Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
The wire holding the door seal gasket came off. I was able to get the wire on and the door closes fine, but the washer does not spin. I have a Bosch 500 series
  • 4 more comments
  • terrapin00 Jan 26, 2009
    My wife says that a pull string from a pair of pants was hanging out of the door. When we opened the door the wire was off. I was able to get this back on.
  • campgreis Jan 26, 2009
    we had a similar issue last week. a shirt sleeve was caught in between the door and the drum. eventually the seal gasket and the sleeve entangled and the whole load created a gigantic knot. after getting the laundry out and getting the gasket and the sleeve seperated i had to 'install' the gasket again and tighten it down with the wire.
    it is relatively easy to tighten down. set the gasket in place, then start setting the wire in at the top, the spring has to face downward (there is a groove at the bottom for the spring), then go half way down on each side of the gasket. a second person now has to ensure that the gasket and wire don't slip up. pull the spring apart and slide the wire over the gasket rand. done.
    however, our washer won't spin anymore right now.
    i have a hard time believing that a technician has to come out (in our case for $ 85) just to diagnose it as this seems to be a common 'safety hazard' with front loading washing machines that something gets caught between door and gasket...
    anyone with any ideas?
    thanks...
  • terrapin00 Feb 02, 2009
    I had this problem. The drive belt had come off. Just take off the bottom panel off the washer, no need to take off the top part and reattach the belt.
  • Anonymous Mar 06, 2009
    My wife opened the door and the wire clamp fell out and the gasket was out of place.
    My wife thinks it was because I overloaded the washer. Not sure if anything was hanging out of the dryer, but one of my t-shirts was twisted into nearly a knot (as if one end got tied or caught in the door and the rest twisted up during the spin cycle.
    Did as the previous poster suggested, working the wire from the top down, with someone (my wife) holding the wire in place near the bottom. What really helped were some small needle nose vice grip pliers to grab one end of the spring while I pulled the spring apart to get the last bit of the wire around the gasket.
  • campgreis May 11, 2010
    hi appldoctom...
    just saw your comment...
    in our case the shirt sleeve entangled itself with the rubber gasket and pulled it off this way. also the load was not evenly balanced anymore as it all became one knot. however the door still locks.
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    for that door boot spring to come off,[i may be wrong with your situation],but the washer would have to go out of balance in a bad way.so if that happened that incident may have damaged the door lock mechanism.because it wont spin if wont lock door
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch 500 series front loader washing machine
Posted on Jul 22, 2013
$ 85 later and it is just the drive belt... 10 screws and you're ready to go... oh, the technician was friendly enough to tell me to run a cycle with vinegar because the washing machine was stinking so bad!
Posted on Feb 02, 2009
I need help replacing the front door gasket and seal
Bosch WFMC3200 Front Load Washer replacing the front door gasket and seal.
This video will show you how to change a door seal on this Bosch front loader washing machine .
we have all
bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 12, 2010 | Bosch WFMC 3200 Front Load Washer
Leaking- could be a hole in door gasket
First step with any leak find out exactly where the water is getting out if possible. You may find a gasket that is not sealing or damaged. Sometimes the door is not closing tightly enough against the gasket and will need to be adjusted. There are a number of other places on this machine that can leak thus the need to know exactly where it is coming from.
Jun 09, 2010 | Bosch Axxis WFL 2060 Front Load Washer
The wire around the rubber seal on my bosch washer
This video will show you how to change a door seal on this Bosch WFMC2100UC washing machine
Jan 01, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Wire off around door
Nexxt 500 WFMC3301 Front Load Washer
This video will show you how to change a door seal on this Bosch front loader washing machine and the best way to get wier back on te door.
we have al bosch repairs in our channel
May 13, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Replace door gasket
It sounds like you have left the spring on the inside lip of the door opening when you removed the old seal,
You will have to take the seal off again and feel for the spring on the lip of the front of the drum, you will find it easier if you have something to hook it out with,it is fiddley, but you must get the spring out, or the seal will not stay on
Refit seal as before, and double it back inside the drum,then fit the spring in the groove that you can feel on the lip of the door seal. Work the spring all the way rond feeding it into the groove as you go round, you will find it a lot easier if you have someone there to hold the spring as you are are fittingit, it is very fiddley, stick with it!!!.
Plz rate this solution .
Thanks.
Dec 19, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
How do I replace my boot gasket on my Bosch Nexxt washer?
Here is how you do it. 1st remove the door & hinge, 2nd remove the covers on the screw where the door sits that holds down the control panel. 3rd remove two screws holding the door latch in place. Remove the spring & wire holding the boot on and pull the boot loose from the plastic holder Remove the plastic boot holder. You will now see the boot where it attaches to the tub. There is a spring and wire that holds that on. At the top there is a tab on the seal, grab it and pull towards you. The boot will come off. To reassemble I remove the counter weights(concrete weights) from the tub and put the boot firmly into the slot on the tub. Now reinstall the rear spring. Be sure to also reinstall the counter weights if removed and torque them tight around 25 to 30 foot pounds. Reassemble the front panel and put the spring retainer back on. Tools needed T20 torx driver, 13mm wrench, and needle nose plyers.
Aug 09, 2008 | Bosch Washing Machines
Replacement door seal/gasket
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Apr 08, 2007 | Bosch Classixx WVF 2402 Front Load...
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
458 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
