Sony KV-21APV2 Good day.. I'm servicing this TV model...B+ is normal 115V without Horizontal output transistor,,but when i put this H.out transistor, regulator(str50115) becomes shorted,R2M diode shorted,and the N20 is open.... Whats the original No. of its flyback?is it 1-439-416? please send reply in my email... ihodiputah_510@yahoo.com Thank you.
5 Suggested Answers
SOURCE: Standby relay clicks on and off
Hi there!
I do not have the specs on your TV but this is standard on all TVs. Only different numbers. The Line or Flyback transistor is located next to the Flyback Transformer, usually mounted on a Big Heatsink. When removed and measured you should read a short between Base and Emitter on the Transistor itself. This is an internal Diode on the Package. Now make sure not to short anything when switching the TV on without the Transistor and then measure your Voltage on the board where the Transistor had been removed( between Base and Collector) 145V. Good Luck,JUS004
Posted on Mar 11, 2008
  • 275 Answers
SOURCE: sony tv H.O.T
Yup. Can be replaced with a simple BU 208D
Posted on Apr 09, 2008
ladywinn
  • 5138 Answers
SOURCE: Replaced Flyback Transformer and Horizontal Output Transistor
I am proud to see you got your set working Good job!
Posted on Aug 26, 2008
romsky79
  • 822 Answers
SOURCE: sony tv KV-27FS120, blinks 6 times, horizontal transistor is good, and driver to, can you help me?
check the memory.
Posted on May 31, 2009
SOURCE: find a horizontal output transistor or flyback
Flyback transformer part number for a tv RCA F32648
Posted on Aug 30, 2010
Sony 29 flat tv model KV-XR29M8O PICTURE HORIZONTALLY SIFTED
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Sep 25, 2016 | Sony FD Trinitron WEGA KV-XR29M80 TV
H out transistor defetive & number missing plz solve
Hello
The horizontal output transistor number for Sony KV-ES34M61
Horizontal output - [Q6807] == 2SC5480-01
Pin output - [Q6808] == 2SC5480-01 Again
Please replace bothe the transistor at the same time. Check horizontal output transformer [LOT of HOT], for any defects.. Ok
Jan 06, 2011 | Sony KV-ES34M61 34" TV
Sony FD Trinitron Wega Model KV-24FS 100 TV. Good morning from Arizona. The set is connected to Direct TV, and I use that remote, except when watching DVDs. A few days ago, the screen went blank, and the...
The 2X blink indicates that either the Horizontal output transistor is shorted, or the RGB amp is shorted (on the CV board).
The Horizontal output is probably the cause, and as a general rule, the flyback should be replaced along with the H-Out transistor. Good news is that Sony is pretty good about having parts in stock. In fact, a lot of times they will have the A board with all the parts on it for only a few bucks more than just the flyback, so you basically get a new TV (electronics-wise).
Any decent repair shop should help get the parts/do the repair for you if you don't have the electronic experience.
Hope this helps you...
Jan 09, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony 27s42 broke the horizontal output transistor
Be sure to make sure the connection on the horizontal driver transformer are soldered good. check caps around HOT
May 23, 2008 | Sony KV-27S42 27" TV
TV - worth fixing or pitch?
Horizontal output and regulator transistor often short out on this model causing a dead condition. Also the resistor right next to the regulators goes open as well. Electronix.com has a sony repair kit to fix the power supply. You just have to check the numbers on your Horizontal output transistor to make sure you get the right kit for your model.
Feb 03, 2008 | Televison & Video
Sony wega model KV-32FS12
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Timer light blinking
POWER SUPPLY PROBLEM.YOU MUST HAVE SOMEONE REPLACE TWO TRANSISTORS,VARISTOR,FUSIBLE RESISTOR,4 CAPACITORS & HORIZONTAL OUTPUT TRANSISTOR & RESOLDER PINS ON HORIZONTAL DRIVER TRANSFORMER.GOOD LUCK.4TUNE
Dec 05, 2007 | Sony KV-35S42 35" TV
1996 Sony 32" Trinitron - Suddenly lost picture and sound
The most common problem with TV was the failure of the Horizontal Output Transistor, this will also damage 2 transistors in the power supply and a resistor in the power supply also. (From memory): Horizontal Output location # Q501, 2 power supply transistors Locations Q601, Q602, and resistor Location R607. Also solder the Horizontal drive transformer, you can find it by following the circuit board from the base of the Horizontal output. Some models used an IC instead of the 2 transistors in the powersupply, it will have six legs and check like 2 transistors. Good Luck.
Jun 04, 2007 | Sony KV-32S26 32" TV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
