Question about LG Refrigerators
LG Fridge GN253VW temp lights flashing
Temp control lights flashing, have turned off and on, the lights stay solid for a while then flash, is cool but not cold, freezer is working fine.
SOURCE: Freezer Working, but Fridge side is not cold.
Excuse me, will not cool lower that 45.
Posted on Jan 27, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire phsc239dsb0- temp controls
e-f relates the evaporator fan. lasttime i had that happen it was problem with the mother board located under the refrig, replaced it and all was well
Posted on Mar 17, 2008
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
bobicehouse
  • 1524 Answers
SOURCE: my fridge seems to have stopped cooling;there is condensation on the inside and the temp is lukewarm....however, the freezer is working fine, very cold.
You have a problem with the defrost timer.
Posted on Apr 26, 2009
LG gn253sqa electro cool- temp. control lights in fridge keep flashing and fridge not cooling so good, help?
This has happened to me a couple of times.The problem is that when the fridge door is opened too may times the warm air of summer will block the cold outlets in the fridge with ice.The cold air comes direct from the freezer and the chamber connecting to the fridge clogs up with ice.What one has to do is completely empty the fridge and freezer,leave open both doors so the the ice build-up can melt.Then after about at least 4-5 hours (very important to stick by this time-frame as I tried a less time,but it did not work.),close both the freezer and fridge doors and switch it on.After about 1/2 hour replace your goods in the fridge.The down-side of this is that you will need the kindness of a neighbor or two to use their fridge to store your food whilst this fix is underway..
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator a model ffhs232mwo frigidaire has two temp controls, the freezer is holding a solid number, but the fridge number is flashing 4 any ideas
The Flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection.
So its your air damper that's bad.
Here is the part to order.
Dec 02, 2012 | Refrigerators
My a/c unit won't stay on.
Does your A/C unit have a manual? and can you specify what goes off? does the flashing temperature ever go off? Also do you have any cooling?
Aug 12, 2012 | LG LWHD1500ER Wall/Window Air Conditioner
Turn it on green light comes on beeps 3 times red light comes on then flashes
yeh thats the red ring of death temp solution is turn on wrap in towels so it nice n steamy then after 30 mins put in fridge til chilled or leave to cool it will reset the system only temp prob will come back and will have to be sent off to microsoft hope temp solution keeps ya goin till its sent off
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Mar 17, 2008 | Refrigerators
Refrigerators Logo
223 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
