Question about Chevrolet Chevy Silverado Extended Cab
2000 chevy 4 wheel drive has roaring noise on left front what could it be
I hear it better at slower speeds. sounds like its under the driver or left side close to the wheel
  • 4 Answers
I am 99% sure this is your wheel bearing. I've had a roaring noise on two diffrent rigs and it was the wheel bearing,
Posted on Jan 23, 2013
    Sergeant:
  • 248 Answers
Have a visual first up - this sounds like the plastic guard housing scraping on the wheel (this is fairly common) you will see scuffing / wear on the plastic - You can cut off loose plastic and / or replace. I did have a stone caught between my brake pad and and disc once which make a horrendous noise. A visual inspection should lead you in the right direction.
Posted on Jan 19, 2013
What is a roaring loud sound in front of 2000 chevy cavilier
Bad front wheel bearings will make a loud roaring sound, and get louder as time goes by, check this out! God-Bless!
Oct 01, 2017 | Cars & Trucks
Im hearing loud roaring noise from front left wheel while driving in my 2000 nissan sunny
It's a noisy wheel bearing and is usually relatively cheap to fix, but not a DIY job unless you have experience.
You need to get it fixed without delay, left to it's own devices it will cause more damage and in extreme cases can cause the wheel to break away.
Mar 15, 2010 | 2000 Nissan Altima
Clunk noise from front passenger side when
That noise sounds to me like a Ball Joint problem. I would check to see if you have fittings to grease the front suspention.
Good luck, Allen
Oct 04, 2009 | 2005 Nissan Sentra
A friend has a 2000 chevy malibu. when driving at
Well, that depends, do you have front-wheel drive or rear wheel drive? With front wheel drive, you most likely have a CV joint problem on the drive axle. The best way to find out how to do ANY repair to any make or model car is to buy (or borrow) a chilton or hanes manual from an auto parts store (or library). They are not very expensive and save you tons of money, by helping you fix the most common, and many uncommon problems, step-by-step.
Oct 02, 2009 | 2000 Chevrolet Malibu
Wheel noise or roar in front end with increased road speed
THIS NOISE IS USUALLY THE HUB. HAVE SOMEONE GO WITH YOU ON A TEST DRIVE. GET THE ROARING TO HAPPEN AT ITS LOUDEST AND GENTLY SWERVE THE CAR LEFT AND RIGHT. DON'T BE SURPRISED IF YOU THINK BOTH HUBS ARE BAD. LIFT THE FRONT OF THE CAR AND PUT IT ON JACK STANDS. PULL OUTWARD ON THE BOTTOM OF THE TIRE WHILE PUSHING INWARD ON THE TOP OF THE WHEEL. IF THE WHEEL MOVES EXCESSIVELY YOU FOUND THE HUB THAT IS NOISY. USING A MECHANICS STETHOSCOPE YOU CAN SOMETIMES HEAR A ROARING TYPE NOISE ON THE BACKING PLATE SIDE OF THE HUB WITH THE ENGINE RUNNING AND THE TRANS IN GEAR. TRY NOT TO GET THE SPEED UP TOO FAR ESPECIALLY IF YOU CAN HEAR THE NOISE AT LOW SPEED, YOU DON'T WANT TO VIBRATE OFF THE STANDS.
Jun 15, 2009 | 2000 Buick LeSabre
Loud roaring noise in front of dodge stratus ES 2000
i have a 2000 doge straus and i put two sensors in and it still wont shift any ideas out ther it was fine when parked a year ago so i know the tranaxle is good
Apr 09, 2009 | 2001 Dodge Stratus
Front End Problems
first i would check the tires , are they cupped or chopped on the tread? run your hand over the tread and see if it feels rough and uneven. take the truck to a auto repair shop and have them jack both front and rear axles off the ground, put the truck in 2 wheel drive and run the speedometer to the speed you usually hear the roaring noise, if you don't hear the noise , put the truck in 4 wheel drive, turn off the traction assist if it has one and run it to the speed you would hear the noise. if you hear the roaring noise with tires off the ground, the problem is in the drivetrain, (engine, transmission, transfer case, u-joints, differentials or the front left or right cv halfshafts or u-joints). the older models (97 98) had the front two driveshafts from the differential turning all the time, they engaged in 4 wheel drive from the transfer case and a solenoid on the front differential. depending on the miles you have on this truck, the most likely areas i would look at would be the tires, u-joints/cv joints, and front and rear wheel bearings. thanks and good luck.
Oct 04, 2008 | 2004 Dodge Ram
2001 LINCOLN CONTINENTAL ROAR WHEN ACCELERATING
Same problem with an LS...wheel bearings. Comes in the whole hub assembly. Just had it fixed for $340.
Jun 14, 2008 | 2001 Lincoln Continental
Chevrolet Chevy Silverado Extended Cab Logo
61 people viewed this question
Top Chevrolet Toys Experts
Electric Dime
Electric Dime
Maxumized
jogp98
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
