Question about Archos ARNOVA 7b G3
How to put arnova 7 g3 in recovery mode - Archos ARNOVA 7b G3
Make sure the tablet is off, then push and hold the reset button(small hole on same side as power button), while holding the reset down push and hold the power button. continue holding both buttons until you see the "Arnova" flash screen, then release the two buttons. this should put you in recovery/download mode... it is not touch enabled though, and there are no physical buttons on the tablet, so you will most likely need the Rockchip flashing tool. Good luck
Posted on Jan 19, 2015
My Arnova 10b g3 tablet won't turn on at all. What could be the problem.
If it is fully charged you need to hold the on button at same time as up volume to reset it..If that doesn't work .It will need a new battrey
Nov 29, 2014 | ARNOVA Tablets & eReaders
Why does my tablet say "cannot connect to camera"?
You should be able to go to the website of the camera for a software patch.
Jul 02, 2014 | Archos Arnova 7 G3 Tablet
Arnova 7k g3 wont charge
You probably destroyed the port plate of the charger. You should check if it is bent or dented and if they are the price to get it fixed is $50-$150
Jan 20, 2014 | Archos Arnova 7 G3 Tablet
I forgot my password in arnova 7bg3 how can i open it??
Well you cant, you will need to do a factory reset, when the device is of hold down the power button and volume up and it should bring you to a recovery menu where you can factory reset it and get rid of the password
Thanks
Aug 06, 2013 | Archos ARNOVA 7b G3
Arnova 10 g3 won't turn on
i see that you are using a universal power adapter, do you have the voltage set to the proper voltage that the unit requires?
I have one of those radioshack universal power adapters.
Based on the fact that it says that it can charge via USB, you would need to have it set to 5 volts. if you have it set to anything different, you are risking damaging the unit.
Try a different power adapter as an alternate step. If that doesnt work, come back and I will try to help you further.
Feb 27, 2013 | Tablets & eReaders
Arnova locked
wachtwoord forgotten
Nov 12, 2012 | Archos ARNOVA 7b G3
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Archos ARNOVA 7b G3 Logo
749 people viewed this question
Top Archos Tablets & eReaders Experts
Joseph Prosser
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
