Question about Jura ENA 9 One-Touch Espresso Machine
Jura ena 9 grinder - Jura ENA 9 One-Touch Espresso Machine
Jura ena 3 rotary dial issue
Have you tried completely powering it down, as far as unplugging it from the wall? Sorry if that's stating the obvious, but I'm a computer guy and 9 times out of 10, a 'reboot' fixes the problem.
Aug 04, 2014 | Jura Capresso Jura Ena 3 Espresso Machine ...
Ena9 coffee comes out is bitter
The most common cause of bitter coffee is that the water is too hot. And the most common cause of too hot water is too much pressure in the boiler. So, the first thing to look at is the pressurestat of the machine, it should be accessable and adjustable. 1.5 bar is often the maximum pressure for good coffee (don't confuse it with the 11 bar pressure in the grouphead when brewing).
Jul 28, 2014 | Capresso Jura-Silver/ Black ENA 9 One...
Jura ena don't grind coffee
new grinder teeth
Dec 27, 2013 | Jura ENA 3
JURA ENA 9, GROUNDS TRAY WILL NOT INSERT IN MACHINE
Hi, I made a video on YouTube how to fix your Jura step by step
like my video, good luck
http://www.youtube.com/watch?v=KP_KvZs1wLY
Aug 15, 2013 | Jura ENA 9 Automatic Coffee Center
My Jura Ena gives a 'fill beans' message even though the hopper is full and it won't grind the beans even though it seems to be operating. Help.
Mine just started doing the same thing. I've always only used plain espresso beans. Only thing is I may have overfilled the hopper and packed the beans down a bit. How can I make it start grinding again?
Sep 08, 2010 | Jura Capresso Jura Ena 3 Espresso Machine ...
Jura ENA 9 One-Touch Espresso Machine Logo
42 people viewed this question
Top Jura Coffee Makers & Espresso Machines Experts
cramsey548
Ross Keen
ray gallant
Are you a Jura Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
