Question about Pioneer Car Audio & Video
Installing a pioneer DEH-6450BT
Hello sir/mam I am installing a pioneer car sound system for the second time into a different car, and the head deck is not receiving power so I would like to know how to get the power by knowing what cords to hook up too
Cerfer39
  • 709 Answers
SOURCE: I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
Hi Elimo
Two pics as the manual had the paragraph separated. This is for DEH 2500 only. Let me know if you want the 1500 as well.
Posted on Nov 24, 2007
c renner
  • 43 Answers
SOURCE: pioneer DEH-31
Check out this pdf file from Pioneer (it's for the DEH-3100 but the wiring colors will be the same - you can disregard the IP-bus input since your DEH-31 doesn't have one).
For the car side you can probably purchase a wiring adapter that will plug into the connector that went to your factory radio - this adapter will have wires which you connect to the same color wires on your Pioneer's wiring harness.
Posted on Feb 23, 2008
  • 158 Answers
SOURCE: Wiring for Pioneer DEH-P5900IB
A word of caution here.If the wires are ,old, faded cut etc, please consider REPLACING them.
Replace ALL the wires with new ones as wires matter a lot in a car stereo .
as for the wiring diagram go to www.pioneer.com or InfoBravado.net/car manual.
Posted on Jul 14, 2008
  • 87 Answers
SOURCE: wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Posted on Jun 02, 2009
  • 3 Answers
SOURCE: I installed a pioneer Deh p49001b car stereo in a
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
Posted on Aug 12, 2009
Pioneer DEH-X6500BT amp & speaker problems
Depending on the car and your setup sounds like the amplifier is not wired properly or an issue with adjustments on your deck itself. More info on your sound setup would be helpful.
Dec 28, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
Pioneer deh p3100ub shuts off when i touch deck
sounds like the faceplate is not seated right or has dirty connections but it is in your detachable face plate. your still under warenty.
May 24, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
I am looking for user guide & installation manual for Pioneer DEH-2750mp car tuner.Pl provide link where I can download FREE
hello sir =)
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Apr 09, 2010 | Pioneer DEH-27MP CD Receiver w/ MP3/WMA...
How to set time on a Pioneer DEH-680MP CD radio
power off deck, hold func key few seconds then adjust when done power on
Mar 05, 2010 | Pioneer DEH-P680MP CD Player
I don't know how to wire this pioneer deh-p2900mp
the wires will not be the same. the best thing to do is go to the nearest place where they sell radios and they do have to sell the two plugs that have the same wiring diagram as the radio and then direct connect to the two plugs on the car.
Sep 11, 2009 | Pioneer DEH-P2900MP CD Receiver...
NO POWER TO MY DECK
Hello clarky909,
On your Alero, the 12V constant wire is ORANGE and should connect to the YELLOW wire coming from the DEH-2300 wiring harness. 12V switched on your Alero is YELLOW and should be connected to RED coming from the DEH-2300.
Hope this helps.
Jun 01, 2009 | Pioneer DEH-2300 CD Player
Pioneer DEH-14 display not lighting up...... help?
The display only lights up when correctly wired to the lighting system.
Jan 11, 2018 | Pioneer DEH-14 CD Player
Pioneer DEH-225 Car Audio
The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
Oct 07, 2007 | Pioneer DEH-225 CD Changer
Car Audio & Video Logo
54 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
