Question about Vacuums
Fantom model fm718 will not pick up dirt - Vacuums
    Scholar:
  • 74 Answers
If it isnpt plugged inth ehose then change the Tap Filter, It is a little thick and without regular cleaning of the particular part, dust will stay compressed in the little filter, plugging it up and restricting the air movement through the machine. I know this because I own this machine and that is what is wrong with it.
Posted on Apr 24, 2010
  • 125 Answers
Its likely clogged somewhere
Posted on Jan 26, 2009
My fantom thunder vacuum runs great but isn't picking up wand has no suction
It could be one or more problems. The filter is likely clogged. It should be replaced at least once per year if you can find one. Clogged filters greatly reduce airflow which will cause dirt and debris to build up in other areas of the vacuum eventually causing it to have no suction. If you get the suction working make sure to install a new belt if using it on carpeted floors.
Mar 10, 2017 | Vacuums
My fantom Fm310K picks up dirt, but it continues to plug up. the canister does not get the dirt.
The dirt is most likely getting caught somewhere between the nozzle housing and the canister. You must try figure out where it's getting clogged.
Jan 25, 2017 | Vacuums
I have a fantom power pet model #fm722c how do i get inside to change the belt or remove the dirt from inside as well as the vacuum is not sucking the air thank you gail glandon
I have just cleaned out my filter and now it does'nt go back together?????
Please help asap. It is a power/pet model
Apr 01, 2011 | Vacuums
Can't get my vacuum to pick up the dirt.
Hi, you may have a clog i te machine, or a broken or stretched belt. Hope this helps. Chris
Feb 07, 2011 | Fantom Vacums FM741 Twister Bagless...
I have fantom FM741H It sadenly stop working. I checked plugs,circuitbraker. They are Ok. What is possible problem? Thanks
I have the same sweeper as you. I have had this sweeper over 10 years. I purchased it from HSN. Model fm741h. Ok here we go. I paid 299. for it 10 years ago. It worked perfectly. Picked up all sorts of things. It stopped working about 5 years ago. I kept it hoping I could get someone to go over it with a fine tooth comb in my area. No one worked on them. So I still kept it. Just today 09/4/2010 I was looking at it. I decided to start taking the whole unit apart. I come to find out all the filters are clogged. I have never replaced them or the belt. The belt was fine, the motor runs, but its just not picking up anything. So inside the canister was caked with dirt. I mean literally DIRT. Inside the part that spins is another filter. I checked the prices on those. Anywhere between 23.00 up to 50.00. So I took a toothbrush and ran it under hot water. Scaped off all the dirt, let it dry and presto....I have my TWISTER back. YIPPY!!! I can't see spending that much on a filter when all you have to do is scrape the dirt off of it. Works perfectly. Now that I know what to do....I'm a happy camper.
May 10, 2010 | Fantom Vacums FM741 Twister Bagless...
My Fantom Fury vacuum does not pick up dirt. [The
You will have a blockage in the vacuum hose. Take it of and outside and push the garden hose from one end to the other.
May 01, 2010 | Fantom Vacums XT450K Upright Vacuum
Where to purchase Fantom Vacuum parts? Not filters, belts, bulbs
I am sorry to inform you but fantom is out of bussiness and the parts are no longer widely available. If anyone has them it would be the guy i am refering you to.
ask for joe
302-698-2133
I am not sure of his hours but take into consideration he is on the east coast.
Apr 13, 2009 | Vacuums
How do I change the fantom fury belt?
Fantom Vacuum site. Find the Model #-usually
on the back of this model,type it in and you can
read and look at diagram .Good Luck.
Belt ordered at Totalvac.com.
Dec 29, 2008 | Fantom Vacums XT450K Upright Vacuum
Fantom Twister
On my fantom cylone I use a 2 foot wire with small hook. Open bottom and push wire up the vacuum channels. There is also a channel that goes to the brush. Check for suction at hose. If none then your one of your channels going up are blocked. If you have suction at hose but none at floor brush then channel to floor brush is plugged.
Dec 09, 2007 | Fantom Vacums FM741 Twister Bagless...
Vacuums Logo
188 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
