Question about Toshiba Satellite A85-S107 Notebook
Dvd drive not recognized
On a toshiba a 85. does not show up in windows explorer,or elsewhere. does not have power. door does not open. tride the registery changes on upper and lower limits. did you mean for me to delete both the upper and lower limit values?
  • eeneremadu Feb 24, 2009
    The cd rom is not recognized on my A85-S197. P.lease help
L755-s5311 dvd not reading dvds or cds,
Your choices are to replace the drive or purchase an external DVD drive.
DVD/CD drives do eventually go bad.
Feb 05, 2014 | Toshiba Satellite Laptop Coretm Intel...
Computer BIOS recognizes the SATA DVD Rewriter but Windows XP does not. The drive opens the loading door but it does not appear in the Windows XP explorer (My Computer).
Windows XP doesn't nativey support SATA. Check in BIOS to see if your motherboard supports sata to IDE emulation.
Comment back if you need further assistance.
Aug 17, 2011 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
I have a Toshiba L305-s5955 and my dvd drive has disappeared. How do I get it back? Thanks.
If the DVD drive has disappeared in the windows explorer.
Here's the step.
1. Go to Start, on the start search box,type REGEDIT and enter. A registry editor will come up.
2. On the left pane of the window, there are folders.
Open HKEY LOCAL MACHINE/open SYSTEM/open Current Control Set/ open CONTROL/ open CLASS/ open the 4D36E965...folder
3. After opening the 4D36E965, on the right pane of the window, under name look for the lower and upper filter files, or even just one of them and DELETE.
4. Then restart NB to take effect.
5. Check in the windows explorer if the DVD-RW drive is back on the list.
6. Insert a disc to check.
Feb 27, 2011 | Toshiba Satellite® M115-S1061 PC Notebook
Using Windows Vista on Dell Dimension Desktop: Windows Explorer does not show a DVD drive. The eject-close button does not extend or retract the disk tray. I have opened the tray manually with a...
try method 5 listed on this site:
https://support.microsoft.com/en-us/help/314060/your-cd-or-dvd-drive-is-not-recognized-by-windows-or-other-programs
May 22, 2017 | Dell Dimension E521 PC Desktop
I have a compaq presario cq 60 laptop with Vista - i don't understand how to access the CD-ROM drive - I would normally expect it to appear as an additional drive using the Explore function, but I can't...
Normally it would show up in "my Computer" as a drive, if it is not, then the computer is acting like it is not installed or not enabled. Go to the device manager and look for the dvd drive there and see what the properties say. Put the computer on its back and with a small phillips screwdriver, remove the screw that holds the drive to the motherboard. Now flip the laptop back on its feet and insert an open paperclip into the small hole in the door of the dvd drive bezel, this willphysically trip the door to open. Pull the door and tray out and keep pulling and the rest of the drive will follow. Power up your laptop with the drive missing and access "My Computer" and see if anything changes. Now,power down the laptop, remove the battery....wait 30 seconds and slide the drive in and make sure it seats all the way in, replace the hold down screw, replace the battery and power it up. Let windows recognize the drive and load drivers for it. If it does not read the drive, there may be an issue with either the interface on the drive or the socket on the motherboard.
Oct 04, 2009 | Compaq Presario CQ60-220US PC Laptop
Will not read any media dsick in DVD combo drive
The disk should actually show up in the My Computer window as a removable drive. Right click on the icon, and select explore.
You should be in the file now.
Mar 16, 2009 | Averatec Refurb Centrino 1.3GHz 512MB 40GB...
DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Tecra 8100 PC Notebook
if it can boot up windows, then the harddisk is not locked(anymore, after entering the correct password),
a slow performance of windows can be sped up by performing a harddisk defragmentation (open windows explorer, right-click onto harddisk, switch to properties,´then 'extras', perform a defragmentation for drive c:, give it time to finish)
to fix the arkward dvd/usb prob:
again open up win explorer and see if cd-rom drive is available, therefore recognized by windows at all.. if yes test-insert Original CD again, see if it can open it(does the CD/DVD-drive LED flash green several times and do you hear any noise from it?)
if not, shut down and enter BIOS while booting hitting either the Del,F1 or F2 button and look if under IDE devices the CD-is recognized by the laptop itself...
if not, set auto detecton for IDE- devices, go
through available menus until u find USB legacy support, enable as well, exit saving changes, reboot.
Again enter BIOS then change
BOOT DEVICE order sothat CD-drive is 1st,
any 3.5'' floppy drive second and harddisk 2nd or 3rd, exit saving changes again.
reboot and let windows come up again. check for cd/dvd-drive again(see procedure as described above), check if windows does recognize your usb-device(mp3 player) now.
if that does not work and during booting you get message'bad CMOS checksum error' you will have replace the CMOS button-battery on
the mainboard, for it may have gone flat...
this means disassembling the laptop
if that is the case, see a technician to work for you or come again with another query.
hope i could be of help
Oct 20, 2008 | Toshiba Tecra 8100 Notebook
Siren MP3 player not recognized by Windows Explorer‏‏
Installing the latest Windows Media Player solved the problem.
Oct 02, 2008 | Siren Edge MP3 Player
CD / DVD player not listed as device on Windows Explorer
Try physically removing the player and fire up the laptop. Power down the laptop, replace the player and power back up. If that doesn't help, see if BIOS recognizes it.
If that doesn't work, get back to me.
Ron-
Nov 09, 2007 | Computers & Internet
Toshiba Satellite A85-S107 Notebook Logo
124 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
