Question about Garden
Snow Blower engine runs very rough
I was given a Mastercraft snow blower with a Tecumseh 5 HP engine Mod # HS 50 - 67258H Ser # 8267B. I cleaned the rust of the fly wheel and magneto install new plug, unit runs very rough and dies when in gear and the auger is on. My question is can the carb be over hauled? How does the bowl come off? can the whole carb be submerged in carb cleaner?
  • womac Jan 27, 2009
    Thanks I'll get a new kit and go from there Thanks
  • 3 Answers
YES THE CARBURETOR CAN BE OVERHAULED
THE REPAIR KIT PART # IS 31840 , THE BOWL IS REMOVED BY REMOVING THE BRASS NUT ON THE BOTTOM WITH A 7/16" WRENCH.YOU MAY NEED TO REMOVE THE WELCH PLUGS FOR A GOOD CLEANING. NEW PLUGS COME WITH KIT. YOU CAN SOAK CARB. IN CLEANER SHOULD BE NO LONGER THAN 15 MINUTES. ALWAYS USE NEW GASKETS. ADJUSTMENTS TO BE DONE WHEN ENGINE IS WARMED UP.
Posted on Jan 26, 2009
Tecuseth Snow King Engine. Starts fine. When I engage snow blower engine dies.
couple of things come to mind. Safety switch. Engine not running at full speed or snow thrower is locked smooth up
Dec 17, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
5 hp tecumseh no power
you need to remove carb for cleaning... if it has an adjustment on the bottom of carb try turning it SLOWLY in and out... also possibly a screw on the side under a black cap... might try it as well engine model number would help here
Dec 11, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
How do I replace the belt on my tecumseh 11hp snowblower
tecumseh didn't make a snow blower... they made the engine but I don't recall them ever making a snow blower... get the model number off of the snow blower and then ask
Dec 03, 2013 | Garden
Craftsman 32" 10 hp
3600+/- 20rpm. That's the top end, I'd say idle should be between 1200 and 1500, but I don't know what model motor it is. I'm assuming its a Tecumseh snow king engine
Nov 22, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Mtd snow blower 8 hp oil capacity
What engine do you have? Tecumseh those are usual 18-21oz Not sure with briggs, but will be around a 1/2 qt (16oz) start there. Add a little at a time to bring level up. get back if you have and need more specifics.
Oct 30, 2012 | Mtd Genuine 9460897 Snow Blower Auger...
Can't keep my snow blower running under load, cleaned carb, but do not know adjustment procedure for a tecumseh 7.5 hp 15 year old snow blower
there should be an ajustment screw on the carb. turn it all the way in don't turn it hard then turn the screw back out 1 1/2 turn to start out with then after runing turn till it runs evenly.
Dec 20, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Tecumseh Snow King HS40 engine only runs on full choke, no power
i did and thanks - just picked up one that does the same thing and i plan to take your advise
Thank you Jerr
Jan 01, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
458 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
