Question about Apache Colco Ah 64 Longbow R/C Helicopter
Frame Where can I get a new frame for my apache ah-64 longbow 4 ch made by coco
    Problem Solver:
  • 16 Answers
Either try see it the manufacture can help or a local hobby shop might have something simular.
Posted on Jan 29, 2009
Activation key?
neviem nájsť aktivačný kod na pc hru APACHE AH-64 AIR ASSAULT. DAKUJEM.POMOZTE MI PROSIM.
Jun 26, 2011 | Activision Apache AH-64 Air Assault
I cannot find activation code for apache:air assault
I dont think there is any activation code for Apache AH-64 Air Assault.But don't worry I have a crack its 100% working.Reply me to know more.
Thank You
Jun 20, 2011 | Activision Apache AH-64 Air Assault
My AH-64D LONGBOW helicopter spins out of control when i try to fly it how can i fix this problem?
make sure the tail motor does not have any hair stuck in it take of the little propeller and clean it.
next adjust the trim so when your taking off so helicopter will not spin any more and your good to go
Dec 13, 2010 | Spinmaster Air Hogs R/C Ah 64 Apache Havoc...
Heli will not climb above ground effect, battery tests ok, axles in balance no vibration, just will not climb
I also have this kind of problem with my apache. The upper propeller must spin faster thatn the lower propeller if not the heli would just spin on its tail although maximum power is achieved. The solution is to check the connection of the gears and the axle of the upper propeller which is located at the bottom of the helicopter. remove first the battery pack to see clearly the connection. try to turn the upper propeller a few turns and see if the axle, gear and the metal connector is sliding. A fixed my heli buy putting a permanent glue on the axle, connector to the gear and whalla. it does not slide. Most problems of this model is the gear of the upper propeller, often times loosened specially during crushes. This will a lot help you as your heli would have power on the upper propeller for lift off. Happy flying.
Gerry1abe.
Mar 07, 2010 | Apache Colco Ah 64 Longbow R/C Helicopter
Building a RC helicopter for college
You might want to get on google and search how to build Remote Control Helicopter. you will find a lot of useful info. If you have never flown a RC heli thought I suggest you get a sim for the computer. I have been flying now for 10 years and they are not that easy to fly. I still have problems and always am learning some thing new. here is one link to look at.
http://www.angelfire.com/blues/heli_project/
Jan 29, 2010 | Apache Colco Ah 64 Longbow R/C Helicopter
Hi my apache bottom wings are good but top wings dont spin they just sit there they were fine the first flight untill i crash it
Please check the connection of the axle of the upper propeller. Turn the heli upside down and spin the upper propeller manually, try to see if the gear turns if not there is a loose connection. You will find 2 small screws near the gear, unscrew one of them and push the axle then back in place, tighten the loosened screws. Turn the upper proppeller manualy, a few turns will do ansd see if the gear turns simultaneously with the propeller. If it still does not turn, apply a permanent glue to the gear and the axle. This will sure have your heli on flight.
Gerry.
Dec 29, 2009 | Apache Colco Ah 64 Longbow R/C Helicopter
I have an apache 3 channel helicopter.the top blades no longer spin so the helicopter just spins clockwise very quickly
Same problem I had. There are two motors. One to spin the top blade and a second to spin the bottom. My motor was defective out of the box to spin the top blade. Very poor quality as my AH 64 had a bad circuit board. I had to take parts from one to fix the other.
Sep 04, 2009 | Apache RC Mini Helicopter AH-64
Apache Colco Ah 64 Longbow R/C Helicopter Logo
126 people viewed this question
Top Apache Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Apache Toy Expert? Answer questions, earn points and help others
