Question about Samsung Sew-3034 Smartview Video Baby Monitor With 3.5 Inch Lcd
Battery dieing on samsung sew-3034
My battery keeps dieing after only a few hours, can you replace the battery, we have only had the monitor for about 15 months.
How do I test the battery in Samsung Tab 4 7.0 SM-T31
Most battery apps are garbage. To prolong life turn screen brightness down, close open unused apps and charge with a quality charger if not the oem unit. There really isn't a way to test the battery without removing it.
Oct 09, 2016 | Samsung Tablets & eReaders
Why does My monitor keep going on Auto adjustment every few seconds and the adjust brightness screen also comes on periodically
Monitors do that when there is a stuck button you can try pressing the buttons on it and if that does not help it is a card inside that needs to be replaced.
Regards
Mar 06, 2015 | Samsung SyncMaster 191T 19" Flat Panel LCD...
I have a Samsung baby monitor SEW-3034, it was working pretty ok, but after 2weeks not using, now when I plugged in power and turn on, only beep once and no screen show up, try charge for a long time, but...
You can connect up to 4 cameras and each camera must be paired with the monitor. Sounds like you need to repair the camera so that the monitor will recognize it. Look at the boston of the camera there should be a button to press.try this
Aug 16, 2013 | Baby Gear
Video monitor goes black for a few min. then goes back to working imeditly after. keeps on doing tha over and over.new batteries in camera and both units plugged into outlets that work properly. thank you...
The unit it is dying and might be shorting out.The Unit is under a year old?Yes,take it back where u bought it and exchange it for a new replacement.Not tries take out the unit batteries and unplug the unit about an hour for letting the unit rest and do a resetting itself back to the factory setting.Than put back the batteries back into the unit and plug the unit back in again.These steps will help and might get the unit up and running properly again.
Aug 16, 2011 | Motorola Mobility Mbp35l Digital Video...
My Samsung 731BF Monitor has recently started behaving strangely. It will work fine for hours and hours, but after I leave it alone a while and it enters sleep mode I now have to turn the monitor off and...
The problem is most likely the backlight or the power supply that feeds the backlight. The bulb will be the most common problem and will likely require replacement. For the cost of replacing the bulb, you would be better of replacing the monitor.
Just keep doing your power reset technique and use it till it dies.
Mar 09, 2011 | Samsung SyncMaster 731B 17" LCD Monitor
1998 VT 1100 C Shadow Spirit: brand new battery;died after a few hours of ridein...
Could be, replace or have it tested. My old bike a 1998 VT1100CT had a problem with the starter being weak, like the battery was dying. Turned out to be the battery ground wire bolt, going to the back of the starter. It just had a little rust on it, and the bolt broke when I went to remove it. But once replaced the bike starts great, we replaced the battery, took apart the starter tested everything. All for a slightly rusted bolt not making a good ground... Check your Regulator, and any corrosion around the connections!
May 17, 2010 | 1998 Honda VT 1100 C Shadow Spirit
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
Thanks,
Lee
May 13, 2009 | Casio Exilim EX-S500 Digital Camera
Car dies and battery light comes on.
Will it crank over when it won't start? When It dies check for spark at the sparkplugs if none change the ignition module.
http://www.aceautomotive1.com FaQ and BLOG
Aug 01, 2008 | 1999 Chevrolet Cavalier
Packard bell imedia 3034
After reading a ton of posts you may be correct, your board is dying or is dead.
An easy way to get your data off your old Hd to your new Hd would be to connect it directly into the new PC internally.
Just like you would a new drive only you would set the old drive as a slave. Here is your 3034 link.
http://support.packardbell.com/uk/item/index.php?pn=P842025601&g=1400
The motherboard in this 3034 is Gigabyte, GA-8SIML-NF7, shown at this link: http://support.packardbell.com/uk/item/index.php?i=spec_columbia5p&ppn=P842025601
There is almost no chance of you finding this board its just too old. There are boards at this link that will handel all of your imedia 3034 parts, motherboards.
http://computers.pricegrabber.com/motherboards/p/40/form_keyword=motherboards+478+socket/rd=1/mode=g_us_b_s/skd=1
Hope this helps you Jim!
Please vote...
Jan 18, 2008 | Intel Motherboard
Samsung Sew-3034 Smartview Video Baby Monitor With 3.5 Inch Lcd Logo
79 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
