Error code 5. Memory lost?
The cycles on the washing machine seems to be wrong
  • gert191
    gert191 Jan 21, 2013
    Thanks. The problem were that the main outlet pipe from the drum to the pump were clogged due to coins. Once removed, the machine worked perfectly..
  • Washing Mach... Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Posted on Jan 19, 2013
  • 3 Answers
SOURCE: error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Posted on Jan 26, 2009
  • 1294 Answers
SOURCE: Zanussi ZWD1471W Washer Dryer error codes help please!
Click on Zanussi (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 05, 2007
jsrock516
  • 5911 Answers
SOURCE: washing machine blinking f-24 error code.
"F24" is a Water Temperature Sensor error or Heating Circuit failure. The first step to troubleshooting these washers is to unplug the unit for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes the error codes can be erroneous and a simple reset of the CCU will correct the problem. If the error code reappears following a CCU reset, you have a genuine problem.
If the error code comes back, check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Check to make sure the connector is still plugged in. The connector can become loose or unplugged due to vibration. If the connector appears to be okay, unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
I hope you find this information helpful. If you have further questions, please let me know.
Posted on Apr 12, 2009
localwonder
  • 6784 Answers
SOURCE: dE code on WM0642HW TROMM washing machine
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Posted on Jul 12, 2009
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Kenmore he4t washer codes
The control for the washer likely detected a problem. The failure code will not be displayed on all models of washers. You can recall the error code by using this procedure:
  1. Select the "Drain/Spin" cycle.
  2. Select No Spin.
  3. Press the "Prewash" options and hold this button for 5 seconds.
  • Immediately after those 5 seconds the last stored failure code is displayed for 4 seconds.
  • After those 4 seconds the display switches automatically back to the selection mode
NOTE: If your washer does not have the Pre-Wash option. Then use the 2nd Rinse button (called Extra Rinse). The failure code should stay in the memory so that it can be recalled as often as necessary and as long as it is the youngest failure Code.
Nov 30, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My washing maching is reading E20 and it is not washing. it seems to stop after a few minutes of washing and then it will read E20 and just continuosly beep
Hello.
Frigidaire front-loading washing machines have an electronic control panel where the wash cycle and any other wash options are selected, and the wash cycle is initiated and stopped, if necessary. The control panel also has indicator lights that show the washer status and will display an error code if there are issues with the washer. The "E20" error code indicates a possible pump problem.
Blocked Pump
One of the primary reasons why there may be an "E20" error code on a Frigidaire front-loading washing machine is if there is something blocking the pump. Disconnect the washing machine from the power and release the clips on each side to remove the front access panel. Set a container under the pump drain, which is located on the lower right side of the washing machine. Open the pump drain plug and allow it to drain. Clean out any debris that might be causing the obstruction, then close the drain plug. Close the access panel and restore power to the washer.
Drain Hose
If the drain hose is blocked or crimped, the water may not pump out fast enough, causing the pump error to appear on the display. Straighten out the drain hose in the rear of the washing machine and move it away from the washer if it's trapped between the wall and the washing machine.
Oversudsing
If too much detergent--or the wrong kind of detergent--is used in the washing machine, too many suds may result. This can overwhelm the drain and pump system, resulting in the error. Use only high efficiency (HE) laundry detergent with Frigidaire washing machines and follow specific instructions on the laundry container for the recommended amount of detergent. Run a drain cycle if there are excess suds in the washer to clear out the system.
Pressure Switch or Control Boar
The pressure switch may not be communicating properly with the control board, which can cause the E20 error to occur. The other possibility for the E20 error code is if the control board has failed entirely. Try to reset the washing machine by pressing "Stop/Cancel" and disconnecting the washing machine power cord. Wait 30 seconds, then restore power. Make a new cycle selection and press "Start" to see if the error code returns. If it does, turn off the washing machine and contact Frigidaire for repair.
Thanks.
Nov 08, 2011 | GE Energy Star WCVH6260F Front Load Washer
My machine is displaying code F01. It comes up at the end of the wash cycle. However, It doesn't seems to be actually washing the clothes anymore. The water runs in and out of it , but I don't...
I tired answering yuor post and there is a problem with the website. I have reported same to the website staff. You should see my post via email soon
Kelly
Sep 24, 2011 | Washing Machines
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 02, 2009 | Washing Machines
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
Jul 11, 2009 | LG Washing Machines
Washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Nov 20, 2008 | LG WD-1280FHD Front Load Washer
Error code SD
I work for an appliance company in the service department, and what this really means is that you could have a suds build up in your machine, or that you used too much soap on this particular cycle. If starting over does not work, you can buy a product called washer magic at almost any store and it will clean your machine out. Also, running vinegar through the machine will make any suds dissapate.
Nov 14, 2007 | Maytag Neptune MAH6700A Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
