The volume control on my sercive electric remote dose not work but everything else dose why?
Volume button will not go up or down
    Producer:
    Uploaded 30 video answers.
  • 155 Answers
You need to program the tv code into the remote. then the volume will work the tv volume.
Posted on Feb 09, 2013
  • 3 Answers
SOURCE: volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Posted on Jan 23, 2007
Emsy32
  • 3 Answers
SOURCE: How do I get the volume to work on my sky remote control?
I've just done this, guided by SKY but all you really need to do it....
Press Interactive button on remote
Choose option 5
Then choose set remote control, it should give you instructions and the correct cde fo ryou specifc tv
Good luck
x
Posted on Jan 05, 2008
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
jerryg50
  • 1667 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
  • 6 Answers
SOURCE: Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Posted on Apr 11, 2009
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
When I put batteries back in remote control it automatically turns volume down, when I take batteries out everything seems to work OK manually
It seems like the volume button is stuck on the remote itself. If you can, try and clean the remote and see if you can free that button.
Jan 07, 2011 | Sony STR-DA90ESG
No Volume.
Try another remote code for that brand tv, there are many different codes for the same make.
Jul 22, 2010 | Universal Remote Control Philips Pronto...
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Remote control not working properly
Just try cleaning the keypad rubber inside, using cotton moisten with alcohol
Aug 17, 2009 | Televison & Video
My volume and mute button dont work on my sky remote
panasonic
please follow the steps below:
TV
RED + SELECT
TV
0051
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
May 06, 2009 | Universal Remote Control Remote Control
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Volume automatic decreases. Have no control of volume
Ensure nothing sticky has been spilled on the TV or the remote, causing the volume down button to stick. Remove batteries from remote to rule it out. Carefully inspect TV volume control for a sticking button. If you find it is sticking, get electrical contact cleaner from Radio Shack and spray the button. Ensure TV is unplugged first.
Oct 27, 2008 | Televison & Video
My tv will not come on because of block; my remote doese not work how do i get the tv to work
press menu button on front panel and volume down on remote for 3-5 sec.
Dec 15, 2007 | RCA 32F531T 32" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
