Osaka gas model 43-558 - Heating & Cooling
My osaka gas heater 140-9173 is not switching on rather a green light on key is permanently on. in this case how to switch on the osaka gas heater
The green light means it's in standby mode. Make sure the child lock is not on and that it's not in timer mode. Also, check to see if the heater is dirty on the inside, unplug and clean as necessary. Make sure that the gas supply line valve open and that you have pressure in the line. The over heat thermister could be tripped and the whole unit needs to be unplugged and then plugged back in.
Jan 21, 2017 | Heating & Cooling
Osaka gas 43-564. what's the meaning of writing on panel
I need user manual (in English) for OSAKA gas heater 43-564 model
Jan 25, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Hi, I have Osaka Gas Heater model 43-540.
A natural gas heater can only burn natural and vice versa unless there are changes such as orifice and regulator. They can easily be converted to use either fuel, but you have to know what fuel supply you have, and what the appliance is set up for. Since you've already tried LPG, if it turns out the appliance is natural gas, then replace the spud (burner nozzle) before trying to operate it again. LPG cannot pass through the small nozzle hole in a natural gas appliance.
Nov 25, 2013 | Heating & Cooling
Osaka Gas Blower Heater Model: 43-553 The heater takes a very long ignition and then gives error 11 or 12 .. Another heater is functioning ok on the same line so there is no problem of gas pressure .
It sounds like a gas line or gas jet is clogged. Clean off the gas tip that is near the electronic igniter. Also find a small diameter wire to clear any obstruction in that jet. Also, carefully clean off the igniter tips.
Jan 11, 2013 | Heating & Cooling
Hi i need English Language manuals for Osaka Gas Fan Heater Model 43-659... as the operating buttons of the heater is in Japanese Language. by mis handling it i got its timer ON. now dont know how to fix...
I have gas fan heater made by Tokyo Gas, model MA-A630TFH.
on the front pannel all the language is jAPENESE. PLEASE HELP ME AND MANAGE FOR OPERATIONAL MANNUAL IN ENGLISH.
Oct 20, 2012 | Heating & Cooling
Osaka gas heater manual
DOWNLOAD LINK
http://www.dl4all.com/aka/tag/osaka+gas+fan+heater+user+manual.html
OR
http://www.osakagas.co.jp/indexe.html
Jan 24, 2012 | Water Heaters
Heating & Cooling Logo
165 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
