Question about Sony ICF-C492 Clock Radio
SOny Clock IC492 looses time
My Sony clock looses 10 minutes every hour, I ourchaed in in teh US and am working thru an adaptor which gives an output of 110-120 volts. can anybody of any help?
  • 3 more comments
  • Rajeev Mall Jul 16, 2007
    Thanks Arpi...
  • BaluKwt Mar 01, 2008
    My Sony Clock IC492 looses 10 minutes every hour, I purchaed thru Amazon.com in Feb-2008 in US and am using it thru an adaptor which gives an output of 110-120 volts from 220V.
    Can anybody help me please?
  • Anonymous Oct 10, 2008
    I have the same problem. I dont think it is because of supply frequency. Since I have another clock radio model number slighly differ ICF C 318, its accurate for even 1 seconds. So how come only ICF C 492 clock depends on the supply frequency? I guess internal circuit use the DC voltage after rectifying the AC. And some amazone complaints looks like this is happening in US also wherein 60 HZ supply exists.
    dont know what to do. Need to find an expert in circuit tracking and fixing.
  • eduardovaz Jan 29, 2009
    My clock is going too fast. Every day it goes about 20min early. My voltage and frequence are 127ac~60Hz, the right one to this clock. This problem started 6 months after I bought it.
  • vaibhavbs Feb 13, 2009
    Anand krishan given a good solution for this but later in the end of his comments he said it again lags 1 min for 1 hr so finally 24mins in a day then what is the use of disconnecting the 26th pin in IC. Can u please be clear in what u said. Does it really works without harming the clock functionality.
    Can we try your suggestion without fear.
Dont think this model clock accuracy depends upon the supply frequency.
1. I have ICF C 318 with the same specification but works accurately (1 sencond) in 50 Hz.
2. there are some amazone complaints even from US (wherein 60 Hz exists)
3. Dont think a clock designer will depend on supply frequency. (many time, this varies even in a very good power network)
Posted on Oct 10, 2008
  • Anonymous Oct 11, 2008
    Hello everyone,
       As danycrash pointed out, it depends on the supply frequency. But I have the solution now. Do the following carefully. Before starting note that the stupid designer of this clock assumed that we are having a pure sinewave powersupply with constant frequency and even without any power failure. So my solution (I found out by doing some research on this :-) ) will work if you can guarantee continuous 50 HZ power supply That wont be possible in india I am sure.
     1. Open the box (you got 5 screws to remove , two of them hidden behind a body coloured lid at the top).
     2. Carefully open the case without damaging the switches and dials and other radio settings (remember this is Chinese made).
     3. Now you need to remove one screw (a black one) to take the circuit board out(with the LED panel).
    4. If you turn the pcb , you can see two ICs on it . One among them is sanyo ic Number LM 8562. This is one which controls the clock functionality of the device.
    5. Now you need a little bit of skill. You need to disconnect the Pin number 26 ( if you are not sure how to count the pins of an ic, observe the IC from top so that you can read the
       Part number written on it and from left to right its the third pin on the top line of this 28 Pin IC) . By using a wire cutter with sharp tip, carefully select that pin and disconnect it.
        (you can desolder it and pull also if you know how to use a soldering iron) using a nose plier pull the pin and bend it sidewards.
    6. now the IC is in mode 12 Hr with 50 HZ. If you want to make it 24 Hr , then you need to ground the pin instead of openig it. I didnt try this.
    7. So carefully replace the PCB and the device back cover with properly screwed in.
    Now your clock is synch with Indian power supply of 50 HZ ( remember you still need to used  220 to 110 volt adapter) .
    Since our power supply varies from 48 Hz to 50.5 Hz, you can expect the clock may lag around 1 minutes per hour. If you have an invertor with 50 HZ constant supply,
    then it should be accurate.
      Even in US, the supply frequency varies. I dont know why the circuit designer did like this.
      I have another one ICF-C318, which is accurate till today ( guess its using normal clock ciruits not depending on the power supply)
     Hope your device is working fine now.
     regards,
     Anand KRishnan
     Bangalore
Hello. I had the same problem, i found the solution. the clock is prepared to work on 60hz power network and you may have a 50hz one. It is possible to modify knowing a bit of electronic.
Posted on Jul 17, 2008
SOURCE:
How do you turn it on?
PDF]Download Manual - TIMEX Audio
https://timexaudio.com/media/uploads/product/.../T231_User_Manual.pd...
es you ntioned y order, her. Model T231. AM/FM CLOCK RADIO with DIGITAL TUNING. For questions or comments regarding this or other products, please call ...
[PDF]FM/AM Clock Radio - Sony
https://docs.sony.com/release/ICFC218_US.pdf Sony CorporationAutomatic time set - When you plug the clock in ... The radio or buzzer alarm does not sound at the ... modifications not expressly approved in this manual.
SONY ICF-C1 FM/AM Clock Radio - Unboxing and Review ...
? 10:28
https://www.youtube.com/watch?v=xgYV7X_AVBI
Jul 14, 2014 - Uploaded by VISHKI
Poor quality, difficult to tune manual tuner, flimsy buttons. The major disappointment is that the clock only shows 24 hour format time. Sony sells ...
[PDF]instruction manual Bluetooth Wireless FM C
Jan 03, 2016 | Audio Players & Recorders
I have numerous times in last 2 days how do I get an answer?. Here goes again . How do I reset time on sony dream machine serial no.4841857
1 Plug in the ICF-C218 in a well-ventilated area free of moisture.
  • 2 Press "Clock" if you are not in the U.K. and need to set the time manually. Hold it for two seconds.
  • 3 Press the + and - buttons until the year is set correctly.
  • 4 Press "Clock" once you've set the year, and repeat this process for the day, hour and minute.
  • 5 Slide the "Alarm Mode" toggle to either "Radio" or "Buzzer," depending on your personal preference.
  • 6 Slide the "Alarm Time Set" toggle to either the + or - side until you've reached the time you want your alarm to go off at. Hold it down to adjust in 10-minute increments
  • Read more: http://www.ehow.com/how_7396985_instructions-sony-icf_c218-clock-radio.html#ixzz2jjJEJSA3
    Nov 05, 2013 | Home
    Cannot reset time on sony dream machine model no. Oct-c218
  • 1 Plug in the ICF-C218 in a well-ventilated area free of moisture.
    Nov 05, 2013 | Home
    My sony radio alarm clock is too fast about 1 hour. i have moved in the philipines. but my alarm clock is working too fast; ie, it does not show the exact time (about 70-80 minutes) faster
    alarm clocks works on frequency and not only on voltage.if it is original 110v 60htz and you trying with 220v 50htz supply then it wont work correctly
    Jun 04, 2010 | Sony Dual-Alarm AM/FM Clock Radio with...
    How do you set the clock
    Clock setting procedure is written in user manual, click Sony Support to download a copy.
    Plug unit in AC, display will flashing AM 12:00
    Cress clock button for few seconds, unit will beeps and hours will start flashing.
    Press tuner/track+time set +/- button to change hours, again press clock button to change minutes etc.
    Hope this info will help you.
    Nov 24, 2009 | Sony ICF-CD543RM Clock Radio
    HOW DO I SET THE CLOCK ON MY RADIO
    Page 10 in this Owners Manual describes setting the clock.
    http://www.docs.sony.com/release/CDXFW700.pdf
    Press menu button. Press up or down repeatedly until 'Clock Adjust' appears. Press 'Enter'. Press up or down to set hour. Press > minutes flash. Press up or down to set minutes. Press 'Enter'.
    Oct 13, 2009 | Sony CDX-FW700 CD Player
    Sony radio/cd/clock under the cabinet. Lost
    On the right side there is a push button switch labeled "Clock". It is springloaded so you have to push it in and hold it for a couple of seconds until the unit beeps and the hour position starts to blink. The volumn up and down buttons will control the changing of the numbers up and down and PM/AM. Pushing the clock button again will change the clock to the minutes position and you cann adjust the numbers up or down just like the hours. Push it one more time will lock-in the new time. Your done.
    Jul 20, 2009 | Sony UNDER-CABINET LCD-TV DVD/CD CLOCK...
    How do I change/set the clock setting on my car head unit? (actually a CDX-GT150)
    press and hold the volume control and it should give you options on changing the clock.
    May 26, 2009 | Sony CDX-GT110 CD Player
    Sony MHC-2800 setting the clock
    Hi, it's simple. First press "Timer1" and Timer2" buttons together, clock on display will start blinking, by cursors "Up/Down" you can change the value of hours and minutes (switching between hours/minutes by "Left/Right" cursor). To save set time press "Memory". Enjoy your set clock :)
    Jan 07, 2008 | Audio Players & Recorders
    Sony ICF-C492 Clock Radio Logo
    534 people viewed this question
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Ekse
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
