Question about Gateway FPD1765 17" Flat Panel LCD Monitor
My Monitor flickers when computer starts
I bought this monitor at a yard sale and it worked. when i got it home the screen was blank with white lines on it. i messed with the crt connection and it can on but it stills flickers and goes blank from time to time. please tell me what i can do to fix this problem. thank you in advance...
  • 624 Answers
If "messing" around with the CRT connection on the back of the monitor causes it to work then I suspect there is some physical damage to. Specifically what connection/connector did you mess with? I can give you more advice if you give me more to go on.
Posted on Jul 15, 2007
SOURCE:
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Monitor has horizontal lines on half the screen but only sometimes
I would just replace it, the cost to troubleshoot and repair will be more than new.
Jul 13, 2017 | Samsung Computers & Internet
Monitor flickers with lines across screen
screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
May 28, 2011 | Norcent Technologies LM-965WA Monitor
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
New monitor flickers when hooked to computer
Hi!
There's a few usual culprits for this problem.
  1. Check the cable. Swap to a different cable if possible to rule that out.
  2. Check the refresh rate of your monitor. Most monitors have options for this via a Menu button on the screen itself.
    If you find it, change it to 60 hertz
  3. Check the refresh rate of the monitor from your operating system/video card's software.
    In Windows, right click on the desktop, click Properties, then the Settings tab, then Advanced. Change it to 60 hertz if it's anything different.
It could be faulty but hopefully not.
Couple of things there to try...let us know how you go
Nov 21, 2009 | Samsung Computers & Internet
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Computers & Internet
Gateway FPD1765 17" Flat Panel LCD Monitor Logo
110 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
