Question about Garden
Remove front wheel masport push mower
How do I remove the circular clip that secures the wheel on the axel.
  • 68 Answers
SOURCE: We just bought a Series 430 push mower --- had no
They usually put spring washers in there to keep things tight.
Try some good penetrating oil on the pivot bolt.
Last resort--loosen the bolt, use oil on it, retighten.
Posted on Apr 26, 2009
  • 81 Answers
SOURCE: replacement of mower wheels
You have to pop the clips off the outside of the wheels. There may be a plastic over on each wheel that has to be removed first, but without a model number I'm not sure it your mower has them. If you don't break any of the clips they can be reused.
Posted on Jun 23, 2009
  • 491 Answers
SOURCE: The front right wheel repeatedly comes off because
Can you drill a small hole down through the end of the axle and put a washer and cotter pin to keep the wheels on?
Can you attach a flat piece of plastic or aluminum sheet under the grass catcher to prevent the bag from wearing as it slides along?
Next ....use the best oil you can get......in the engine.......they are also not made as well as they used to be (service life has been reduced ) so take extra good care of it.
Posted on Sep 04, 2009
heres2maine
  • 84 Answers
SOURCE: How do you remove the gears on a front wheel self
Take the front tires off, pull gears and take out pins, put tires back on and you have a "non-self propell" mower.
Posted on Apr 15, 2010
  • 1116 Answers
SOURCE: how to remove the blade from the Masport lawn
There is a nut in the center of the blades. The easiest way to remove this nut is with an impact wrench. If you don't have one there is usually a hole in the disc where you can insert a screw driver to lock the blade from from turning and you will need a long handle ratchet in order to give enough torque to remove the nut. Once the nut is removed, the blade will slide right off. If you are doing this to sharpen the blades, you do not need to remove the blade to do this. Use a 1/2 HP grinder wheel and just evenly slide the wheel down the blade until it is sharp. CAUTION: it will cut you finger. Make sure you disconnect the power and the fuel is turned off at the time you do any of this work....
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 09, 2011
How do i fix cv axels on a 2002 hyundai accent
It's not worth it to fix the axel, it is wise to replace the axels
by jacking up the car secure the car with jack stands, then remove the wheels, the big center nut of the axel and the lower bolts on the ball joint, then pry the lower control arm down and pull the hubb aside. Now u could remove the axel easily, if stuck take a hammer and tap it lightly, remove it, replace with the new but make sure both ends r lubed with grease.
Feb 21, 2015 | Hyundai Accent Cars & Trucks
How do i remove the axel on a toyota echo 2000 model
remove road wheel . remove axle nut , uncouple lower strut and pull disc housing out wards may have to tap axle. the axle is held in the diff housing with a c clip but come out with a sharp pull.
Sep 20, 2014 | 2000 Toyota ECHO
How do you replace the cv drive axel
start by jacking the car (SAFELY secure it up in the air with jack stands) - remove the tire on the side you want to replace, once in there you will need to get at the center of the wheel and remove the nut, pop the axle out and replace..
it would be wise to have a drain pan and rags for any oil which may leak and or seep out..as you progress forward the removal becomes more evident, there are typically no spring type clips, the shaft slides right out. other hint: you may find it easier to turn the steering wheel - again be sure you safely secure the car when it is up off the ground
Best regards
Ck
Mar 12, 2011 | Chevrolet Uplander Cars & Trucks
How do i remove the back wheels for a bugaboo cameleon
Go to www.bugaboo.com they have pdf owners manuals for all their product and they are actually quite easy to understand, Unlike some of the Chin-glish horrors I have seen. Simply there's a wire clip on the frame stub where the wheel axel inserts, Squeeze the clip and the wheel comes off.
Aug 21, 2010 | Bugaboo Cameleon Jogger
I have 2001 Chev Tracker, Oil started to run out of the Right side break drum. Removed Drum and foud oil all over the breaks. Tried to remove the Axel by removing the four nuts off of the backing plate,...
fror fixing the brakesw take the other rear wheel off and duplicate what u see. to get the axel out u must first remove diff cover in center of rearend then u will see a clip for each side axel remove clip and axel will slide out. good luck fron 1 to 5 being difficult its a 3
Jul 21, 2010 | 2002 Chevrolet Tracker
Remove axel from transfer case of polaris atv
the axle is held in by a small circular compression clip. after you remove the tie-rod from the strut assembly and remove the nut holding the axle in the strut tower you should be able to pry on the back side of the axle where it goes into the differential. it might be a pain but will come out.
May 03, 2010 | Polaris ATV
The axle from a jeep 4x4 is broke , both axles, how do i take out the rest of the parts?
The front axel is a two piece assy. remove the 4wd
shift moter from the axel housing. Once the moter
and fork are off , remove outer axel.To remove inner
axel, remove differential cover and let it drain.
There is a C clip on the axel, remove it and work the
axel out through the axel tube.(if it is broken)
To remove the rear axel. Remove diff. cover and drain.
Remove the pinion lock nut(or spring clip) and slide
back pinion shaft. Remove retaining clip from axel
and remove axel. To remove broken piece I use to
use a length of an old whip antenna, to push it out.
If you can find a piece of heavy gauge wire to push
it out.(a plumbers snake may work)Also only have
one axel at a time out of either housing, this will
make it easier to reinstall the axels.
I hope I was of some help. Good luck.
Jan 30, 2010 | 1995 Jeep Grand Cherokee
How do i remove the rear axels on a 2001 dodge ram 1500 4x4 3.6 v8
this is for front axle removing.you have too take off the wheel then the brakes, then you have to remove the 3 bolts on the back of the wheel assembly and lightly take a mallet and tap the wheel assembely out. and it all just pulls out after that. ------------- for rear axle . for the axle shaft,jack the rear of the truck up take off the wheels and brake drums.make sure truck is securly supported with jackstands.remove the differental cover locate the bolt that holds the cross pin in the carrier.remove the bolt,slide out the cross pin.push the axle in towards the center and remove the c-clip holding the axle in.remove the axle shaft carefully so not to damage the bearings or seal. ----------- You need to remove a bolt inline with the axles on the spider gears which holds the center pin in place. Remove the pin, rotate the spider gears to the other side. Now move the axles inward to reveal the c-clips and use a hemostat to remove. Of course the the truck is up on jacks with the tires removed. this will help.
Sep 15, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Instructions for removing/replacing rear wheel, 2007 FLHR
remove the bags and side covers /remove clip from rh side of axel remove nut/put wrench on lh side of axel and twist to loosen belt adjustment caution !! note clamshell adjusters both sides they need to go back the same way when refiting wheel knock the axel from rh side through with large screw driver use hand not hammer the wheel should drop stand over back fender lift wheel slightly slip off belt roll brake caliper up and outwards untill it clears drop wheel down and remove brake caution again!! belt tension should be 10lbs 4.5 kg force centre from front and rear sprocket you will need belt tension tool for correct tension
Jan 18, 2009 | 2006 Harley Davidson FLHR Road king
Leaking left rear wheel seal.
Loosen differential cover and let oil drain. Remove cover, remove E clip lock from axel. Pull axel out. Remove bearing seal. Install new seal and reinstall axel. Reinstall E clip lock and new cover gasket. Fill with 75-90wt gear oil. Now I know that sound pretty straight forward. But there are some things to remember. The E clip lock can be difficult to remove sometimes. The most important thing is the seal, you will need to make sure it gets seated correctly and not torn when installing axel
Jul 26, 2008 | Chevrolet Silverado 1500 Cars & Trucks
Garden Logo
132 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
