Question about GPS
Lowrance EP-85R storage device problems
I have installed an Lowrance EP-85R storage device to my network to display and record fuel usage from my E-tec. The storage works well as I can record and display all fuel data on my LFM-400 gauges, however every trip I do at different time intervals the storage unit will reset and display strange figures. The i am forced to reset all data. Please help as this defeats the purpose of installing the device.
SOURCE: Re: Magellan Maestro GPS 4250 original data erased....
download the new firmware again and run the setup
Posted on Aug 31, 2008
SOURCE: lowrance 330c gps unit
A "soft reset" can be accomplished by pressing and hold "Pages" key and press and hold "PWR" key till USA map comes on , then release both. A "hard reset" requires press and hold both "Z in" and "Z out" buttons and press and hold "PWR" button releasing all three when USA map appears.
Posted on Oct 28, 2008
SOURCE: FineDrive 400 Map Data
Hi I have the maps for 400 , I can upload the files to an FTP , if you give me the address
Posted on Nov 09, 2008
  • 24 Answers
SOURCE: Nuvi 5000 not starting up
Call Garmin customer support at 800-800-1020 and they will talk you through the reset process for FREE! Wait time may be long but worth the free help! Good luck!
Posted on Jul 07, 2009
SOURCE: Installing the Lowrance HDS 5
You do not need the data cable connected unles you are hooking it up to other electronics, ie computer, second GPS sounder ect. You only need to conect the red to the positive on the battery and the black to the negative.
Posted on Jul 17, 2009
My new Lowrance Hook-5 GPS isn't working, I'm a noob, how do I get this function working?
'isn't working' is such a broad problem. If it is only the GPS, it is covered from Page 49 of the manual and shows you can access Satellite information. Note, it almost certainly won't work in your garage or storage. It need to see the sky as the antennae is internal.
The unit has an installation guide. In my personal opinion, it is better to let a professional boat engineer install it, mainly for the correct fitting of the transducer on the stern. Correct placing makes all the difference to a good set up, unless you intend to fish without the engine running.
All they need is mounting, power through a fuse direct to the battery, and the transducer fitting. Then you put the boat in the water and switch it on.
Installation Guide
http://www.lowrance.com/Root/Operator%20Manual/Lowrance/HOOK-5-SERIES_IG-MT_988-11024-001_w.pdf
Manual
https://www.lowrance.com/Root/Operator%20Manual/Lowrance/HOOK-SERIES_OM_EN_988-11004-002_w.pdf
Full Specs
HOOK 5 Fishfinder and Chartplotter
Apr 24, 2017 | Lowrance GPS
Need a repair shop for GPS,Fisher
Hi Clarence
Although the problem COULD be a faulty depth transducer, in my experience this is usually caused by a cabling problem, either there is a poor connection at the display unit, a poor power cable connection, RF interference from another device or the cable has been pinched causing an intermittent fault. After making SURE the power cable is tight, I'd clean the connections, then inspect the cable looking for an area that has been stressed. If you have a VHF radio nearby, try shutting that down during your testing. If depth reads normally, you know where your issue lies.
Good Luck!
-Steve
Oct 27, 2014 | Lowrance PARTS - LOWRANCE 15FT EXTENSION...
Lowrance EP-85R storage device data lost
how much memory space do you have on your chip if you use up all memory it will delete all to make room for new memory
Jan 19, 2013 | Lowrance Boating
How to wire a lowrance elite 7 hdi
Hi Everyone, Has anyone install EP-60R Fuel Sensor unit to Elite 7 HDI ? I have hustle making it work. Appreciate if anyone successfully solve similar problem. Dan
Record greeting
What kind of voice mail system do you have? They all are limited to the amount of total storage available. It probably has one or more mail boxes that are full and using up your storage. If it is a call pilot 100 or 150 and you have call pilot manager access, you can click on "message usage" under the reports menu and it will tell you the current storage available. Hope this helps.
Bill C www.dyna-tech.us We also offer remote programming and tech support for the Norstar CICS, MICS and the Call pilot 100/150.
Mar 16, 2010 | NorStar M7310 Corded Phone
Trying to figure out how to start up my fuel guage on my Lowrance
You need to purchase a EP 60 fuel flow meter. Once you have it installed in your boat, you need to monitor it. You set it up under NMEA DEVICES on your setup menu,
Jun 18, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Connecting a red device to blue network.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Apr 10, 2009 | Lowrance Ep 60r Fuel Flow Probe And Cable
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Globalmap 2000 sonar not responding
Not enough info to diagnose your problem. It sounds like a networking problem. I couldn't find a manual for the sam-st module so I'm not sure how you have it hooked up. Typically with these devices only one would be hooked up to the SONAR module, and it would then share the data with the other display via an ethernet or NMEA2000 network. The erratic behavior of your bluewater could be due to some sort conflict with the current coming from the GlobalMap2000. Do you get the same problem when the 2000 is turned off? Have you tried running the GlobalMap2000 with the bluewater turned off?
Aug 04, 2008 | Boating
Sony DVD recorder RDRGX210S PLaying back in ep only.
Have you tried to see if you can record in sp directly. That is, without any timed delay?
Feb 15, 2008 | Televison & Video
GPS Logo
59 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
