Question about Bosch Washing Machines
Bosch was32440au beeping at end of wash cycle
SOURCE: beeping
Thanks! I found this online, which shows how to run tests on the washer to see what might be wrong, which helped, too. Now if i can just find a few muscly people to help me move the dryer from atop the washer.
http://forum.appliancepartspros.com/attachments/washer-repair/42d1194897506-error-code-01-wfk2401test.pdf
from this page:
http://forum.appliancepartspros.com/washer-repair/2385-error-code-01-a.html
Posted on Nov 26, 2007
  • 97 Answers
SOURCE: Beeping on spin cycle
It is most likely out of balance, could be for many reasons.
1 could be too many heavy items such as jeans, towels, etc in one load.
2 could be the machine or floor is unlevel.
3 Could be a balance sensor needs replacing.
Posted on Mar 22, 2008
SOURCE: bosch classixx6 1200 express
Turn Program switch to 6 o clock,hold RPM button turn switch to spin, release RPM button.Turn back to 12 o Clock .It should reset it ,Mine is a classicxx7 but should be the same...Marius
Posted on Jun 27, 2008
SOURCE: Zanussi ZWF16581W Washing Machine
Not helpful as the instructions given in the manual do not work. It may be that they do work at a certain point but they don't tell you WHEN to press them. When the machine has irritated you beyond belief in beeping like a maniac? Before you start the cycle? during the cycle? When? Have tried all of these but to no avail. What am I missing?!
Posted on Aug 04, 2009
SOURCE: I have a Bosch washer, model number WFK 2401 that
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Posted on Aug 06, 2009
Hi. Have a Bosch Loggix 8 VarioPerfect WAS32440AU. It has been displaying a uPd code. Was hoping that you can verify the issue. TIA Brian.
First, of all it is a Bosch "Logixx".
Not a whisper of your fault code anywhere... go to this site and towards the bottom you will see a FORM to ask directly about your specific model AND your exotic fault code! Are you sure you have that "code" right?
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes
Then I found THIS bad news!
"There are a number of different version of the electronics used in Bosch Group made washing machines and washer dryers that are sold as Bosch, Siemens and Neff and most of them use the different fault or error codes when they have a problem or a spare part fails. This particular article relates especially to the range of Logixx washing machines that have an ENR number in the format of WAS****GB/** where the asterisks replaced by a number for each one."
Find a long list of fault codes here:
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Yours is not on the list? Still sure about that number?
Anthony
Apr 02, 2018 | Bosch Washing Machines
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
How do I stop my Bosch logixx 8 from beeping endlessly at the end of a cycle?
hi, I found out last night after being wokenup by endless beeping.... start with program dial at " off position", then turn 1 notch to the right, and then press and hold eco-perfect button and turn prog.dial 1 notch to the right. a number will appear in the display. press"clock" button until number is 0. then turn prog.dial one notch more and do the same. all sounds are off now....
May 09, 2012 | Washing Machines
How do shut off the beeping noise when the washing cycle has ended?
I too had this problem and it drove me and my husband crazy! We have the 300 series washer/dryer. You just turn on any cycle on the main dial, and then press both of the Option buttons. A short beep = Off. A long or double beep = On. Try it a couple of times and you will hear the difference.
You can visit the Bosch website, go under service locator, enter your zip and get an 800 number. They will walk you through it on the phone, which is what I finally did.
Mar 19, 2011 | Bosch Nexxt 300 Series WFMC2201UC
How do i get the beep at the end of the cycle to turn off
To disable the end of cycle beep on the Nexxt washer, select a program and press two of the option buttons (e.g. Stain Removal and Allergy Rinse) and hold until you hear a short beep.
Aug 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Dishwasher finis tone
  • Open door, push and hold Delicate/Econo button, then turn the dishwasher on while holding Delicate/Econo button.
  • Release Delicate/Econo button.
  • If module beeps, then end of cycle tone is on. PressDelicate/Econo button to disable tone.
  • If module doesn’t beep after button is pressed, then tone is disabled.
  • Turn off dishwasher to save selection.
Jan 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
END OF CYCLE ALARM
The manual on my Bosch 500 plus 4.2 says to select a cycle and then push and hold two option buttons until you hear the beep to turn off the audible end of cycle alarm. Hope this works for you! P.S. It says not to try this with a load of laundry in the machine.
Jan 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Dec 06, 2008 | Washing Machines
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
128 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
