Question about Honeywell Programmable Thermostat Heater
Replace three wire thermostat with four wire thermostat
Hi
I have electric baseboard heating and I am trying to replace my thermostat. The baseboards are always cranking out heat even when the thermostat is turned all the way down, and I am assuming it is the thermostat that is broken.
Anyway...I just purchased a Honeywell CT410A
http://customer.honeywell.com/techlit/pdf/67-0000s/67-5169.pdf.
My problem is that when i took off my old thermostat is has three wires which appear to be red, black (maybe blue) and yellow (the wires are very old so the colors are faded).
The new thermostat i purchased has four wires, two sets of red and two sets of black.
can someone please explain to me how to hook the new four wire thermostat up the the three wires I have coming out of my wall?
thank you!!
  • 15 Answers
From the two red and two black wires (and the specs in the pdf), your new thermostat sounds like it's designed to directly control the line voltage (120 or 240) to the heater. That's the usual way baseboard heaters are controlled.
Could your wires be red, black, and (old, yellowed) white, the standard colors in a 3-wire power cable? Just the red and black should be enough to control a 120-volt heater so I don't understand what the white would have been used for. If it were my heater I'd take off the cover(s) -- with the power off, of course -- and find out what those wires actually connect to.
Posted on Jan 26, 2009
Why is my line voltage baseboard thermostat not shutting off at set temp?
I think you are right - it is the difference in wiring. On the ones that don't work, I suspect they are meant to run 2 baseboards each (hence the splices)
Run another black wire from the black splice and white wire from the white splice. Now treat these b & w wires as if they are from one baseboard unit and attach to the thermostat screws as the working ones are.
All this assumes that it won't exceed the capacity of the thermostat. If it does, you either need another thermostat for the second baseboard(s) or a relay that can handle higher current.
Be safe and good luck.
Please rate this 4 stars if it is helpful. Thanks.
Oct 24, 2017 | Heating & Cooling
How to set heat for baseboard heat
They use a 120v thermostat you should be able to buy one wherever you bought the baseboard heaters. Be aware those heaters costs a lot of money to run and dry out your house like a desert buy a few room humidifiers when you get the thermostat. Make sure you use the correct size wiring to the baseboard heaters and the Tstat if you undersize the wires for the breakers involved you'll more than likely cause a electrical fire.
Oct 01, 2014 | Honeywell Heating & Cooling
Replacing a Honeywell T822l1000 thermostat.
The W terminal is used for heating and goes to a small electric valve in the water line to your baseboard. The Y terminal is for a cooling system. The T822 is wired wrong and is not working. The wiring between R and W is corect for a heating only application. The R terminal is the power source.
Nov 10, 2013 | Heating & Cooling
We put in a new baseboard heater thermostat a couple of years ago in our 20 yr. old apartment. When we turned it on yesterday, it shorted and we no longer have any heat coming from the baseboard. Do we...
I have base board heaters in each room and each with a thermostat and hooked to a controller. The controllers activate the heat in the base board heaters. I believe this is how it works. When you activate the thermostat, it sends a message to the controller that sends a message to the base board for heat.
The controllers are Singers. Prbkem 2:. When I turn down the thermostat (to off), I still get heat in the base board heaters. WHY.
I was going to get rid off the controllers and thermostats and buy new base board heaters at Home Depot. The thermostats are on the base board heaters. Will this work.
Oct 26, 2010 | Electric TPI CORP TBS BASEBOARD HEATER...
Above some of the baseboard electric heating vents (the whole house is wired with electric (not gas, oil, or coal) heat there are black marks on the walls. what is causing this??? I do not burn candles,...
While it could be nothing, it is a good idea to have a heating professional check them once in a while. Sounds a little odd, though, as most electric baseboard heaters have no vents. You will be comforted by the reassurance of having them looked at. Farmerbear at FixYa.com
Sep 28, 2010 | Fahrenheat Built-In Baseboard Thermostat...
Disconnect baseboard heater
After confirming that the heater circuit is de-energized, simply go to whatever heater that you want to disconnect, open the junction box, remove the heater wires and cap them off. Twist the remaining circuit wires together, wire nut, replace the juction box cover and on to the next one. There are ways to install a thermostat at each heater too.
Jan 17, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Mar 17, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
1,284 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
