Question about Saeco Royal Professional Espresso Machine
Machine will not grind beans.
Last week while making coffee the machine ran out of beans whilegrinding beans. Since then the machine will not grind the beans in the bean container and shows there are no beans on the display.
  • 3 more comments
  • nelso Dec 25, 2007
    hi there,
    i bumped the machine and a small amount of water went into the bean holder, it was only a tiny amount. we have cleaned out the bin the best we can as well as using a hair dryer to take any moisture out.the display still reads  ( cof. beans empty). the machine tries to grind bu nothing happens.it would be great if someone could help
    thanks
  • Nina Scheller Dec 25, 2007
    Our machine will not grind, either. We took the advice to clean the grinder, put everything back together, and...... nothing. We get the "Cof Bean Empty" reply, even though there are plenty of beans. What comes after the grinding? What's the next step that the machine expects to take? Is there anywhere online that I can find a repair manual, not the users manual?
  • Anonymous Mar 04, 2008
    Same problem, it indicates: no beans
  • Anonymous Jul 13, 2008
    Machine wont grind, says coffee bean empty.  Fairly new when it broke.
  • Anonymous Apr 01, 2014
    Icon displays no coffee, tray has beans
    New Friend:
II had the same
Posted on Apr 27, 2012
    Problem Solver:
  • 4 Answers
That error message will also appear if the coffee grind is too fine.
Posted on Dec 14, 2007
Thanks, I had the same problem it worked for me.
Posted on Oct 13, 2007
I had the same problem and Saeco recommended that I clean the grinder. Check this link for instructions.http://saecooutlet.com/instructions/Grinder%20Cleaning_Magics_Royals.pdf
Posted on Jul 27, 2007
SOURCE:
My Gaggia Unica won't grind the coffee beans, it just whirs and stops making the drink
More than likely the machine is stuffed with coffee grind. Need to take it apart and clean it. See https://www.youtube.com/watch?v=JQbP2v8C-sA
Sep 20, 2014 | Gaggia Unica Bean To Cup Coffee Machine
COFFEE COMES OUT TOO FAST
Try making your coffee a finer grind. The finer the grind of the beans, the slower the water will flow through the beans. Also fresher beans will make the water flow slower due to the moisture and oil content in the beans.
Jan 07, 2014 | Starbucks Saeco Italia Digital Barista...
Just bought a mazzer super jolly grinder, used it once, the grind was too coarse (#6), adjusted it to a finer grind ((3), and the next time i ran it it stopped grinding, the motor is on, the grinder turns,...
yes, you have to remove the beans inside because there is beans stuck between the burrs. after removing the beans, start doing the finest first before loading the hopper then after putting the beans test the grind as you go courser.
Feb 11, 2012 | Mazzer Coffee-grinder SUPER JOLLY Electric
My super jolly mazzer grinder is switching off after only a few seconds grinding. used to grind continuously for however long i needed, now i have to turn it on 4-5 times just to get enough for one shot! ...
Most grinders, especially the larger professional models will eventually need to have the grinding wheels (set of 2) changed out. They do wear down. The grinder will struggle as the burrs on the wheel dull out. This increases the time it takes to grind coffee and puts a heavy electrical load. Burnt out switches, tripping breaker, overheating, and burnt coffee grounds on espresso size are all symptoms of a worn burr set.
It's common to find; stones, nails, jewelry, and small loose things found around coffee counters in the grinding wheels or burrs. Have a qualified operator remove all beans and hopper to check and brush out burr set. This should be done every day.
Another cause is very oily beans. Sometimes poorly roasted beans come out extremely oily which will gum up everything from the burrs, Moving parts, and electrical components. Disassembly of entire machines may be necessary.
ukeboy57
Nov 07, 2017 | Mazzer Coffee-grinder SUPER JOLLY Electric
When machine grinds coffee it makes winding noise but does not grind coffee, hence you get water
This is a desgin flaw of this machine. Hapens when you use the machine over a long continous period. The water damp makes the grinder wet a it cakes up. The spring is supposed to remove the debris but does not work well. Remove beans form bean tray. Remove the bean tray (1 screw and pull the knob off). Use a vacuum cleaner to **** out the wet bean grind. Dry the wet damp area and use a tooth pick to remove the bean grind (especially around the scute). Let dry and assemble, Good luck!
Aug 09, 2010 | Krups Small Appliances Espresso Machine
Spidem Trevi Plus coffee is not being dispensed.
The grind chamber is blocked, remove the beans and brew unit then clean the grinds chamber, then adjust the grind 2 numbers coarser and try again.
Nov 05, 2009 | Spidem Trevi Digital Coffee Maker,...
Coffee Beans do not grind
Try using the vacuum to clean out the grounds, then remove the brew unit and make sure the chamber from the grinder is clear.
Aug 11, 2009 | Saeco INCANTO DELUXE Espresso Machine
Hello and good morning, I have the Saeco Magic model which has been absolutly fantastic, in the last couple of days my machine has been making coffee that has been very watery? How do I fix and could it...
You don't say whether your using ground coffee or beans if using beans chek that no one has altered the grind adjustment on the bean hopper. If using ground coffee it could be that the grind is too coarse not allowing the machine to extract the coffee.
Dec 20, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Royal Professional Espresso Machine Logo
900 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
