Question about Briggs & Stratton Garden
98902-2065-B1 briggs & stratton oil:petrol ratio pls
    Sergeant:
  • 322 Answers
This is a 4 stroke engine which requires an sae 30 weight oil in the crankcase and straight gasoline (petrol) in the fuel tank
Posted on Jan 23, 2013
hunter19_46m
  • 7482 Answers
SOURCE: weed eater 22" mower with
Hi stnstomper...
Look under the mower for a square plug or allen wrench type plug, this will be your oil drain for the motor.
Some of Briggs & Stratton motors do not have an oil drain plug...
If you do not have an oil drain plug then you will have to run the mower to get it warm, then remove the oil fill plug and tip the mower towards the oil fill plug to drain out the oil thru the fill plug hole.
Free Answer...Please take time to rate me
Posted on Jun 13, 2011
hunter19_46m
  • 7482 Answers
SOURCE: mountfield petrol mower HP470 problem with
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming the carburetor a few times or spraying starting fluid into the carburetor, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 11, 2010
canbruce75
  • 1776 Answers
SOURCE: I have a troy bilt mower with a briggs &
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Posted on Jul 19, 2009
  • 1129 Answers
SOURCE: Briggs and stratton engine surges and slows, repeatedly
There is still either water or debree contaminating the fuel system. Surging is usually debree, empty and flush the tank with gas or Iso alcohol, disassemble carb soak in solvent for 30 minutes blow out the carb passages, reassemble and if the problem persists run engine at top rpm with air cleaner off and block off carb intake with hand, this will stall the motor restart and repeat 4 - 5 times this wiil draw out any debree or other blockage in the carb.
Posted on Jul 25, 2009
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
Not able to find listing for Briggs Stratton 126907 1473
MAYBE this is the right number ? 12S907 1473 B1 by a little suggestion
http://www.partstree.com/parts/briggs-and-stratton/engines-vertical-engine-with-electric-starter/12s907-1473-b1-briggs-stratton-engine-electric-starter/air-cleaner/
Briggs and Stratton 12S907 1473 B1 Briggs Stratton Engine Electric Starter...
Oct 21, 2016 | Briggs Measuring Tools & Sensors
On a briggs & stratton mod#122T02-1012-B1 does the primer bulb have a hole in it
No primer bulb should have a hole in it. Petrol will escape and become a fire hazard.
Jun 24, 2013 | Garden
Overheating briggs & stratton motor model #126t02-0487-b1
what do you mean by overheating make sure all the fins in engine are clean and free of debris and also the top of flywheel is clear as well it must be to keep it running cool
Jun 04, 2013 | Garden
What 2-stroke mix for a Snapper mower (Briggs & Stratton 6.5 HP)?
USE A 32:1 MIX. THE MORE THE RATIO OIL TO GAS MIX RATIO THE MORE COOLER AND LONGER LASTING THE ENGINE WILL BE. 40:1 IS FOR FULL OUT TROTTLE CHAIN SAWS ECT.
Mar 13, 2012 | Snapper Garden
My Briggs & Stratton Diamond I/C 13.5 HP has
it could be worn out piston rings letting unburnt fule past into the sump oil
Jun 20, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
My flymo briggs & stratton quick silver 46d
Your carb needs to be taken apart and cleaned
Jun 19, 2010 | Briggs & Stratton Garden
What oil to petrol ratio does this engine run on?
http://www.briggsandstratton.com/maint_repair/manual_and_more/
Go here and enter the proper information, and see if they have the manual available.
Apr 18, 2009 | Husqvarna Garden
Garden Logo
140 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
