Question about Gaggia Accademia Super-Auto Espresso Machine
Gaggia Accademia Error code E14?
Hi i got Error code E14 today. It startet up and and should make cappucino, the milk when good and when i come to the coffe making the grinder did not start. I turned off (power cabel out) the machine a couple off minuts, while I washed the Coffe brew unit and interier. but it did not help. Any idea what this could be.
  • Torben Jensen Jan 21, 2013
    Got answer from Gaggia repair specialist Error code E14 is temperature controller failure. Solution: Drain water and Clean system
  • Daniel Puga
    Daniel Puga Dec 17, 2013
    Hello Torben, Do you know what is the error E-16?
SOURCE: Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Posted on Sep 17, 2007
  • 833 Answers
SOURCE: Broken Handle on Coffee Grinder
Nice unit! Replace the part. Try www.smallappliance.com.
If you want to try to glue it first, get a product from 3 M. I think they call it super strength glue. Scrape off all traces of whatever you used before. Follow the instructions exactly.
Posted on Dec 03, 2007
  • 1089 Answers
SOURCE: Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
Posted on Jun 17, 2009
  • 421 Answers
SOURCE: Have a Gaggia Cyncrony Compact Coffe Machine that doesn't brew!
Has the machine been de-scaled recently? I would run a descaling solution through the machine first to eliminate that.
Posted on Jan 16, 2010
SOURCE: how can I clean my Gaggia burr coffee grinder?
For parts you can see, use an artists paintbrush. If you want to clean the internals, grind some panko breadcrumbs or raw rice grains, then run some coffee through it a few times before using.
Posted on Feb 12, 2010
Gaggia cappuccino xtwo. What is error code 1?
Im not sure if this will help but I've got some Gaggia Accademia Error Codes, maybe they are the same as the Gaggia cappuccino xtwo.
Hope it helps. https://wll-documents.s3.amazonaws.com/Gaggia/Accademia/Accademia%20Error%20Codes.pdf
Apr 05, 2016 | Gaggia Coffee Makers & Espresso Machines
My new accademia gaggia won't work, error code 05
see this causes and fix it. God bless you
Reset the code read your instr. manual
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord, the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 1003380 Accademia Espresso Machine
My new gaggia accademia won't work. IT shows error code 05. Con Youtube help me?
reset the error code and read your instr. manual. God bless you
proceed according.
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord , the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 10003380 Accademia Automatic...
My new gaggia accademia won't work. It shows error code 19. Can you help me?
Hi, Error 19 is not known by me. Sounds like something is not resetting or has failed. Try turning off the machine at the main power switch and unplug it from the wall for a few minuites. Remove the dreggs draw and drain tray and replace them before you plug it back in. This will allow the machine to reset. Dazza REPAIRER
Sep 24, 2011 | Gaggia Coffee Makers & Espresso Machines
STEAM PROBLEM
Does the steam itself smell, or just the milk. If yes on the steam run the descale again. If no on steam then check the perfect cream wand the black plastic arm connected to the steam wand, dissamble and clean, make sure all the holes are clear.
Mar 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Accademia Super-Auto Espresso Machine Logo
655 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
