Question about Sport & Outdoor - Others
After resetting, the Chappee CF7 / 2002 boiler runs for a while, then the control lamp starts flickering before the boiler shuts down.
ginko
  • 19396 Answers
SOURCE: I want to shut the
Do you have a unique timer for the two boilers?
Posted on Sep 11, 2008
jyackle5
  • 8197 Answers
SOURCE: Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Posted on Mar 12, 2009
  • 33 Answers
SOURCE: ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
Posted on Jan 17, 2010
smarthome2
  • 1114 Answers
SOURCE: After lamp replacing on Sanyo PLC-XP46 the
Check the iris door, it opens and closes freely. If dust has clogged it up, it will not stay on. Also check the air filter and the fan, if they are dirty, it will shut down as well. If your manual does not show any diagrams of the unit, post a comment and I will look it up. Hope this helps.
Posted on Jan 11, 2011
HANSGROHE US
  • 7 Answers
SOURCE: Hansgrohe Ecostat (with part 94282000
Check the 94282000 cartridge for debris on the filters. If your boiler requires a certain flow rate to come on, then you must get enough flow through the cartridge to make that happen. Also, if your boiler is producing very hot water, the cartridge will self regulate and reduce the hot flow accordingly. try lowering the output temperature of the boiler to resolve that possibility.
If you need further assistance, you can call us direct at 800-334-0455
Posted on Sep 08, 2011
My boiler keeps getting shut down and the message says "supply too fast". I have to reset the boiler every time that happens. What is wrong?
Either the pump in not running to circulate the heat, or the boiler is going straight into high fire and not modulating correctly.
Jan 06, 2016 | Heating & Cooling
Benq MX761 stays on for only 2 minutes and then shuts down after genuine Benq lamp replacement. Picture flickers colour just before shutdown. Lamp timer has been reset to zero.
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. Check to see if your TV is still under warranty first though.
Nov 29, 2014 | BenQ Projector Lamp for MX760 MX761...
Hansgrohe Ecostat (with part 94282000 thermostat). Shower runs fine for a few minutes then boiler shuts down and shower runs goes cold. Boiler starts up again after 30 seconds and runs fine for a few...
Sep 03, 2011 | Home
The boiler wont fire up and the blue light flashes once per second
Let's see what we can do to trouble-shoot this boiler--
First of all-- Are we talking about a Hot Water 'Boiler'-- In other words does this boiler heat water that circulates thru the house, to keep you warm?
Next-- What is your fuel?
Have you Shut the system down, to reset it?-- What happens when it comes back on again?-- Clicking sounds-- pumps trying to start-- solenoids trying to open, etc.-- Tell us what you observe-- so we can help you trouble shoot this problem.
Mack B
Jan 15, 2011 | Heating & Cooling
I have Crown Tobago boiler that cut off two days ago
Possibly due to a power failure, control unit needs to be reset. Hit reset button. Hold for 30 seconds. Also no fire typically due to nozzle clogged, no fuel which means control will shut down. Water in fuel will also shut boiler down. Clogged filter will decrease fuel flow. Electric eye face is dirty which will also shut it down. If you have a two line system, open up bleeder and see if you get a good flow. Check electrodes for burned ends or out of gap specs.
Aug 04, 2009 | Water Heaters
Mar 12, 2009 | Panasonic PT-AE700U Multimedia Projector
I have a radiant floor heating system with a wirsbo control system, i keep having to reset the system to get the zones to heat up again. The broiler is working fine. The first time I reset the radiant heat...
Is this a water circulating system? If so there are bleeder ports on your radiant heating zones on the floor that you can bleed the air out of the system. They look like a tire air pressure valve. Depress the valve core with a small screwdriver or something of the same nature. You will hear air coming out and water will come out. This is done while system is running. Also it may maybe under pressurized, circulating pump could be shutting down. Does the boiler keep running or shut down on reset. If it does could be within the boiler itself. Please rsvp with more info.
Oct 02, 2008 | Heating & Cooling
Sport & Outdoor - Others Logo
621 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
