Question about RCA TruFlat 27F520T 27" TV
TV turns off than on, off than on, until I unplug it.
After my television has been on for a half hour or so it starts to turn itself off than on, off than on again, and so on so forth. It continues this behavior as long as there is power to the device.
  • Anonymous Jan 20, 2009
    my tv turns of and on , the volume goes up on bust and wont answer ton remote or tv-- goes through setup and dont finish
Perhaps glass cleaner has dribbled from the screen during cleaning, onto the front panel switch assembly. That seems to be a common problem with this model.
Posted on Sep 09, 2007
If you haven't tried this, go into the menu, under "Time" see if the "time on" and "time off" feature is on, if so, turn it off.
Posted on Aug 06, 2007
6ya staff
SOURCE:
Tv works fine until you turn it off, when you turn it back on the green light shuts off and the tv totally dies, the red light thats on when its turned off is not working either. Now if you unplug it for...
check all caps in the power supply especially the 10mf 22vols cap.the caps are not filtering the voltage properly when the the current i off the caps drain the voltage and does not keep charging.until when current is applied to the set.good luck.
Feb 21, 2010 | Philips Magnavox 27MS343S 27" TV
Turns itself on and off every few seconds. The blue light at the front of the TV stays on steadily during this process. Tried unplugging it but made no difference.
When you unplugged it, did you leave unplugged for quite a few hours? And in the meantime of being unplugged, did you press and hold the power button for 5 full seconds, and then wait half hour more to plug back in? If you did this and it still is the same, then you likely have either a loose wire or solder joint or your high-voltage transformer is likely bad.
Jan 23, 2010 | LG 32LH30 32 in. LCD HDTV
Sleep timer will not shut off We can not turn it on to shut it off.
unplug for a quite few hours, press and hold power button for 5 full seconds while it is shut off, then wait half hour more and plug back in and it should reset itself.
Jan 22, 2010 | JVC AV-27D203 27" TV
My Mitsubishi Medallion 1080 won't turn on
Are you sure its the right remote? Verify TV mode on remote if equiped with mode switch. Drain the remote by removing batteries.
Jun 27, 2009 | Televison & Video
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
TV turns on & off
Hi there!
Exterior equipment attached to a standard tv cannot cause the set to switch on/off by itself.
I think you may have a power supply fault or else loose solder connections on the board, hence the "warming up" intro before the fault shows itself.
My suggestion would be a service technician if you are not familiar with electronics or TV's. Regards, JUS004
Mar 23, 2008 | RCA TruFlat 27F520T 27" TV
Ws 65909
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Dec 30, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Apex pf2025 20 inch tv
timer set in menu options. Mine did the very same thing until I cleared the timer
Oct 13, 2007 | Apex Digital PF2025 20" TV
RCA TruFlat  27F520T 27" TV Logo
138 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
