Question about Panasonic Home Theater System System
Dvd player my child put the movie in incorrectly, now the door is jammed and will not open or play the movie
    Genius:
  • 1,199 Answers
Turn player upside down gently and try to get the dvd to slide back down to the front of player return and try again! this may take a few tries...just be carefull
Posted on Jan 26, 2009
I cannot play a dvd movie or record a tv program in ilo dvdr05 recorder, what might be the problem?
1: Get a movie and some popcorn.
2: Make sure the DVD player and the tv are turned on.
3: Push the button on either the front of the player or on the remote to open the player door to load the disc.
4. Put the disc on the tray that pops out
5. Push the same button pushed previously to close the door
6. Enjoy the movie
Jan 19, 2015 | iLO DVDR05 DVD Recorder
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Dvd player
I took some screws from the sides off, and lifted up the top. I took the dvd out of it. It seems to be working good now.
Jan 26, 2009 | Philips GOGEAR SA6045 MP3 Player
Door will not open to put dvd in
hold the eject botton and pull on the side pannel a little and it will open
Nov 26, 2008 | Clarion MAX385VD Car DVD Player
Playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
Feb 24, 2008 | Emerson EWD7003 DVD Player
DVD stuck/jammed in tray
there may be two screws on the top of the tray that holds the rounded magnet, the one that is placed to hold the disc when spinning, remove it, you can then simply take the disc out.
May 19, 2007 | Pioneer DVR-810H DVD Recorder
Incorrect region code
This is how to make Philips DVD 622 region free so that it can play VCDs from all regions.
*Open CD tray by holding down "stop" button on the remote.
*Enter 2812
*Hold down "OK" button on the remote till 9 appears in the TV screen
*Turn off power of your DVD player
*Turn your DVD player on and it is region free now
Apr 27, 2007 | Philips DVD 622 DVD Player
Incorrect disc and bAd
I have the same problem, reads bad, won't play, took the top of a blow on it, alot, hoping dust would come off the lens, it did. Works now, also ran a disc cleaner in to after.
Have another dvd palyer, never had that problem, Philips.
Feb 25, 2007 | Toshiba SD-3980 DVD Player
Panasonic Home Theater System System Logo
60 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
