Question about Pioneer VSX-D511 Receiver
OVERLOAD Hi I'm having trouble, I keep getting a message OVERLOAD then it shuts dow, can someone please help me
  • 20 Answers
HOW MANY SPEAKERS ARE YOU RUNNING? IF you are running more than TWO speakers, the very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: Some Pioneer equipment have internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized HK service center must do this.] But, before you take your unit in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Posted on Jul 18, 2007
SOURCE:
Where is the reset button on Elna6004 6004, overload message keeps appearing
The message means that the motor is drawing too much current. Could be a mechanical bind or the motor itself is worn out.
Hope that helps.
Aug 19, 2016 | Sewing Machines
How can I fix my blue tooth keep shutting Dow and saying rad is killing the battery
rad is bad,get rid of rad especially if it is shutting dow
Jul 24, 2015 | Cell Phones
Hi, My Acer aspire 5332 keeps shutting down with no warning, I have rebooted approx 7 times each time it will shut itself down.
Have you checked the battery condition indicatot on the lower right hand side of the screen? It may be low and telling the laptop to shut dow.
Hope this helps.
Oct 31, 2010 | Acer Aspire 1202XC (LX.A0105.085) PC...
Hi, I keep getting the od trouble code.
See this link for OD troubleshooting. If you have questions post back and I will help you….Rich
Jan 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Keep getting the overload message "OL"
Try unplugging for 12 hrs before reconnecting
If the problem continues then the controler board is damaged and will need to be replaced.
Please rate our help to keep the FREE service online ++++ Thanks for using FIXYA
Sep 05, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Dryer runs for a few mins. then shuts off and turns on after a while
Hi, The motor is overheating and shutting off on an overload.
The motor will need changed. Let me know if I can assist you further.
Vic
May 30, 2009 | Dryers
Wrong directions
did you try reseting the system
Sep 05, 2008 | Garmin StreetPilot C330 GPS Receiver
APC UPS CS 500 (BK500EI)
If you can repair pcb then check overload protection section.There is some shortinng in components or ic could be demage.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 07, 2008 | APC (BK500TW) UPS System
Overload?
I was recently on the Pioneer site researching this receiver. They just happen to have a few suggestions for trouble shooting this particular problem. I think you have to have cookies enabled to view this link. Hope it helps ya. http://www.pioneerelectronics.com/pna/v3/pg/support/knowledgebase/0,,2076_310069579,00.html
Sep 08, 2007 | Pioneer VSX-D608 Receiver
Pioneer VSX-D511 Receiver Logo
281 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
