Question about Pool & Spa
Older spa spa quip sq1500 need replacemnet control box model 2095bb5 and heater element
    New Friend:
These controllers will cut the heater out soon as you turn on the blower or aux, this is to prevent overload of current/controller meltdown.
Posted on Feb 17, 2017
    New Friend:
Can some one help me i have a spa quip sq1500 and my heater light will stay on for say 5 or 10 min but soon as i put jets on again the heater will go off and stay off untill i turn off jets again ????
thanks
Posted on Jul 02, 2013
  • Adam Henshaw
    Adam Henshaw Feb 17, 2017
5 Suggested Answers
  • 128 Answers
SOURCE: i need help with aqualink rs4
The heater is not wired to control panel for automation operation
Posted on Aug 23, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
SOURCE: Spa Quip Err8
An error code will come up if the sensors in the unit detect no water flow, or over temperature. Now this might be the actual problem or the sensors or circuit board may be faulty. First check the pump is circulating the water, if it still errors then the fault is in the electronics.
David. Goulburn Pumps
Posted on Nov 08, 2009
  • 990 Answers
SOURCE: Spa Heater
You need to check your temp sensor and your high limit. Both are tubes that slide into the plumbing on or near your heater. If this is a tube heater then they are probally at on each end of the heater and will have small wires coming from them that go back to the control board. Farely common problem and easy enough to fix with replaceing them both. A number of models wire them together so they come as one part. Good luck.
Posted on Jan 20, 2010
Heat pump does not work
can some one help me i have a spa quip sq1500 and my heater light will stay on for say 5 or 10 min but soon as i put jets on again the heater will go off and stay off untill i turn off jets again ????
thanks
Jun 08, 2013 | Pool & Spa
Spa quip hot tub error code 07 stuck relay
Bad relay on the circuit board will require a new circuit board.
Rod
US Parts Center
Apr 17, 2013 | Pool & Spa
Leisure Bay spa will not heat past 86 degrees. Element and sensors are new. Spa has excellent flow and correct voltage at terminals.
if the spa does not heat up to 104 degrees then the temp sensor is what you are going to need.
Are there error codes showing on the screen of the topside?
You will need to know the model number of the control box or the model number of the heater tube in order to get the proper sensor.
Rod
US Parts Center
888-521-6183
Feb 09, 2013 | Pool & Spa
LocF error on hydroquip 9000 e spa
possible bad pump motor or relay to pump or shorted heater element
Oct 21, 2012 | Hydro Quip Inc Pool & Spa
Hydro-Quip pack in my Hydro-Spa hot tub no heat.
3 Flashing dots (display) - Water flow problem check for closed valves, dirty filters, water level, pump/wet end operation/defective pressure switch.
If your spa has been off for a while its likely something is blocking the lines.
Flashing dots & Lit light on display - Hi-limit trip, reset power to clear.
Nov 16, 2011 | Hydro Quip Inc Pool & Spa
Hi, my Hydroquip powered spa is running continuously but not heating up to the proper temp. All 3 small lights are blinking continuously. I havn't been able to find any trouble shooting info. Thanks for...
Check for power at the wire terminals. If you have power then you probably have a bad element and will need to replace it. If not your temp sensor has probably gone bad.
Nov 27, 2010 | Hydro Quip Inc HEATER ASSEMBLY FOR VERSA...
Spa Quip Err8
May 09, 2009 | Pool & Spa
NO HEAT
heating elements are located in the stainless steel tube attached to the control box. Older models from the early 1990's and 1980's were sometimes housed in a plastic case with a square 5 x 5 plate on the one end.
Jan 17, 2009 | RTO SPA SYSTEM HEATING ELEMENT - HEATER -...
Pool & Spa Logo
1,266 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
