Question about Mitsubishi HS-U570 VCR
Need a manual for Mitsubishi VCR HS-U67
We have a tape stuck in the vcr and need to get it out. To save the tape without damaging the vcr would be the best. We're looking for help.
dodgecharger
  • 254 Answers
SOURCE: VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Posted on Jul 10, 2007
SOURCE: Mitsubishi HS-U447 VCR in Lock or "Loc" mode
Hopefully you still the VCR. Your's is stuck in "CHILDLOCK" mode. To release the lock you have to have the remote and press the DISPLAY for 8 to 10 seconds.
The purpose of the CHILDLOCK is to prevent others from using your VCR. If you want to set the VCR back on Lock you again press the DISPLAY for 8 to 10 seconds.
This solution is from the owner manual for HS-U448, so I figure your model is the same.
Posted on Jan 18, 2008
sharcnet
  • 2130 Answers
SOURCE: Mitsubishi HS-U61 SVHS
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor. Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft. You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved. Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism. Please let me know if I can be of further assistance Good luck! - Jim
Posted on Feb 28, 2008
  • 103 Answers
SOURCE: I am in need of User Manual for Mitsubishi VCR
you can get your manual here ,,,,,,
Mitsubishi Digital Electronics VCR HS-U570
Posted on Apr 07, 2009
SOURCE: My Mitsubishi VCR HS-M60V rejects cassette tape
Take it to a technician
Posted on Aug 28, 2009
How to Remove a Stuck-Up Tape
Take the top of the VCR off and remove it manually. If you don't do this you risk ruining the tape.
May 03, 2011 | Mitsubishi HS-U760 S-VHS VCR
I have a Mitsubishi HSU48. The tape is stuck in the VCR. I cannot get it out. Do you have any suggestions
I had this problem with this specific machine. These answers have all been general to any VCR. The Mitsubishi HS-U448 has its motor underneath the machine. You don't have to remove the top cover at all. Just remove the bottom plate and spin the motor (the correct direction) to completely eject the tape.
Dec 23, 2010 | Mitsubishi HS-U448 VCR
Tape stuck will not eject
open vcr look for a belt on the right side of the vcr and begin manually turning it until the tape ejects
Jan 04, 2010 | Mitsubishi HS-U770 S-VHS VCR
A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
Sep 22, 2009 | Televison & Video
Getting E2 error flashing on vcr and can't rewind tape or anything.Don't have user manual to see what that error means.
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
Aug 28, 2009 | Mitsubishi HS-U445 VHS VCR
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Language setup for Mitsubishi HS-U510 VCR
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
Mar 06, 2007 | Mitsubishi HS-U447 VHS VCR
Televison & Video Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
