Question about Garden
How do i put the drive belt back on a sanli ride on mower?
I don't know how to get into the drive belt section to put it back on.
  • 18 Answers
SOURCE: motion drive belt on craftsman riding mower
there is no adjustment..it is set by the spring that engages ur drive belt....
Posted on Sep 03, 2008
  • 42 Answers
SOURCE: how to replace drive belt
here is a diagram that will hopefully help you. let me know if it helps, or if you need further assistance. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chus%5cimages%5c33%5c28%5c0009.tif&ilsc=16&iliv=0&ilbr=0&ilif=g&ilre=8
Posted on Mar 15, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
bargainbin2
  • 123 Answers
SOURCE: need a diagram on how to put a drive belt back on
It is a hard one to put on co look at the picture carefully there are two pulleys one that one side of the deck that are trickey.
Posted on Sep 01, 2009
  • 203 Answers
SOURCE: I have a John Deere LA140 Automatic riding lawn
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
That should help. It's on the John Deere website.
Posted on Nov 19, 2009
Riding mower won't go nowhere it's got drive belt on but won't drive
Is it a hydro? check the release lever some times i forget too. If its gears then try different gear and check that the belt is engaging fully if the clutch spring broke your pedal shouldn't push back up.
Oct 03, 2012 | Craftsman Garden
Need a diagram for the drive belt on a wheel horse c 100 8 speed
i don't have a diagram but the belt goes around the trans pulley and around the engine pulley and the pulley from the clutch pedal goes under the top section of the belt pulling up in the center hope that helps you
Aug 18, 2012 | Garden
My Motion Drive Belt slipped of it's pulley on a Husqvarna Riding Mower Model 917-289570. Do I have to remove the rear tire to put the belt back on?
i had a 2148. you remove the mower deck as the first step. feed the belt over the pulley on top the transmission, then put it over the engine pulley. then have someone push the clutch pedal in so the tensioner pulley moves, put the belt in the guide pulley and on the tensioner. release the clutch put the deck back on and you are good to go. notice there are little keepers welded to the frame for the front, engine, pulley and it is easy to mistakenly put the belt over them instead of under them.
a general rule is that a pulley shaped like a Vee takes the V of the belt whilst a pulley which is flat takes the flat back of the belt. if you bear that in mind you will not have a problem putting belts back on. also there is a little decal on top the deck showing how the deck belt and deck drive belt go.
Sep 09, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I had a new engine installed in my John Deere riding lawn mower. It was delivered, but now it doesn't cut grass, it seems like the blades aren't turning.
sounds like they forgot to put a deck drive belt back on it, or they forgot to hook the wire back up to the PTO unit which engages the deck drive belt when you turn on the mower. a visual inspection should reveal which. i would call the foreman at the shop and ask him to drop by a take a look at it so he can fix it and go back and chew some ***.
Aug 19, 2011 | Garden
DO NOT KNOW HOW TO REPLACE THE BELT TO THE DECK MOWER
Me to ... you want help but you don't give any description of the mower! There must be a way to remove it ... think about this ... someone put it on! so it has to come off! You may have to disconnect part of the deck, I don't know ... You may have to cut the old one off and pry the new one on (on cheaper models) I don't know, you will not tell me what we are working on. It SHOULD be reasonably easy - some company made them by mass production - they wouldn't make it hard for them to assemble (unless it is a really cheap one).
I suggest you get on the ground and study the deck ... look for levers or tension pulleys. Make sure the mower is OFF, OF COURSE. ALSO, disconnect the SPARK plug as turning the belt COULD START THE MOTOR!!!!!!! I don't know what this machine is so I am stressing the safety aspect of what you are about to do!!!!!!!!!
If you will post additional information on this machine, I may be able to offer more suggestions.
Thank you for using FixYa.com
Jun 05, 2011 | Garden
What kind of fluid goes in the hydrostatic drive ? The mower goes fine in forward and reverse when first started. As the mower heats up it has trouble pulling itself. After about an hour it will barely...
Hi Jeff,
Use hydrostatic fluid. Consult your owner's manual for information. Do not use hydraulic transmission fluid.
If you do not have your owner's manual, you can find one on www.managemylife.com Just go to that site, click on manuals and enter your make and model number.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 09, 2011 | Briggs & Stratton Garden
I have an early-2000s Troy Bilt Bronco, 42 inch deck, 18hp Briggs Inotek engine, hydrostatic drive. It broke or threw a drive belt (not for the mower deck, but a transmission belt). How to you go about...
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
Jun 14, 2010 | Troy Garden
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
