Question about Soyo DYLT032D 32 in. LCD Television
Soyo tv will not pick up digital over air channels
When I did the air auto scan it only picked up two channels. How can I get more channels?
The auto scan picks up whatever channels are available, if it only picked 2 then that is all you have available
Dec 11, 2015 | Pegasus 7" ST07-B Portable Handheld...
Does this model have a digital tuner or do I need to have a box to watch televison over the air?
Yes this tv dose have a digital tuner inside of it,all flats LCD and Plasma tvs are Digital tvs they all can get free DTV air broadcasting tv channels.All digital flats LCD and Plasma tvs are DTV set u just require a very good like a roof Antenna or a newly Digital design portable Antenna connected the tv incomming air broastcasting signal cable back of to the flats screen tvs at the axail input call ANT.Then go into the tv menu.Goto setup go down pick AIR than press the enter button for scanning for free DTV air broadcasting channels.After the tv finish scanning for channels than the tv will let ur tv to get all the free DTV broadcasting channels.
Sep 29, 2011 | Olevia LT32HVE 32 in. LCD Television
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
Cant get channel 11 when i hook my converter box to this tv is there a way i can i get regular tv without it
No,if this tv is an analog tv mean tv have a big back cover and have a heavy CRT-(tv tube).Must have a good antena like a digital antena or move antena around to left or right to pick up channel 11,might lost some other channels than.This tv now can't pick up digital signal now without the tv converter box if u want to pick up free DTV air broadcasting tv signal,it all broadcasting in DTV free air in all digital now.
Apr 14, 2011 | Apex Digital AT2402 24" TV
I need to know what steps need taken in order to update my Sony LCD Digital TV to accept the 1st phase of the Wow Cable digital channel conversion
U mean u want ur tv to getting a Free DTV AIR incomming broadcasting tv channels?Yes.U must have a good antena like a roof or a digital antena plug into the tv hole that said ANT.Go into tv menu goto SETUP go down CH. enter and pick AIR and then press enter again for scanning for Free AIR DTV incomming broadcasting tv channels.
Apr 04, 2011 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
My digital tv will only pick channel 10, abc and sbs, even though it used to pick all channels?
U trying to pick up all free AIR DTV tv stations wright?Yes.This problems u have a weak airial antena.Buy a better antena like a Digital antena or a roof antena for hook up.Tries again,will pick up all DTV free AIR tv stations.
Apr 03, 2011 | Televison & Video
Do you need a cable box for it
U mean a digital converter box for getting free broadcasting DTV airing channels?No,this tv it is a digital tv,just require a roof or a good digital antena.Hook it up with the antena and goto tv menu go to setup go down to Ch.pick AIR not CABLE and go into scanning for DTV channels after that tv will get all the free broadcasting DTV air channels.
Feb 17, 2011 | Toshiba 19HLV87 19 in. LCD HDTV
Im trying to comnect this tv so i can get the local channels only- no cable. the tv comes on but the connection is not there. thank you
Go to the menu pick air,don't pick cable u get free air channels,just use a regular roof antena or a digital antena.
Dec 10, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Digital TV not picking up all channels
TV is searching for over the air channels. Select in the main menu to go from over the air to cable channels and you should be fine.
Nov 19, 2008 | Televison & Video
Not picking up digital channels on my Dynex TV
My Dynex tv isn't picking up my digital cabel any suggestions for me Please!!! I am lost without my TV!!!!
Aug 14, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Soyo DYLT032D 32 in. LCD Television Logo
46 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
