery for Clifford 7752X remote control ?
The remote is still in the good working condition, just only the built-in battery got busted, need to be replaced.
    New Friend:
There is a guy on ebay that is selling them now.
Posted on Apr 05, 2013
I have a clifford arrow 5. It no longer chirps when Iblock it and the blue light syays solid. Last time this happendx it made my battery go dead. Anyone know how to fix this?
Pull the batteries out and let it sit for a few minutes.
replace the batteries.
If that didnt help, than a button may be forced in the pressed position.
You may have to put it apart and see if there is anything lodged in the keypad.
Jan 08, 2015 | Televison & Video
The focus remote will not work I don't know how to operate on on projector
Not all models of projectors have the remote focus built into them. Remote focus is a feature that designed & built into the projector, not the remote. So if the remote has a "Focus" button, it won't work if the projector is not so equipped. If it is the correct projector model and remote combinations, there could still be conditions causing it not to work, such as: projection lens not installed correctly; gear teeth that drive the lens broken off (some or all); electronics that control the remote function; remote not plugged in correctly (a remote will only work if plugged in the correct orientation of the 5-pin plug) and finally the remote control, itself. Lots of variables. Try troubleshooting in the order I have listed. Good luck !! Jim
Nov 06, 2014 | Office Equipment & Supplies
How I can get a service repair business for the diagnosis of a Clifford car alarm system?
First replaced the batteries, you may find a CR2032 in there easy to replace then try before blaming any other components
Aug 03, 2014 | Brand Remote Start/keyless/car Alarm Very...
Lost program
Make sure that the battery is in good working condition and charged before it is totally discharged. If not replace the battery. Unfortunately the program may be lost. Or you could see if it's backed up on Logitech's website. Try updating the remote and see if you can recover that way.
Mar 23, 2014 | Logitech Harmony 650 Remote Control
Clifford remote start problems
clean the contacts battery and measure the battery and if it is low replace. and clean the keypads from dirty, corrosion, oxide, etc. and try again. Clean it contacts cleaner
God bless you
Jul 16, 2013 | Televison & Video
I need a Clifford 50.7x installation manual
go to www. fitnessmanualsonline.com and download for freeGod bless youcreateLink
Dec 14, 2012 | Clifford Matrix 50.7X - Car Alarm with...
Remote locks do not work on a 2003 dodge neon
Either the sensor in the car is busted - in which case see your local Dodge dealer for help - or else you just need to replace the battery in your key/fob remote!
Sep 26, 2012 | 2005 Dodge Neon SXT
RCA #D930 remote control stopped working??
good day
2 common causes of malfunction remote control... first,is low battery or empty...if you have a multimeter tester set it to dc and check the voltage of your battery if it is on empty or low battery condition replace it
and secondly,when the infrared is defective...how can you determine?..if you have any digital cameras get it and point it to the top view of your remote then try to look the infrared bulb (LED)then press any button to activate the remote after look at your camera while pressing the remote if you see infrared lights up for every pressed..your remote is OK..if it is not lights up and your battery is good..replace the infrared to fix your problem
thank you and good luck
Apr 09, 2011 | RCA Televison & Video
It appears it just went dead. Replaced batterys. Lite does not even work
The remote you have is an expensive item to replace so lets try checking a few things first. Open the battery compartment and closely look at the contacts, there should be one at the top and bottom of each battery. If the remote was not used for a long period of time with the batteries still in the remote, then some corrosion may have built up preventing good battery connections... clean the contacts if you suspect this. Hope this works for you.
Feb 28, 2011 | Universal Remote Control MX-350 LCD Remote...
Clifford 7752X 2-way LC3 SST LCD Replacement Remote Logo
321 people viewed this question
Top Clifford Televison & Video Experts
Are you a Clifford Televison and Video Expert? Answer questions, earn points and help others
