Question about Nokia N73 Cellular Phone
I am getting no memory card inserted
After inserting memory card in my nokia n73 i am getting no memory card inserted
  • Amin Apr 01, 2014
    format ur memory card,2.test with another card,3.flash ur phone.cheers
    Filmmaker:
    Uploaded 5 video answers.
  • 93 Answers
Remove your battery
insert your memory card
insert your battery
Power On.
if still no memory card inserted
Replace your memorycard
something wrong with your memory reader (parts of cellphone)
Posted on Jan 19, 2013
manojro
  • 495 Answers
SOURCE: memory card not inserted
Insert your card propely. You can also check when you connect your handset to computer and verify if data is there.
Posted on Nov 26, 2008
Raysagem
  • 1017 Answers
SOURCE: n73 problem
Use only miniSD cards approved by Nokia for use with this device. Nokia utilizes the approved industry standards for memory cards but not all other brands may function correctly or be fully compatible with this device.
Use only compatible miniSD cards with this device. Other memory cards, such as Reduced Size MultiMediaCards, do not fit in the memory card slot and are not compatible with this device. Using an incompatible memory card may damage the memory card as well as the device, and data stored on the incompatible card may be corrupted.
Press menu and select Tools > Memory. You can use a compatible miniSD card as extra storage space and for backing up the information in the device memory.
To back up information from the device memory to a compatible memory card, select Options > Backup phone mem.
To restore information from the compatible memory card to the device memory, select Options > Restore from card.
To eject the memory card, press , and select Remove mem. card.
Important: Do not remove the memory card in the middle of an operation when the card is being accessed.
Removing the card in the middle of an operation may damage the memory card as well as the device, and data stored on the card may be corrupted.
"I used to be apathetic, but somehow I just lost interest..."
Posted on Apr 08, 2008
karankr
  • 274 Answers
SOURCE: n73 no memory card inserted solution
Full format solution for NOKIA
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Posted on Mar 10, 2010
  • 306 Answers
SOURCE: memory card
u ll hav to get track of the setting in ur cell about the memory card.. if any changes n the settings of mem card may display lik tis..
  • 1011 Answers
SOURCE: Get Memory card not inserted
simply check the memory card through card reader if it works then u have to check the socket of phone where the card is to be inserted..
that one is causing problem...may be its pins are not propely being connected with the memory card..
if  the card doesnt work even with memory card reader then the card is faulty...or if u dont have memory card reader just put your memory card in another compatible phone to check..
or get another card and put it in your phone for checking..
hope it will fix the issue so dont forget to rate it...
Posted on Jul 06, 2009
My phone memory card is ok but phone N73 is not detect it
make sure you are inserting the card facing the right way.if it is then somthing is wrong with your card or phone.. trying inserting a new card
Jan 23, 2011 | Nokia N73 Cellular Phone
When insert the memory card the cell phone wil hang...........
HI there format the memory card from the computer & after that insert it in mobile. If your memory card infected by virus then then phone will hang. So before insert format the card from a virusless PC. Thanks.
Apr 02, 2010 | Nokia N73 Cellular Phone
I have re-inserted my memory card of Nokia N73. but is showing "memory card not inserted"
ur memory card may damaged or used password in memory card. pls check other phone to confrm
Jan 11, 2010 | Nokia N73 Cellular Phone
N73 Hangs when Mem card is inserted.
first try to format the memory card through the mobile ...
Sep 22, 2009 | Nokia N73 Cellular Phone
In my n73 phone even thought the memory card is inserted it displays insert memory card now what shld i do.
Try cleaning the connectors on the memory card. Check the card on a different phone or PC. Make sure the card is inserted correctly, right side up.
Aug 08, 2009 | Nokia Cell Phones
Memory card not inserted problem
i have aslo the same problem but i have solve it know take out ur memory card  from the mobile and clean it properly and  in place the memory card is inserted clean that area also . ur problem will solve enjoy guys.
Apr 12, 2009 | Nokia N73 Music Edition Smartphone
Nov 26, 2008 | Nokia N73 Cellular Phone
Memory card
Memory card of nokia n73
yes the MC can be formatted..
If it detected all the datas in your card. The card was working perfectly.So just copy files from the card to hard disk..
just insert the card into the Card Reader, copy items to hard disk. Format it, then copy items back to card. And then insert the card back to phone. You have all your data back.
Jun 24, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
309 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
