Question about Samsung 2012 Vg-stc2000 Original Skype Web Camera 3d Smart Tv Usb Dual Hinge
Camera getting connected and then dis-connected and my photo is coming in negative
  • Samsung Master
  • 27,725 Answers
Skype is a free software program that allows you to make phone calls through the computer. It also lets you text chat and place video calls. Since Skype is designed for use with web cams, it has the capacity to take snapshots both of you and of the person to whom you are talking in a video call. Plug your web cam into your computer and make sure it is on, open Skype, click on the "Skype" menu, select "Change your picture," and then click "Take Video Snapshot." After that, you can decide whether you want to keep the picture or trash it. Use this option if you want a picture that people can see in Skype almost immediately and don't want to bother with downloading or uploading anything. b>
Posted on Jan 19, 2013
Why does my Defender camera, model 26001, not function in color nor does the infra red work?
First check the power supply, make sure you are over 12vdc or 24vac depending on your source with all cameras connected. Try only one camera connected to the power supply. Make sure you have the positive and negative connected correctly. If the power is good the cameras may be bad.
Sep 07, 2014 | Defender Home Security
I install a vivitar vivicamera dis but the dis wont work
When you connect the camera to the computer USB port, you have to turn on the digital camera. Then the camera will start the program you loaded into the computer to get pictures from camera..
Apr 09, 2012 | Vivitar ViviCam 25 Digital Camera
Hello my problem is every time i take a photo it comes up as a negative image
in your camera setting ther will be option
normal
false colour
greyscale
sepia
negative
solarise
select the normal
Jan 09, 2011 | Cell Phones
How to change out a starter
Dis connect the battery, Locate it on the transmission, then dis connect the cables going to it, then loosen and take out the bolts holding it up. Piece of cake
Nov 23, 2010 | 1998 Chevrolet S-10 Pickup
Light comes on: Traction engaged and goes on and off. Also the anti-loc traction control light comes on and off on Cadillac 1997
My friend; Try this; Check the fuses / relays boxes in both cabin & engine compartment. Make sure there is no burned fuse or relay. U can check them visually & or using digital multi tester DMM. Check the brake peddle switch. This system {TCS} hooked up with ABS system & ESS & could be due to leaks or malfunction in the brake & or ABS sys. NOTE; TRY TO RESET THE SYS. BY Just ; 1. Dis-connect the battery negative cable, while the ignition switch in the ON position {Don?t Run the engine}. 2. keep it Dis-connect for at least 15 minutes { some experts said 13 hours """ Overnight""" }. 3. Re-connect the battery negative cable, put the ignition switch in the OFF position {Don?t Run the engine}. Then NOW run your engine & see if it disappears. Try it, & PLZ; let me know if I add any benefits to you. I hope I add some thing valuable to you. Regards; MAR; soer2@yahoo.com
Nov 09, 2009 | 1997 Cadillac DeVille
Put camera in cradle to charge. red light comes on for about 5 secs, then goes out. can't get camera to take a charge...
try connecting a 9volt battery with a couple of jumper wires to the correct terminals on the battery for about 30 seconds then put it on charge(positve to positive negative to negative) if the battery is to low the charger won't pick it up and start the charging cycle by connecting the 9volt to it t will put a small charge to it to start the charger
Oct 15, 2009 | Sanyo Xacti VCP-HD2 Camcorder
No real color picture, looks like an undeveloped negative, ghost
The pictures are indeed negative.  When scanning negatives or transparencies make sure you have the scanner set to the appropriate setting, otherwise simply Invert the colors in Photoshop, or similar photo editing software.
Dec 03, 2008 | Cameras
Negative/inverted pictures
If the images in the camera are inverted , then could mean repair or replacement is the remedy and I suspect only replacement will be the answer.
When you say Photo Gallery- do you mean as displayed in your computer after uploading?
If so then an image editor such Irfanview or Picasa will revert them.
Jun 23, 2008 | Fuji FinePix A350 Digital Camera
Negative effect screen
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Apr 05, 2008 | Nikon COOLPIX L4 Digital Camera
Sony Mavica MVC-FD75 Digital Camera pictures taken come out as colour negatives
If you can use the LCD to take a photo and then use the LCD to review it later then the fault can't be with the camera. Have you tried checking the photos on another computer? Maybe your software is corrupt and needs uninstalling and then reinstalling again. Actually, from memory this camera has a few effects and one of them could be a negative. Check that you haven't switched the effect on by mistake. You'll find it in the camera's menu. What's causing the distortion I'm not sure.
Jul 24, 2006 | Sony Mavica MVC-FD75 Digital Camera
Samsung 2012 Vg-stc2000 Original Skype Web Camera 3d Smart Tv Usb Dual Hinge Logo
112 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
