Question about Thermador 42 in Built in Side by Side Refrigerator w/ Masterpiece Handle - KBUIT4255E / KBUDT4255E
No power I have a Thermador side by side and it went totally out. No lights, nothing. I flipped all the circuits and it still won't come on. All the other electrical products in the house are working. Help!
  • 700 Answers
Check all of the gfi plugs that you have in the house and rest them.
Posted on Jan 26, 2009
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
Tail lights and turn signals dont work
Use the wiring schematic to follow the wires and check for any breakage or burnt wires. Repair any breakage and recheck. Check all grounds in the circuit as well; a faulty ground can cause total loss of lights.
Check the brake light switch near the break pedal. Use a voltmeter to make certain the voltage is correct with switch engaged and disengaged. Check the grommet that depresses the switch as well. Repair any issues and recheck.
Key Fob Programming
ECU Tuning Software
Immo Emulator
Car Key Chips
Airbag Reset Tool
Jan 23, 2014 | 1987 Suzuki Samurai
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
I was surfing the internet,All the sudden my acer made a noise and went dead,Now it does nothing no power indicater light,totally dead..
That noise was caused by the failure of the power circuits from the mainboard. This is a major failure - the entire mainboard will have to be replaced. For that you must take it to a repair shop, this isn't something you can fix.
Nov 15, 2010 | Acer AS7736Z4015 Notebook
Power window on driver side stopped working and the door locks stopped working . Also this morning the battery was dead but nothing was left on.
It sounds like you may a faulty door lock switch. If you pushed the switch to lock the doors and the switch stuck and kept door lock solenoids energized, that would drain the battery. It would also keep the door locks from unlocking, as to why window don't work it could all be on the same fuse or circuit breaker. Usually the power windows are on an automatic reset circuit breaker. Do you hear click and a short time later another click (with the battery charged)? If so that the circuit breaker tripping then resetting. Good luck!
Dec 19, 2009 | 2005 Chevrolet Colorado
Thermador rdss30rs xlo burners don't light and right side burners don't light either. can light right side with lighter. while burners are on igniter spark continously.
IF THE BURNERS DO NOT IGNITE
• Are the burner caps properly aligned and seated in the burner bases?
• Are the burner ports clogged?
• Is a fuse blown or is the circuit breaker tripped?
• Is the manual shut-off valve closed, preventing the flow of gas?
Jun 29, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
Error F5 comes on when trying to bake
Ok, this is a control fault that may or may not be solved by initiating a hard reset. To initiate this reset, you will have to unplug the entire oven for 3 total Min's. it is vital that you allow three total Min's before you power up once more. if you cant reach the actual plug, you can shut of the appropriate circuit breaker as well for three total Min's. Once the hard reset has been initiated, power the oven up once more. If the same problem still exists, you will have to replace the Electronic Oven Control Board.
Please rate and god bless:)
Apr 03, 2009 | Thermador SC302T Electric Double Oven
Thermador professional
I had the exact same problem. I read someone else turned off the circuit breaker in the electrical panel.. so I tried that. Flipped breaker off for 30 seconds and then turned back on. Oven now works perfectly as before. Go figure??
Oct 19, 2008 | Thermador PG486GEBS Stainless Steel...
Thermador 42 in Built in Side by Side Refrigerator w/ Masterpiece Handle - KBUIT4255E / KBUDT4255E Logo
187 people viewed this question
Top Thermador Refrigerators Experts
John Tripp
John Tripp
christian nielsen
ray gallant
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
