How do you replace flooring. - Washing Machines
2009 buick lacrosse console gear indicator bulb
Transmission Floor Shift Control Indicator Lamp Replacement
Remove the front floor console. Refer to Front Floor Console Replacement.
Rotate the floor shift control indicator lamp socket (2). Pull the socket from the trim bezel.
Remove the bulb from the socket.
Preliminary Procedures
Remove the rear floor console. Refer to Rear Floor Console Replacement.
Remove the instrument panel lower trim plate. Refer to Instrument Panel Lower Trim Plate Replacement.
Set the parking brake, then shift the transmission into drive and push the shift indicator down until it locks, to allow clearance to remove the console.
Front Floor Console Screw (Qty: 2)
Caution: Refer to Fastener Caution in the Preface section.
Tighten
2 N·m (18 lb in)
Front Floor Console Bolt (Qty: 2)
Tighten
10 N·m (88 lb in)
Front Floor Console Assembly
Front Floor Console Retainer Clip (Qty: 2)
Feb 24, 2017 | 2009 Buick LaCrosse
Center console removal
Well, this good to be interesting to say the least, and probably long as well. By my gm. service information your going to need to take out the front bucket seats so the sides of the console can come off.
Remove the left front seat . Refer to Bucket Seat Replacement .
Front Floor Console Extension Panel
Retainer Clip (Qty: 5) same for right side.
showgif.do?image=1875475
Callout
Component Name
Remove the right front seat. Refer to Bucket Seat Replacement .
Front Floor Console Accessory Trim Plate Assembly
Procedure
Use a flat bladed plastic trim tool in order to release the console accessory trim plate from the console assembly.
Retainer Clips (Qty: 5)
Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement.
Front Floor Console Accessory Housing Screw (Qty: 2)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
2 N?·m (18 lb in)
Front Floor Console Accessory Housing Assembly
Procedure
  1. Disconnect the electrical connectors.
  2. When replacing the front floor console accessory housing assembly, transfer all necessary components
  1. Remove the rght or left front floor console extension panel. Refer to Front Floor Console Extension Panel Replacement - Right Side or Front Floor Console Extension Panel Replacement - Left Side .
  2. Remove the front floor console cup holder housing. Refer to Front Floor Console Cup Holder Housing Replacement .
Front Floor Console Rear Trim Panel Screw (Qty: 1)
Tighten
2 N?·m (18 lb in)
Retainer Clip (Qty: 4)
  1. Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement .
  2. Remove the right and left front floor console fillers. Refer to Front Floor Console Filler Replacement .
Front Floor Console Armrest Assembly Bolt (Qty: 4)
Tighten
9 N?·m (80 lb in)
Procedure
Position the armrest assembly out of the way leaving the electrical harness attached.
Front Floor Upper Console Trim Plate
Procedure
Lift the rear of the trim plate first, releasing the retainers securing the trip plate to the console assembly.
Retainer Clips (Qty: 4)
Front Floor Console Replacement (Enclave)
showgif.do?image=1858392
Callout
Component Name
  2. Remove the right and left front floor console extension panels. Refer to Front Floor Console Extension Panel Replacement - Right Side and Front Floor Console Extension Panel Replacement - Left Side .
  3. Disconnect the automatic transmission range selector lever cable. Refer to Range Selector Lever Cable Replacement .
Tighten
2 N?·m (18 lb in)
Front Floor Console Bolt (Qty: 10)
Tip
Before installing the right lower forward bolt, ensure that the console wiring harness is tucked below the fastener location to avoid driving the bolt into the harness.
Tighten
9 N?·m (80 lb in)
Procedure
  1. Note location and routing of the front floor console wiring harness prior to removal of the front floor console assembly to ensure proper reinstallation.
  2. Disconnect the electrical connectors.
  3. With the aid of an assistant remove the console assembly from the vehicle.
  4. When replacing the front floor console, transfer all necessary components.
h4hqqpweof7+aaaaaelftksuqmcc
arzs+0tf0j6faaaaaelftksuqmcc
Jan 10, 2015 | 2008 Buick Enclave
What needs replaced on 2011 evergreen ever-lite 25RG travel trailor after submerged in river water up to floor for 12 hours
Depends on the construction of the floor. If it is the composite floor that is a layer of luan, Styrofoam and luan. Then the entire floor will need to be replaced. Heavy moisture will cause the glue to release and the floor will fail. The walls may also cause an issue if the water permeated them causing the insulation to get wet. Mold will begin to grow and could cause heath problems down the road.
May 19, 2014 | Evergreen 2011 Ever-Lite 25 RB
I would like to replace the flooring on my RV half is wood and the other is carpet i would like to have all wood how do i get under the slide outs
The carpet is probably glued down and also recessed under the wooden sections. To remove the carpet section is pretty easy, simply take a stanley knife or any heavy duty blade and cut out a small section of carpet near to the edge of where the carpet meets the wood and use this opening as a hand hold to lift the rest of the carpeting from the actual floor of the rv. You can then use a putty knife or similar tool to slide under the wooden sections and lift them. You can buy laminated wooden flooring in sections and replace the entire floor with this, using a jigsaw to cut the edges to match the outline of the surrounding areas. Hint: use pieces of sturdy cardboard to make templates of any edges that are not straight and transfer the outline to the flooring panels with pencil before cutting to ensure a good fit.
Aug 18, 2013 | Building Materials
What are the advantages of laminate flooring over hardwood flooring?
First, you can get the exact visual design that you wanted and it will cost you considerably less. Second, laminate flooring can be installed above and below the grade unlike hardwood flooring. Moreover, the laminate flooring is installed without using any nails or glue which make it much easier to it yourself. Furthermore, laminate flooring is extremely durable, easy to maintain and can be replaced easily.
Feb 06, 2013 | Building Materials
Kitchen floor
You have to replace the floor joists. This is accomplished with bottle jacks to raise the floor high enough to fit new floor joistsalong side of the old ones.
Its best left to somebody who is experienced in construction
Sep 07, 2009 | 2006 Eagle Talon
How to remove heater core from 2000 Pontiac Montana. Antifreeze leaking on floor.
Wow I hope youre mechanicly inclined, big job the entire dash & carrier have to come out 7-15 hr job if you know what you are doing to much to list hear I would check heater hoses at fire wall first make sure they arnt leaking. I wish you well
Aug 31, 2009 | Pontiac Montana Cars & Trucks
J20 Floor Pan replacement
I don't know if the 715 floors work in a J-series, but they should be real close. Jeepanels plus make a quality product.
May 14, 2008 | 2006 AMC J20
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
