Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
MY DOOR CONTROL PANEL WAS FLASHING AND THE ICE MAKER WAS FLAPPING,M AND IT WOULDNT STAY COLD. I WAS TOLD BY THE DEALER THAT I NEEDED TO REPLACE THE CONTROL PANEL ON THE DOOR. I HAVE DONE THAT AND IT IS COOLING NOW BUT THE TEMP CONTROL IS STILL FLASHING AND ITS NOT MAKING ICE AND CANT GET WATER....ANY SUGGESTIONS
  • ckernisa Mar 07, 2009
    we bought our maytag MFI2588AES at home depot in july of 06 after seeing a special for a 10% discount. we bought the warranty yet home depot has no record of it. 2 days ago our the ice maker door started to flap open and the lights on the control flashes... and it no longer keeping cool... it stops for a few minutes and then starts over, very annoyning. even maytag is giving us the run around... any suggestions?
  • Anonymous Mar 21, 2009
    We are having the very same problem. Flickering digital display and flapping ice-maker cover.
    President:
  • Maytag Master
  • 2,651 Answers
You need to replace the high voltage board behind the unit , not he board behindthe dispnesor.. call maytag with oyur issue, tell them thatyou read about it oin the internet adn would like compenstaion for the board, form the numbe rof posts you read about!!!
Posted on Jan 26, 2009
Whirlpool how to install
With the freezer door open, depress the flap on the left. Does the flashing stop? If so, the Ice maker is the problem, not he optics. With the flap depressed is the only way you can test this. Solid light mean good, one flash and a pause means cycling, 2 flashes and a pause means faulted optics. Now for the ice maker, what position are the harvest fingers sitting at? At 2 O'clock the Ice maker is parked, At 12 it should fill with water so if the fingers are in any other position than 2 O'clock than the ice maker will not cycle at it can't. Its possible that the ice maker have a broken gear and will not function as designed. Get back to me if you need more information and a model number would be great. Good Luck
Jun 18, 2014 | Whirlpool Refrigerators
#! i am very slow on typing ihave matag 12568aeb top ref.& bottom freezer lights on control panel flashing & ice door flapping & ref. & freezer not getting cold i removed door control...
I have seen this before and it is a control board problem. What is the make and model number of your unit? We are not allowed to call clients but I will work with you thru email til the problem is resolved.
Regards,Richard
Oct 13, 2011 | Refrigerators
Ice maker door
The solenoid that operates your ice flap needs to be replaced. You can get it at the linked site below.
http://midwayparts.net/midwayparts/zen-cart-v1.3.8a-full-fileset-12112007/index.php?main_page=product_info&cPath=2&products_id=176
May 20, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Kennmore refrigerator is not making ice,but water
The control light flashes to indicate the infrared beam is being blocked. The flap on the opposite side blocks the beam when the door is open to prevent ice from being dropped on the floor rather than in the ice bin. If you pushe the flap in so it's flush with the liner (use care not to block the hole) the light should go from flashing to on in a steady state. If not, your electronics are bad and would need to be replaced. If the light does glow steady, then the problem is with your ice maker, water valve or ice maker fill tube.
Dec 23, 2009 | Refrigerators
Shoot door (flap) for ice maker wont stay closed causing frost
the gear that pulls it closed is bad. some have small plungers instead of gears
Oct 28, 2009 | Refrigerators
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice flap door won't close - Freezer and ice maker frost up
Every time you use the ice dispensor , when the flap opens , cold air will fall inside the enclosed dispensor cover . This cold air , mixed with the warm outside air , produces moisture inside the cover . After so long , this moisture starts turning to rust , causing the solenoid and plunger to rust . G E has no "fix" for this problem yet . My suggestion , would be to drill holes in the bottom of the dispensor enclosure (white plastic enclosure , held on by 4 screws ) at certain points , so that the cold air will fall thru the cover , instead of staying in the enclosure . This is something I have to try on customers refrigerators for a while , before I send this Idea to G E . To answer your question , yes , I is normal to replace every couple of years ,.....for now anyway .
Sep 11, 2009 | GE Refrigerators
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Frost and ice on flap of ice maker
look down in the chute where the ice despences see if its closing all the way
Feb 15, 2008 | Freezers
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
437 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
