Question about Microsoft Office Publisher 2007 for PC
How to recover a corrupt file on a publisher 2007
I cant open my file.. it says, the publisher cannot open the file. This file may have been corrupted during download.To open this file, try to download again.
antiochpc
  • 1314 Answers
SOURCE: file is corrupt
This usually happens when something happens during the transfer. Try to redownload it.
Posted on Jul 05, 2008
  • 16 Answers
SOURCE: I'm using MS Publisher 2007 and pdf creation problem
  1. On the File menu, click Publish as PDF or XPS.
  2. In the File name list, type or select a name for the publication.
  3. In the Save as type list, click PDF.
  4. Next to Optimize for, click Change.
  5. In the Publish Options dialog box, click the optimization in the Specify how this publication will be printed or distributed list that matches the needs of the publication. For example, if the publication will be distributed online and print quality is less important than a small file size, click Minimum size. If the quality of the printing is more important than file size, click High quality printing.
  6. Click Advanced to display the entire dialog box, and select the settings that you need. (Find links to more information on these options in the See Also section.)
  7. Click OK.
  8. In the Save As dialog box, if you want to open the file immediately after saving it, select the Open file after publishing check box. This check box is available only if you have a PDF reader installed on your computer, and if the Commercial Press option is not selected in the Publish Options dialog box.
  9. Click Save.
Posted on Feb 12, 2009
Squirm57
  • 152 Answers
SOURCE: how to recover corrupt files for .doc
This link has a couple fixes you can try: http://www.tech-pro.net/how-to-word-document-recovery.html
Posted on May 07, 2009
ginko
  • 19396 Answers
SOURCE: some of the files needed to play video are missing or corrupt
When that happens you usually need to backup your data, and reinstall the system to fix Windows corrupted files.
Try first doing a system restore to the most recent date before you started having the problem. If system files are damaged this will not help.
Posted on May 16, 2009
  • 323 Answers
SOURCE: Corrupted Money backup files
There are a few things you can do. Manually open up the *.mbf file, does it open?
If it doesn't, the file type *.mbf may not be associated to Money 2007 anymore. Very common.
If the file becomes too large they also become corrupted. It may be possible to export the *.mbf file to Microsoft Excel. Make sure you create a copy of the file before manipulating it.
http://support.microsoft.com/kb/279274
Actually.... if you have a system administrator. They should have a back up tape, you should already have a path to the file you can give them. They can do a backup and restore of a day or two ago and see if that mbf file was not corrupted as well.
Let me know if I can be of anymore help =)
Posted on Jun 12, 2009
How to recover MS Word 2007 Corrupted files
Here's where to look;
HD > Users > [my user name] > Library > Containers > com.microsoft.Powerpoint > Data > Library > Preferences > AutoRecovery > Presentation1_autorecover
Copy the file to the desktop and change the extension to .pptm and then double click it. Should be good to your last auto save point.
Cheers and best of luck.
Maybe you can try uFlysoft Data Recovery for Mac, it can recover empty trash on Mac only in three steps:
Step 1. Launch the software to scan the device where your files deleted
Step 2: Preview the scan result files and make mark if it is the one you find
Step 3: Recover files
Mac Word Document Recovery How to Recover Lost Deleted Word Document on Mac
May 14, 2015 | The Computers & Internet
How to restore pdf files?
You can use Google Chrome, use the shortcut key Ctrl P, under the Destination use the Change button and select PDF (or PDFCreator) but if your file is corrupted, you will need - PDF Restore Toolbox read it
http://www.pdf.restoretools.com/
Apr 17, 2015 | Microsoft Office Professional 2007 Full...
How do I repair supposedly corrupted MS Works Word files?
Many of the OLD files will not work with a newer version or the program. just a fact of life from microsoft software
Mar 16, 2015 | Microsoft Office 2007 Professional
Is it possible to recover corrupted PDF?
You can try to recover it with PDF Open File Tool http://www.pdf.openfiletool.com/ This tool should help you with it. Good luck!
Feb 24, 2015 | Adobe Acrobat v.X Pro - PDF Application -...
Corrupt DWG files
AutoCAD RECOVER command?
If doesn't help, try it:
DWG Repair Kit
This professional AutoCAD DWG repair tool features a uniquely efficient data analysis core and an interface that both professionals and novices with appreciate. The program will show you how to repair DWG files online in seconds even if you have never worked with data recovery tools of any sort!
For more information: http://www.dwg.repair/
Also look here: https://social.technet.microsoft.com/Forums/en-US/fb2d8693-9551-43b7-9310-584471d60a56/autocad-files-corrupted?forum=w7itproappcompat
Feb 17, 2015 | Autodesk AutoCAD 2007
I want to open powerpoint presentation.
then, go to format -> slide design, choose to show all documents, and choose the corrupt powerpoint file. now, go to insert -> slides from file, and select the corrupt powerpoint file. make sure you are set to insert all slides, and then import. if that works, great! i suspect, however, that you might crash at that point. if so, try repeating the process, inserting specific slides one by one until you find the problem one. after that, save the file, making sure that fast saves are off (in preferences / save).
if you are unable to open your powerpoint files then try pptx viewer tool. this utility recovers your corrupt and damaged powerpoint presentations (.ppt, .pot, .pps, pptx and ppsx formats) from ms powerpoint files. http://www.pptx.viewertool.com/
visit:- http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/1128-how-do-i-recover-a-corrupt-p-point
http://www.pptx.viewertool.com/ http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/1128-how-do-i-recover-a-corrupt-p-point
Jan 19, 2015 | Microsoft PowerPoint Computers & Internet
How to recover Excel lost file
How to solve some troubles with excel files you may learn from- http://www.filerepairforum.com/forum/microsoft/microsoft-aa/excel/481-%E2%80%8Bexcel-files-corrupted
How to Recover an Excel File for Free
1.Check the Recycle Bin--if you've accidentally deleted the file, it should still be there unless you've emptied the bin, and you can click on the file and recover it.
2.Use the Auto Recovery Pane when you open Excel. Review the document recovery pane. If Excel has managed to recover your file, it will show in a separate pane on the left-hand side. Identify your document in the pane, then click on it and choose "Open" to open the recovered file.
3.Try manually repairing the file. Click on "File" in Excel 2003 or the "Office" button in
Excel 2007, then select "Open" and click on the arrow next to the "Open" button. Click on
"Open and Repair" and choose from two options: click on "Repair" if you want to try to completely recover the file, or click on "Extract Data" if you previously tried Step 1 and it did not work.
4.Search for the file manually on your computer. When performing a system search (click "Start" and select "Search" in Windows XP and Windows 2000, or press the "Windows" button and "F" key in Windows 7 and Vista), make sure you choose "Advanced Search Options" and then check the "System and hidden files" check box. You may be able to find your missing or corrupted file using this search: double-click on the file name in the search results to open it.
If nothing can help you, look at Excel Repair Toolbox
As a solution, it costs money, but effective- http://www.excelrepairtoolbox.com/
Nov 11, 2014 | Microsoft OFFICE 2013 PROFESSIONAL 1 PC...
Ms word 2007 file are corrupted how to recover it
One can easily repair MS Word file 2007 using third party software like word repair software. This software works efficiently to repair corrupted documents because it has inbuilt strong scanning algorithm.
Jan 03, 2013 | Computers & Internet
Microsoft Office Publisher 2007 for PC Logo
145 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
