Question about Acer TravelMate 529ATX Notebook
My laptop wont turn on!
My acer laptop would turn on but the screen would stay black i need some help my mom took the battery out when the power stayed on so i need help soo much
    Brigadier General:
  • 5,158 Answers
Reboot the battery tapping the F8 key... when the menu pops up use your up and down keys to select last known good configuration.... boot to that... that should fix it up.
Robert
Please take a moment to rate this solution thanks
Posted on Jan 26, 2009
Acer aspire 5155 turns on but wont start
I am guessing that you already removed the battery and re-installed it. IF not, try it.
Good luck
Joe
Jul 15, 2014 | Computers & Internet
I was just using my mom's acer aspire when suddenly a blue screen appeared that stated it was preparing for a crash dump. The computer will turn on and sound like it's starting up, but then it stops and...
from what yu say if i infer correctly then
when powered on the system powers up properly and the HDD and CPU are running fine but there is no display on the screen and is black,
first try the this step, try connecting an external monitor to the VGA port (generally in blue color) and see if you have a Display on the external monitor.
the black screen generally means that either the Display section is not getting power or the invertor board is damaged and this needs professional help in fixing / replacing it.
hope could be of help
Mar 28, 2011 | Acer Computers & Internet
My acer aspire ones screen is just staying black and wont reboot what do i do ?
I have the same problem! I received a response to my email telling me to disconnect adapter and battery, hold the power button 30 minutes, connect ac (make sure it's plugged), turn on, wait 1-7 minutes, then attach battery after windows boots. After several tries, it still hasn't worked. When I turn on the system, my power led stays green, but the hdd indicator is not lit. My battery can still recharge, but the screen is still black, and there is no sound.
Apr 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
It wont stay power up;and screen stays black; and shuts down after a second' please help'''''
try to power drain pc first. to do that, turn pc off, remove battery and ac adapter. press down power button for 15-20 sec, then but all back in and try to turn pc on. if still no go, you may need to replace battery or ac adapter, f it still wont work, possible motherboard replacement is needed.
Mar 29, 2010 | Dell Inspiron 1501 Notebook
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
I was using my one-year-old acer aspire one netbook. i just left it (plugged and all) for less than 5 mins and when i got back, the screen has already turned dead. thinking that it must've went into...
you need a new battery it happened to my mom's desktop and she took it in and they told her to get a new power sorce so you most likley need a new battery
Sep 29, 2009 | Acer Aspire One PC Notebook
Black screen / HD light steady and the fan keeps running
Ok, check your RAM, reseat or clean it with soft eraser, only its edge connector both side. Do this when unit is off and no other power source is connected to it even its battery.
Hope this help.
May 02, 2009 | Acer Aspire 5050-3242 Notebook
Black Screen
look man ACER laptops are the best laptops in the world ! you didn't take care about it ! so don't blame them UNDERSTAND !
Jan 06, 2009 | Acer Aspire 3610 Notebook
Laptop Wont Boot
Does it sound like it's starting up at all? Is the problem that only the screen turns blank? You might have just disabled the standard output. Try pressing Fn (bottom left on the keyboard) and the F5 on the top a few times to see if the screen toggles back on. You might also try to run it without the battery, and on the battery only in case it's a faulty battery or power supply that causes the problem. If not, it sounds lsike a serious problem, so if there is any chance of the waranty still being valid I'd call acer support asap.
Jun 17, 2007 | Acer Aspire 3000 Notebook
Acer TravelMate 529ATX Notebook Logo
90 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
