Question about Kodak EasyShare DX6340 Zoom Digital Camera
DID NOT SWITCH ON.WHY? - Kodak EasyShare DX6340 Zoom Digital Camera
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello, There are several reasons : Battery Problems, Switch Malfunction, Camera Internal Problem. You probably need to have it checked by a camera tech to find the cause.
Best Regards, Russell
Posted on Jan 24, 2013
How do i install handlebar mounted kill switch in a chinese 72cc atc
replace the key switch as it is faulty
as to fitting a kill switch find a switch that the mount opens up so that the switch can be mounted without the necessity to remove anything off the handle bars take a wire from the key switch and run it to the kill switch and from the other terminal reconnect it to where it came from. This means that the power from the ignition switch now goes to the kill switch then back to where it was originally connected after the igition switch.
Feb 07, 2015 | Cars & Trucks
Tip
How to service a lid switch
The lid switch on a washer often serves as a safety switch. If the switch is not working, or if the switch opening in the lid is clogged with detergent, the machine will not run. To check and repair the lid switch:
- Unplug the machine. Clean out the lid switch port with a wood manicure stick or chopstick. Clean off any detergent buildup around the rim of the lid. Sometimes there's enough detergent encrusted on the metal to prevent the lid from closing tightly and keep the washer from operating.
- If cleaning doesn't help, remove the top of the cabinet to get at the switch. With the switch exposed, check the screws for looseness. Loose screws can cause the switch to move when the lid is closed or as the machine goes through its cycles. Check the terminals of the switch to make sure they're tight. Tighten the mounting screws after the switch is in alignment. -Test the switch with a VOM set to the RX1 scale. Disconnect the power leads to the switch terminals and clip one probe of the VOM to each terminal. Close the lid of the washer. If the meter reads zero, the switch is working. If not, the switch is faulty and should be replaced. - If necessary, replace the lid switch with a new one of the same type. Connect the new switch in exactly the same way the old one was connected.
- If the switch still doesn't work, it is probably misaligned. Realign the switch by repositioning the screws holding it in place, testing the switch as you go until it works properly.
on Jan 16, 2010 | Washing Machines
Kexus ignition switch replace
To troubleshoot these issue, for ignition switch replacing procedure:---
Click the link below:---
IGNITION SWITCH REPLACING
It depends on vehicle to vehicle. But it's not very difficult on mot of cars to replace ignition switch. Basic theory of replacing ignition switch is same for all car models. -----
To replace ignition switch on your vehicle, I suggest you few helplinks with proper ignition switch replacing procedure. View its details and you can replace ignition switch on your vehicle.
Click the link below: ------
How to remove ignition switch on VW Car models?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-ignition-switch-on-vw-car.html
How to replace Ignition Lock Cylinder on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-lock-cylinder.html
Ford Taurus: Ignition Switch & Steering Column Replacing?
http://repairhelpcenter.blogspot.in/2012/06/ford-taurus-ignition-switch-steering.html
How to replace Ignition Switch on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-switch-on-acura.html
How to Replace Ignition Switch on Chevrolet Caprice Classic?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-ignition-switch-on.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
These will help.
Thanks.
Dec 06, 2012 | 1993 Lexus Es 300
How to replace ignition switch
It depends on vehicle to vehicle.But its not very diffult on mot of cars to replace ignition switch.Basic theory of replacing ignition switch is same for all car models.:-----
To replace ignition switch on your vehicle,i suggest you few helplinks with proper ignition switch replacing procedure. View its details and you can replace ignition switch on your vehicle.-------------Click the link below :----------------
1995 Ford Taurus: Ignition switch not turning OFF? http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Switch Will Not Turn Off? http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
These will help.
Thanks.
Nov 25, 2012 | Cars & Trucks
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
Giving code p0704
P0704- Clutch Switch Input Circuit Malfunction
Possible Causes:
- Open or short clutch switch circuit
- Poor clutch switch circuit connection
- Damage clutch switch
- Misadjusted clutch switch
- Damaged ECM
Possible Solution: Check clutch switch adjustment, the switch should open and close when the clutch pedal is depress. If the switch is properly adjusted, replaced the clutch switch to resolve problem.
Aug 26, 2011 | 1998 Dodge Avenger
THE "SWITCH" GOES BAD EVERY
Please look at the list below, keeping in mind that this is not an exhaustive list of the switches that your vehicle is equipped with. After staring at the list for a while, tell me what is wrong with your question.
>> A/C High Pressure Switch
>> A/C Low Pressure Switch
>> A/C Refrigerant Pressure Sensor / Switch
>> Ambient Temperature Sensor / Switch HVAC
>> Blower Motor Switch
>> Brake Fluid Level Sensor/Switch
>> Brake Fluid Pressure Sensor/Switch
>> Brake Light Switch
>> Brake Switch (Cruise Control)
>> Cabin Temperature Sensor / Switch
>> Combination Switch
>> Coolant Temperature Sensor/Switch (For Computer)
>> Cruise Control Switch
>> Door Jam Switch
>> Door Sensor/Switch (For Alarm)
>> Door Switch
>> Driver Information Center (DIC) Switch
>> Engine - Coolant Temperature Sensor/Switch
>> Fog/Driving Lamp Switch
>> Fuel Door Switch
>> Garage Door Opener Switch
>> Glove Box Lamp Switch
>> Hazard Warning Switch
>> Headlamp Dimmer Switch
>> Headlamp Switch
>> Heated Glass Element Switch
>> High Pressure Sensor / Switch
>> Hood Switch / Sensor
>> Horn Switch
>> Ignition Switch
>> Ignition Switch, Buzzer
>> Low Pressure Sensor / Switch
>> Neutral Safety Switch
>> Parking Brake Release Switch
>> Parking Brake Warning Switch
>> Power Door Lock Switch
>> Power Mirror Switch
>> Power Seat Switch
>> Power Window Switch
>> Pressure Cycling Switch
>> Rear Defogger Switch
>> Remote Switch
>> Seat Belt Buckle Switch
>> Seat Heater Switch
>> Seat Memory Switch
>> Shift Interlock Switch
>> Sunroof / Moonroof Switch
>> Telescoping Wheel Switch
>> Tilt Wheel Switch
>> Traction Control Switch
>> Transmission Mode Switch
>> Transmission Temperature Sensor/Switch, A/T
>> Trunk / Liftgate Switch
>> Trunk/Liftgate Sensor/Switch (For Alarm)
>> Turn Signal Switch
>> Underhood Lamp Switch
>> Valet Switch
>> Washer Fluid Level Switch
>> Windshield Washer Switch
Aug 17, 2011 | 2001 Cadillac DeVille
With the switch in the up position(toward input screws on back) and placing the ohm meter probes; one on the upper left, one on the lower right, continuity is read. Reversing (one lead on upper right, one...
I answer questions for free.
I understand electrical devices.
It is unclear how many screws are on the switch you are testing.
If your switch does not show ohms when the switch is in one position, then it sounds like the switch is bad. But you can read information below for more information about your testing.
You can also add a comment and continue the discussion.
Let me provide more information about switches because you seem interested in electricity and the information may help us understand where the other is coming from in case you add a comment needing more help:
2 screws on switch: (excluding ground screw)
An ordinary single-pole switch usually has 2 brass colored screws.
These screws only read ohms or continuity when switch is in one position.
When the switch is in the other position, there are no ohms that pass through the switch.
3 screws on switch: (excluding ground)
A 3-way switch has 3 screws. There are 2 brass-colored screws and one dark-colored screw.
Put ohm tester on dark screw and continuity will show between the dark screw and one of the brass screws.
Flip the switch and ohms will test between dark colored screw and the other brass screw.
4 screws on switch. (excluding ground)
There are 2 screws on each side of switch.
This type of switch might be a special purpose double-pole switch.
Or it might be the more common 4-way switch.
Add a comment if you have a switch with 4 screws.
Below is a typical 3-way switch application showing the dark-colored screws:
Here is a typical 4-way switch circuit:
Notice the switch in middle has 4 screws:
Link below goes to a special application double-pole-double-throw switch:
http://waterheatertimer.org/images/30-Amp-DPDT-switch-a-800.jpg
Nov 01, 2010 | Leviton Decora Gray Rocker 4-Way AC Quiet...
Replaced the bulbs and checked fuse but the brakelights fail to work. Could it be a switch.
Yes, it could be the switch behind your brake pedal.
  1. Remove the driver's side instrument panel trim panel/sound insulator.
  2. Detach the switch electrical connector.
  3. Remove the switch from the retainer by grasping it, turning the switch 90° counterclockwise, and pulling it toward the rear of the car.
The brake light switch (3) is mounted on the brake pedal support (1) and secured with a retainer (2)
To install:
  1. Insert the brake light switch into the retainer until the switch body seats on the retainer.
  2. Pull the brake pedal upward against the internal pedal stop.
  3. Turn the switch 90° clockwise in order to lock it into position.
NOTE Proper switch adjustment is achieved when no clicks are heard as the pedal is pulled upward and when the brake lights do not stay on without brake application.
  1. Attach the switch electrical connector and test the switch for proper adjustment.
  2. Adjust the brake light switch, as follows:
    1. Detach the switch electrical connector.
    2. Remove the switch from the retainer by turning it counterclockwise 45°, and pulling it toward the rear of the car.
    3. Insert the switch into the retainer until the switch bottoms out against the brake pedal and the switch actuator button is fully depressed.
    4. Snap the switch into the retainer by turning it clockwise 45° until a click is heard.
  3. Attach the switch electrical connector.
  4. Install the hush panel/sound insulator.
  5. Connect the negative battery cable.
Sep 13, 2010 | 1998 Oldsmobile Cutlass
1998 Mercury Villager Break light switch
go here for help. http://autos.groups.yahoo.com/group/villagerquest/
Brake light circuit goes through turn signal switch. Do turn signals work ok? Does high mount stop lamp do this too? If you disconnect brake switch, do the lights go off? Do you have trailer tow? Maybe that wire is an issue. I would check brake switch first again. Maybe out of position.
I think you need to adjust the switch.
Installation
  1. Install the BPP switch.
  1. Adjust the BPP switch. Refer to the procedure in this section.
  1. Tighten the BPP switch locknut to 12-15 Nm (9-11 lb-ft).
  1. Connect the BPP switch electrical connector.
  1. Connect the battery ground cable.
Section 17-01: Lighting, Exterior 1998 Villager Workshop Manual
ADJUSTMENTS Brake Pedal Position (BPP) Switch
  1. Measure the distance between the brake pedal stopper and the threaded end of the brake pedal position (BPP) switch. The BPP switch height (A) should be 0.3-1.0mm (0.012-0.039 inch).
  1. If the BPP switch height is not within specification, loosen the BPP switch locknut.
  1. Adjust the BPP switch until the height is within specifications.
STOPLAMPS Condition Possible Source Action
  • Stoplamps/Rear Hi-Mount Lamp Inoperative
  • Fuse.
  • Circuit.
  • Brake pedal position (BPP) switch.
  • GO to Pinpoint Test Step K1 .
  • One or More Stoplamps Inoperative
  • Stoplamp bulb(s).
  • Circuit.
  • GO to Pinpoint Test Step L1 .
  • Stoplamps/Rear Hi-Mount Lamp On Continuously
  • BPP switch.
  • REPLACE the BPP switch.
Apr 20, 2009 | 1998 Mercury Villager
Kodak EasyShare DX6340 Zoom Digital Camera Logo
24 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
