Question about Samsung NP-N102SP 25.7 cm 10.1inch LED Netbook - Intel Atom N2100 1
The battery of my samsung netbook N102SP no longer fully charging even the charger is still connected
    New Friend:
  • 3 Answers
Samsung n102 I plug charger the laptop off when I on it.
Posted on Oct 11, 2013
4 Suggested Answers
CreativeTECH
  • 1719 Answers
SOURCE: basically my samsung n145 netbook
Hi Ashley,
It clearly indicates that the battery of your laptop has deteriorated and cannot hold enough charge to run the system without AC Adaptor/ external Power Supply Source. So, the battery is supposed to be replaced with a new one. You may have noticed that the battery would be empty when you start the netbook and it shows 100% (fully charged) in a very less time. This happens due to the faulty/ deteriorated battery, which has very less charge holding capacity and hence shows fully charged in no time. If so, I suggest that you buy a new genuine battery (not any replacement), as genuine battery would last longer and serve you best.
On the contrary, if the battery gets charged normally and takes about 50-60 minutes to show 100%, then you may get the netbook checked by any authorized professional for complete hardware (Battery/ AC Adaptor etc).
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Posted on Jul 28, 2011
krbshg
  • 430 Answers
SOURCE: CHARGER NOT CHARGING BATTERY ON SAMSUNG N130 NETBOOK
Have you check the charger, is it providing proper voltage? it could be because charger if it is not supplying proper voltage to your laptop, if not then there use to a charging IC attach with the mother boardhas gone bad.
Posted on Aug 08, 2012
  • 564 Answers
SOURCE: sAMSUNG LAPTOP PLUGGED IN NOT CHARGING
try removing the battery and just use the mains power. If the laptop works you may need a new battery. If it doesn't your charger is faulty.
Posted on Nov 26, 2012
My samsung pl200 won't turn on, battery is fully charged I even tried an extra one still not working... ????
Possible Solutions.
1. Charge the battery
2. If still not turning on, try using a little alcohol and wiping the battery terminal(s) on the battery and the battery terminals in the camera. Use a QTip and allow to completely dry before recharging the battery or inserting it into the camera.
2. Replace the battery with new one.
3. On/Off switch may be defective on camera. Charger may be defective. Wire connecting power from charger to wall socket may be improperly connected or loose.
Aug 16, 2016 | Samsung Cameras
Our Samsung tablet (GT-P5210) will no longer turn in. It's supposedly fully charged but even the battery indicator screen no longer comes on. The screen is completely blank an we cannot turn the tablet on...
Try a completely different charger if haven't done so already
Samsungs can be very picky on what chargers they will accept, usually will charge on any charger but sometimes will need a genuine Samsung charger to work
Mar 24, 2015 | Samsung Tablets & eReaders
Samsung N102SP doesn't boot
Sounds like a Ram or processor failure. Any beeps?
Take the battery out and pull the power. Wait 2 min and put the power back in and try to boot. That is a start.
Nov 16, 2013 | Samsung NP-N102SP 25.7 cm 10.1inch LED...
The cursor is not working
samsung n102sp plug charger it off solution plz
Aug 04, 2013 | Samsung NP-N102SP 25.7 cm 10.1inch LED...
Can not run netbook off battery even though battery shows fully charged' When charger is removed netboook will not turn on
Make sure the battery is fully inserted and clicks in to the netbook body. Your battery may also be showing that it's charged but is actually dead. Try a new battery and see if it solves your problem.
Jul 04, 2013 | Wolvol Mini NOTEBOOK COMPUTER Laptop...
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
Aug 08, 2012 | Samsung Computers & Internet
Hello, Leoch 12V battery, DJW12-12Ah, is no longer charging. We bought a John Deere riding toy at a local Toys R Us in Michigan three years ago. My children have only used it for two summers and is...
Sounds like a battery problem.
Lead acid batteries should to be charged every 3 or 4 months even if they are not being used, or they can slowly self-discharge and will start to deteriorate if the voltage drops below about 12.2v (for a 12v batt.)
They can then be difficult or impossible to charge. The charger can see this as fully charged and show green.
You can test for this if you have a voltmeter. You should be able to work out if it's the battery or a connection (or the charger).
Measure the battery voltage (use a DC voltage range greater than 12V). The normal voltages you should see:
A) Key off, no charger: >12v, <14
B) Key off, charger connected: >12, <14.2, but higher than A)
C) Key on, no charger: >12, <14, but lower than A)
If voltage A) is low and immediately goes high when the charger is connected then the battery needs replacing.
If A) and B) are exactly the same then it could be the charger is not connecting or is faulty. Measure the charger output, should be >13.8v (unless it's an "intelligent" charger in which case it might need some voltage applied to its output before it starts charging).
Note: If A) and B) are low, say <8v it's possible that an "intelligent" charger will refuse to start charging. In this case it's probably worth jumping the battery to a good 12v battery (e.g. car). Be very careful to connect the batteries (+) to (+) and (-) to (-). Leave connected for 10 - 20min or even overnight and then disconnect jumper leads and check A) and B) again. Sometimes a battery can be recovered by this method (it's unlikely to regain full capacity though).
Jul 19, 2017 | Lee-t.com Facebook Apps
Basically my samsung n145 netbook wont power up unless its connected to the power supply and also i cant disconnect the power supply when fully charged as it cuts the laptop off straight away :( cheers
Replace your battery to solve this trouble.
Get a battery from a FixYa.com advertiser or anywhere computer batteries are sold.
Thanks for your question @ FixYa.com
Jul 28, 2011 | Samsung N145-JP01US Netbook
Samsung NP-N102SP 25.7 cm 10.1inch LED Netbook - Intel Atom N2100 1 Logo
303 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
